Question about NCR Computers & Internet
Have a ncr 2126 1300 error code 0409 won't reset. what do I do
Ncr atm error codes
Contact NCR Support. They should have the answer to this problem. That is a proprietary piece of equipment.
Jul 19, 2013 | Computers & Internet
Ncr cash register model 2114 3Err code
error 3 code on model NCR 2114 is a printer error meaning the printer cannot complete a print cycle caused by various issues concerning the condition of the printer
Nov 16, 2011 | Computers & Internet
I have a 7870--2000 NCR scaner and it keeps freezing with the cash rigester?
First determine if the problem is the scanner or the register. Switch scanners with another one, does the problem follow the scanner?
Could be the cable, interface card on teh scanner.
If the problem stays at the register and you tried a new cable, the register is the problem.
Apr 10, 2010 | NCR 7872
Capital Computer Group, LLC
651-405-8293
www.capcom-ncr.com
We specialize in the NCR arena, also have many other point of sale needs.
Free bench testing equipment failure on any p.o.s hardware item.
Nov 05, 2009 | NCR 7875
7875 scanner/scale error code 4.
Problem is with the scale part of theunit, it needs calibrating, you can do this but you do need a set of weights, and it also depends on what country you are in reference the legality after you have done this. But chack fist the top plate is OK not damaged and sits OK, press scale zero. If that does not work there is a cover at the front of the unit sometimes with a seal over it or through the part that stops the cover being shown. Press the button under thisand follow the audio instructions, you will need 2.5kg, 5kg & 10kg or 5lb, 15lb & 30lb depending on ncountry you may need Weights & Measures in to verify afterwords depending on legalities
Mar 26, 2009 | NCR 7875
I have been getting error code and now error code , which I assume are related, Where can I get a replacement ink absorber?
2425 Enterprise Dr.
#200
Mendota Heights MN, 55120
Wethernb@capcom-ncr.com
651-405-8293
We Buy, Sell, Repair, and Refurbish both new and used POS Systems, NCR, IBM... We also offer structured cabling as well as Video Surveillance Equipment.
Give us a call and we can trouble shoot it with you!
Jan 14, 2009 | Office Equipment & Supplies
Programming scale to display in pounds
ITS YOUR SCALE BOARD! <-- I am also an NCR Technician (Now Sales and Technician)
2425 Enterprise Dr.
#200
651-405-8293
Dec 29, 2008 | NCR 7875
Error 230 en Escaner NCR 7875
You need disable the scale scannig the bar codes for programing
Program mode
304
save and reset
301lbs to kg
302kg to lbs
303enable scale
304disable scale
305 Protocol comunication
306 Protocol comunication
307 Protocol comunication
Oct 08, 2008 | NCR 7875
NEED ACTIVATE READ OF CODE 128 IN NCR 7872 SCANNER
Reset
Defaults
Prog.mode
Hex 1
Hex 7
Hex 1
Hex 1
Hex 0
Save & Reset
Aug 14, 2006 | NCR RealScan 7872 (787220509090) Fixed...
Computers & Internet Logo
133 people viewed this question
Top NCR Computers & Internet Experts
 steve
steve
Are you a NCR Computer and Internet Expert? Answer questions, earn points and help others
