Question about Epson Perfection 3490 PHOTO Flatbed Scanner
How do I clean the inside of the glass on the Epson 3490 Scanner?
My Epson Perfection 3490 Photo flatbed scanner has accumulated a lot of dust on the INSIDE of the glass. How do I clean the inside of the class on this device. The scanner generates a lot of dust and grime.
Disconnect and remove the lid. Remove the two screws on the back of the base. Then use a screwdriver or flat blade to slightly open the back seam. Beginning at the back, run a blade up inside the upper part of the side seam. You will need to release three catches on each side. Once the sides are loose, raise the back of the top, while pushing forward, and the two snap catches at the front will release. The top then lifts off and you can clean the glass. Reassemble in reverse order.
Posted on Nov 17, 2009
  • 156 Answers
I have never done that particular one, but you can remove the glass and clean the bottom. Most are fairly easily removed by removing a few screws. And yes, almost every one of these things do gather dust on the inside. Most come from the factory with it :>)
Posted on Jul 03, 2009
3490 photos wont feed out after scanning
The Epson 3490 is a flatbed scanner that has an optional business card/4x6 photo auto feeder. Do you have the optional feeder attached & plugged into the correct connecter on the back of the scanner? Also, make sure the Epson scanning software has been configured to use the auto feeder. http://www.epson.com/cgi-bin/Store/ProductQuickSpec.jsp?BV_UseBVCookie=yes&oid=48059604&category=
Nov 02, 2013 | Epson Perfection 3490 PHOTO Flatbed...
How do I clean the underside of the glass on the 2450 epson perfection scanner?
Scanners are not meant to be user serviceable. This means that to clean the inside of the scanner, its better that it be brought to the manufacturer who can do this in a safe and correct manner. Believe me, it is worth doing this than ending up having a non-working scanner.
Jan 11, 2010 | Epson Perfection 2450 Photo Flatbed...
My epson 3490 photo scanner isn't working theres a red light on the front of the scanner which is flashing
If the start button light is flashing red, it is because of one of the following problems:
  • The scanner is not connected to your computer properly or your software is not fully installed.
  • The transportation lock is locked. Slide the lock to the unlock position.
After trying these solutions, unplug the scanner to turn it off, then plug it back in.
Sep 30, 2009 | Epson Perfection 3490 PHOTO Flatbed...
Scanning 110 negative film
I just finished scanning many 110 film strips. You need to lay the strip along the inside edge of slot A and scan in normal preview mode. On the preview strip, put a marquee around each individual photo and scan each one separately. Worked fine for me.
Sep 27, 2009 | Epson Perfection 3490 PHOTO Flatbed...
I have vertical lines in my photos when i scan them
If the lines are in the same location for all scanned outputs, it is clearly dust on the scanner glass. Clean it thoroughly.
S. Mohan, India
Jul 04, 2009 | Epson Perfection V350 Flatbed Scanner
How to cleas Epson Perfection 3200?
use a lint free cloth, slight moisten the cloth and clean the glass.
do not spray anything on the glass.
Apr 04, 2009 | Epson Perfection 3200 Photo Flatbed...
I have lost the power cable for my Epson perfection 3490 -
Hi Dave!
Go to a good elecronic store and buy a power cord.
Juste be sure that you have the info about the cord you lost.
You will find that info here:
http://files.support.epson.com/pdf/pr349p/pr349ppg.pdf
Just make sure that the voltage and the amphere is correct.
Any good elecrtonic store have replacement cords stored.
Good luck to you
Nic
Feb 05, 2009 | Epson Perfection 3490 PHOTO Flatbed...
Epson Perfection 3490 PHOTO Flatbed Scanner Logo
2,290 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
