Question about Akai PDP-42TD1 42 in. EDTV-Ready Plasma Television
Akai viella kk i have an lcd 1080p akai viella its been giving me problems when i play on it with my 360 i change it to hd its perfect picture except the sides then when i actually starts playing it goes to lines when its on regular it just starts to look like its static
SOURCE: Akai 42" LCD has lines on start up
I got the same problem on a LCT42Z6TM. It is related to video, occurs on VGA, S-Video and Video Ports.
Posted on Aug 30, 2007
retrohack
  • 27 Answers
SOURCE: akai lct2721ad flashing red light
I would bet on the power supply....these (and other Akai LCD) are notorious for filter capacitors. Look for electrolytic capacitors with a dome-like bulge on the top of them. They are usually located at the top of the power supply board where the power output lines run out.
Hpe this helps you out....
Posted on Oct 23, 2007
  • 62 Answers
SOURCE: Akai LCT42Z6TM HD 1080P TV
Yes - the four capacitors that are mentioned are the correct capacitors - call 800-726-4405 to verify the info. akai LCT42z6tm
Posted on Mar 29, 2008
  • 98 Answers
SOURCE: Akai LCT3201AD 32 in. LCD
This is not a Samsung/Akai tv, but it is a cheap Chinese "counterfeit" tv. Here is the makers' info:
APH USA Inc.
5900 Canoga Avenue
Woodland Hills, CA 91367
United States
Phone Number: 800 837 4685
Fax: 818 702 2289
Posted on Jun 09, 2008
  • 60 Answers
Yes, I am a computer / electronics person and by brother's tv had the same problem, here is a complete description of the problem and the fix. Many thanks to all that have come before
Symptoms
1) While watching tv, there will be vertical grayish lines that move around a bit on the screen
2) While viewing a menu, the menu will be all hacked up as if the bits are all out of order
3) If you unplug all of the sources and then re-power the tv, unplug from wall, the tv will seem it is working fine. Menus will work until a video source (Component) is plugged into the tv.
Tacking the back off
WITH TWO PEOPLE Lay the TV on a table with a blanket, etc to protect the tv. Do not try and move the TV with the back off in general. You may flex the screen and damage it.
Remove all of the screws from the back including the one under the sticker near the left bottom. Remove the stand from the bottom. Lift the back up from the left to the right. Power is hooked to the right of the back. Remove the two screws to remove the power jack from the back.
Remove the back and place aside
Remove the RF cover from and the board will be underneath
Remove all of the screws from the board and from the RCA connectors from the outside bottom of the board.
Carefully remove all of the wires, taking time to remove the glue from the connectors. The glue should "Snap Off", take your time here. Remove the wires, noting where they all are. Take your time with the big connector on the left side.
You will see that all / some of the caps will have a discoloration on the bottom.
Replace and replace ALL of the caps on the upper left side of the board. It's OK to replace with a higher value Voltage, they must be the same uf value of equal or higher voltage. They must be electrolytic caps (+/-). Make sure the line up the - properly with replacing. Radio shack may not have all of the them, but other electronics supply place should. They are call fairly common.
If you have never done this before, find someone that has, or find another tutorial on how to do this. You will need a small soldering iron and solder ****** and very thin solder from Radio Shack.
Replace the board, we tested by putting the board back. Sliding the TV on a table so the top could be seen and then plugging a source in and verifying it worked before reassembly. You HAVE to have a component source plugged in or it will false positive the test. We found this out the hard way....
Replace the back and the screws. On the right side of the TV MAKE SURE that the AC power wires are NOT in the way the screws on the right hand side.
Replace the TV to the original position and test....
Reason for Problem.
Either they have a flaw in the design, but more probably they had a poor supplier of the Capacitors. I have seen this before and we will probably see it again. This really should be some sort of class action suit since they are all failing about 1.5 years of use.
Any question, please contact me....
orthober@msoe.edu
Jeff Orthober, Assistant Professor, Milwaukee School of Engineering.
Posted on Oct 11, 2008
AKAI 48 in. LCD HDTV with bad signal board
Option 1
The web site shopjimmy.com has tons of parts for your TV.
I looked through it and they don't have a signal board right now.
It's the best place I know to find the parts you need.
Sooner or later, they should acquire one.
Option 2
Fix the signal board.
Try to find a SERVICE MANUAL for your TV on the web. This manual will have parts list, schematics, and test points for circuit boards for your TV.
A electronic tech should have no trouble fixing it.
Good Luck
Feb 21, 2009 | Akai LCT42Z6TA 42 in. LCD Television
Fuzzy picture on my 42" akai lcd tv
Check the menu ,,it should have a option ,,called convergenge ,,that realigns the colors,, and some tvs have geomagnetic correction,, good luck
Oct 05, 2008 | Akai LCT3201AD 32 in. LCD Television
Picture but no sound on Akai 26 in flat screen
Did you fix this yet?Please let me know.Thank You very much!
Tyler
Feb 19, 2008 | Akai LCT2660 26 in. HD-Ready LCD...
Akai LCT3201AD 32 in. LCD picture stretched around the corners
This set has several differant aspect ratios, could you have unwittingly change it to a zoom or expand by mistake?
Feb 07, 2008 | Akai LCT3201TD 32 in. LCD Television
HDTV?
HD ready?? NO - - Compatible? Yes but you'll need the converter.. The US post office will be giving away coupons for the converter. Google search the HD converter issue and you'll have a wealth of information.
Bill
Feb 03, 2008 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Akai LCT 32"
Do you still have this TV?Sounds to me like a bad capacitor,or two.I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
Tyler
Jan 03, 2008 | Akai LCT2660 26 in. HD-Ready LCD...
No power
Tyler
Dec 26, 2007 | Akai LCT2660 26 in. HD-Ready LCD...
No power problem.
Tyler
Oct 19, 2007 | Akai LCT2660 26 in. HD-Ready LCD...
No picture but has sound
leaky jungle IC. if your not enclined with this job. contact a certified technician on this matter.
May 04, 2007 | Akai LCT2660 26 in. HD-Ready LCD...
Akai PDP-42TD1 42 in. EDTV-Ready Plasma Television Logo
219 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
