Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Model No. KV-DB29M80 Serious colour & sound problem since day the set was installed. Sony technicians could not solve. Initial requests to replace were not heard by the representatives of Sony Service / Customer Care. Now they have taken back the TV Set. We as customer insist that the set should be replaced since it is inherently defective. It is a matter of customer satisfaction and reputation of Sony. C R Ghosh email: cr_ghosh@hotmail.com
5 Suggested Answers
  • 5 Answers
SOURCE: KDF-55W655
red light blinks in 5 times then pause and then repeats. It is the lamp error. " Lamp Driver Defect"
When the "LAMP-PORT" (pin 95) is low, the lamp is not turned on. If the "LAMP-HV-DET"(pin 96) is low at the same time, it is classified as no high voltage of the lamp driver. I'm guessing it needs a Lamp driver which I think is on the C Board, which is part of the "Optics Unit Block Assy. The C Board cannot be orderd separately, and Optics Unit Blocks are not cheap. Good luck
Bobby G aka poolmvp1
Posted on Jan 02, 2008
  • 586 Answers
SOURCE: Standby indicator light on TV flashes - Sony TV
    Please check fisrst that indicator liight (LED) blinks how many times.it could be from 1 to 8 times and the interval would be of three seconds.So, count the led flashes how many times and then tell me i will try my best to find and fix the solution.
Thanks
Posted on Nov 19, 2008
  • 178 Answers
SOURCE: KDS-R60XBR2 power led blinks 4 times,
There are three fans the one that usually fails is located on top of the optical block and cannot be reached by the owner unless you take the set apart yourself. What is happening is that one of the fans are not spinning fast enough or has stopped altogether. The best solution is to replace all three fans cleaning may not be enough to get a slow fan up to speed, and the tech should blow out the dust in the duct work. This is what the tech coming out will (or should) be doing. Also some fans will have an intermittent startup, and cause this intermittently, so it is a good idea just to replace the fans instead of just cleaning them.
Posted on Sep 02, 2009
  • 4234 Answers
SOURCE: Sony - KP61XBR48. I need to know a model of the replacement Lamp
First of all, there are no lamps inside this set, there are CRTs. These are not just replaced as lamps would be. The CRTs themselves will run at leas $80 each. To change these will require replacing the coolant for the CRT as well which is not a DYI type of job. The coolant is dangerous and needs to be handled carefully. Also, once a CRT is replaced, a complete mechanical and electronic convergence adjustment must be made. There is a specific order in which to do this that is outlined in the service manual and it requires a template that would need to be purchased as well.
Unless there is a specific problem that needs to be addressed, it is unlikely that any of the CRTs needs to be replaced.
If you are having a problem with the set, can you please update this with a description of the problem? We should be able to assist in the resulution of the problem with something less drastic than CRT replacement.
Thanks,
Dan
Posted on Nov 20, 2009
Testimonial: "Very informative and fast reply"
Sony kv j14l1
If there is any blinks occurs to standby power LED during switch On, and the set switches off automatically?
Jun 01, 2013 | Televison & Video
I have a tv sony trinitron model KV-32FX68E 32''.
try to plug the tv to other socket that is working before suspecting the tv set
Jul 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hi,im a technician and i got a problem with a Sony Trinitron Colour television model Kv-T29mn3. I replaced an Str, capacitors & Horizontal Output Transistor. Voltage output its okay but it keeps on...
These sets had alot of problems with bad FBT flyback tranfomers,You might need to change FBT.
Heres another thing they also had Bad Picture Tubes that will blow hori output and you will not know its the Tube untill you replace the FBT.Use a high voltage probe to monitor Voltage coming from the anode button, if you dont have a HVP then disconnect the CRT board and monitor set.
Jun 26, 2011 | Sony KP-57HW40 57" Rear Projection...
My SONY KV-XF21M80 produce a hissing (sparking) sound
That model number is not correct. What is an EHT? Must mean HVT High voltage transformer. If this set is 26 inch or smaller replace it. If larger yes replace the transformer.
Nov 23, 2009 | Televison & Video
KV-36FS200 WEGA Initial Setup Annoyance
hello my friends i beleive that you have some loose connections on the main board around the eprom
good luck
caypianan@yahoo.com
Aug 20, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony KV-27FS100 does not respond to remote
Good day.
Maybe there are loose connections along the IC that supports the operation of your remote. This could also hamper initial set up operation of your unit. Also, check on loose connections along the power supply.
Chris
Mar 02, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
The "Initial Set Up" Box continues popping up and will not go away despite auto programming
Sounds like you are skipping a step....consult owners manual
for procedure...if missing manual,download a copy...google Sony tv owners manual..............................T.
Jan 09, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Vertical fold over
if the set has a previous vertical line problem and a white horizental line only comes in the cross of the screen and you turned the tv on for a time while the problem is solved that mean you have make a burnt line to the screen , but if you are the tv owner and nothing of that happens so you have a problem in faulty dried capaciter in the vertical live part search for 33uf 160 v or 22u 160 v and alter regards please don't forget to rate thx
May 01, 2007 | Sony KV-32S45 32" TV
Sony Tv 29 Inchs, The Picture Keep Swiching off and replaced by fable shadowi pinky multi colour light
Your symptom description is a little vague. Is there sound? Is there a full screen? Assuming there is a full screen and sound I would look for bad solder joints on the boards. Particularly the CRT board but really just resolder all the connections in the set. The KV series has been plagued with more than their share of bad solder joints. Give this a try first and if this doesn't solve it give us a more detailed explanation of the problem. Good luck.
Jun 17, 2006 | Sony KV-32S26 32" TV
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
