I'm thinking it's a connection problem with the wiring because this has happened before and it would take some opening and reclosing of the door to jostle it around to suddenly make the light come on. I've pulled the dishwasher out a bit and looked at the wiring and nothing seems to be out of place or corroded. Thoughts?
SOURCE: Maytag MDB9100AWW Dishwasher
We have this same model. Right under the 5 yr warranty mark, the control panel started going "funny". Some of the buttons stopped working, then more. We could finally get it working only in one mode. I was certain it was the control board, which I replaced under warranty just in time.
This lasted another year, until moisture began appearing under the number window and the left side button set stopped working. Now the right side is gone, except for the delay-start button.
I believe moisture is getting into the control board and frying it, either slowly or quickly. If you are seeing similar problems where buttons seem to stop working, it is PROBABLY the control board. It is a relatively easy home repair if you know your way around a screw driver.
SOURCE: dishwasher not draining completely
If you take the toe panels off and look at the motor you will see the discharge anti-siphon tube there with the drain hose attached. That tube is the discharge major restriction point. Be careful not to destroy the anti-siphon valve, by pulling the bale, remove it, a flapper valve. If you can't see through the tube you have found the problem. Punch a screwdriver into it to dislodge the crap and clean it up. Put the anti-siphon valve back in as found and check it out. Be careful, when you remove the tube , water will come out of the pump assembly. If you remove the hose be sure to watch for water there also.
SOURCE: Frigidaire Dishwasher CL error light
sound as if your having an issue with the latch not closing properly( switches not making contact inside) yo can take apart, requires dropping the front panels and checking the switches, or replace the entire switch costs about 60 bucks part number 154529403 (black handle)
SOURCE: Maytag Dishwasher Doesn't Start
on a dishwasher an ohmmeter is almost useless. the best way to check is to look for voltage. at the door switch check for voltage to ground on both sides. if you have 120 on both sides of the switch then follow the wire over to the control board. if you have 120 going into the control board and nothing coming out of the control then you nood to start looking for a broken neutral. however the likelyhood that its the control panel may be a better idea especially if you are hitting buttons and nothing happens. try reseating any ribbon cables
SOURCE: Frigidaire Dishwasher won't start
hi there,
as u said that u have already replaced the timer u may also try the following:
Power from the house
Is
there power getting to the dishwasher? This can be difficult to test,
because dishwashers are usually wired directly to an electrical
circuit, rather than plugged into the wall. But at least check for a
blown fuse or a tripped circuit breaker.
Door switch
The
door switch is important because, if it's defective, the dishwasher
won't work at all. To reach it, you need to remove the control panel
cover, or sometimes the interior liner of the door. If it's defective,
you need to completely replace it.
Wiring
Often
the main wiring connection from the house, at the dishwasher, burns and
breaks the connection. If that's the problem, the wires must be
repaired/replaced as necessary. If that's not the problem, check the
wiring to the door switch, the wiring between the door and the lower
part of the dishwasher, and the wiring to the timer. Repair any broken,
burned, brittle, or defective wiring, using the proper appliance-grade
wire and connectors.
Hello - Are you referring to the spray arms will not rotate? If so, do you noticed if the spray arm is cracked or broken? Will it rotate slowly? If so, you might have to remove and replace the spray arm assemblies. I will suggest verifying that there is enough water pressure coming into the unit. If any proves to be ineffective, it could possibly have a communication problem coming from the main control board or wiring connections to the dispenser, I would suggest contacting a professional technician to diagnose the unit accurately.
