Question about Dymo LabelWriter 400 Turbo Thermal Printer
Keeps spitting out three labels at once - Dymo LabelWriter 400 Turbo Thermal Printer
Tv keeps shutting off
that's an overload protector clicking off. take it to a tech and get it tested. you're not going to be able to fix it yourself if you had to come here to find out what's wrong.
Open the back, spit in it three times, and bang it once really hard. That should do the trick.
Jan 24, 2014 | Panasonic Televison & Video
Zm400 just keeps on spitting out blank labels even after a hard restart
It's possible the labels are not loaded correctly and are missing the label sensor. Be sure the labels are loaded all the way to the left, if you are looking at the front of the printer.
Jun 16, 2011 | Zebra ZM400 Thermal Label Printer -...
My datamax printer keeps spitting out 8 labels everytime i hit the feed button or print something
It is the media sensor. Try adjusting and check for stuck labels in it blocking the sensor.
Jul 21, 2010 | Datamax Prodigy Plus Thermal Printer
Blank labels keep feeding out
Disable start up calibration maybe?
May 09, 2009 | Zebra 105SL Thermal Label Printer
Spits out multiple blank labels and reports a printing error
I just fixed my coworker's Dymo, which had the same problem. I hope this helps: if you've ever fed it labels in the wrong direction (upside down), you may have jammed it and left a piece of a label glued to one or more of the sensors that let the labelmaker know it's finished printing a label.
1. Disconnect your labelmaker
2. Disconnect/remove any unused labels and set them aside.
3. Remove the face plate (with the DYMO LabelWriter 400 logo)
4. Lift the gray plastic lip (labels go under this) and make sure there are no pieces of paper/labels in there.
Once I removed a piece of an old label and put the LabelWriter back together it started working well again.
Sep 23, 2008 | Dymo LabelWriter 400 Thermal Printer
Zebra 2824
if you see that it is like printing a card. check your thermal print head maybe its not working.
Jun 23, 2008 | Zebra Eltron LP 2824 Thermal Printer
TLP 2824 don't print
Only one suggestion, do a memory dump, switch off the power switch (should be back corner of printer) , hold down the green feed button, power on and watch the feed button, take Your finger off it after the third flash.
Leave it for a moment and press once more, it might say something on the label like out of dump. Try a label again.
Do this two or three times if it still acts up.
After this all thats really left is to clean it with an alcohol swap or check settings in the program You're using
Some times they cant store the amount of print jobs being sent to them and the zebra just freezes up or spits out labels
Apr 08, 2008 | Zebra Eltron LP 2824 Thermal Printer
Printing blank labels between and after printing tags
your printer needs to be calibrated and set label lenth in the driver in both printer preference and printer defaults
Jan 16, 2008 | Zebra Eltron TLP 2742 Thermal Label...
Spits out label but cuts words off
Problem is solved by pressing the function key until "margin" comes up. Then press function key again while "margin" is selected. Use the arrow key to select the "###". Then once that is selected press the function key again. That solved the same problem I had. Good Luck :)
Apr 15, 2007 | Brother P-Touch 1180 Label Printer
Dymo LabelWriter 400 Turbo Thermal Printer Logo
59 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Marvin
Marvin
Jose Pino
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
