The picture is skewed on the sides? How do I align guns?
    Scholar:
  • 155 Answers
It is not easy to align the guns without proper expertise and tools. its highly not recoomended.
may be there is some very high magnetic fields like speaker or an low voltage adapter or coil that  is interfering. check
Posted on Jul 03, 2009
How to check transmission temp sender on 1992 w350 dodge
How to check the Transmission Fluid Temperature Sensor. There is a reason for it. The sensor can skew ,a skewed sensor will mean either the computer thinks that the fluid is either too cold and thick for shifting or the computer will want to go into hot mode. Hot mode means no OD. Overdrive. Overdrive means no mechanical coupling.
Use an infra temp gun. There are two windows to a typical gun. the top window is the laser. It gives you something to point with. The bottom larger window is the infra red. This is what actually takes the temperature. Temp guns are getting cheap.
Place the gun on a hot transmission cooler line and compare the reading to the gauge.
May 16, 2014 | 1992 Dodge Dakota
When printing pictures, I use the photo paper mode, but the pictures come out blurred and skewed. The Printer makes a lot of grinding noises.
I would say that your printer ink heads need to be alined, in the software that was provided with your printer, select align printer ink heads.
Thumbs up!!!
damnor01
Nov 07, 2010 | HP PSC 1210 All-In-One InkJet Printer
Picture caves in on the sides
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 02, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Print head seems to be out of alignment. Lines of print seem skewed and blurry. Edges of pictures are not in alignment.
Run the alignment in the maintenance software. Each new print head must be aligned.
Possibly release and remove the print cartridge and reinsert it. Maybe it is skewed.
Mar 21, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Hitachi 65F59 65-Inch CRT Projection HDTV picture skewed.
The convergence output IC's have failed and need to be replaced. Sometimes when they go biasing resistors burn open also. These are large amplifiers mounted to heat sinks and have as many as 18 pins soldered into the circuit board. Better be handy at desoldering even if it's only the IC's that are bad.
Jul 10, 2009 | Hitachi Televison & Video
Skewed picture
you need ned convergance chips
Mar 22, 2009 | Mitsubishi VS-60621 60" Rear Projection...
Blue Projection Gun
It is not the gun ,but the convergence IC that needs replaced providing that you have went into the tv menu and selected convergence and manually adjusted the blue convergence.
Sincerely the Hammerman
May 14, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Ts-4557
easy way to adjust the convergence is, first off blue back option. Then check snow on the picture., if each snow carries any color on side. adjust convergence till color disappears. take long time but it is very easy no need other equipments
Feb 08, 2008 | Mitsubishi TS-4557 45" TV
Red convergence is bad.
Hi, you need to change the convergence ICs , STKs: and some resistors,low values; , after changing them, you will have to go into the service mode, to do some adjustments.that's it.
Nov 27, 2007 | Samsung HCN4226W 42" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
