I have a GE HC39GE242A going bad. Can I replace it using a GE HC39GE242 motor?
SOURCE: I thought the blower motor
It could be a bad thermostat. remove the front cover, take a jumper wire from r to g to see if the fan will come on, if does then its the thermostat is bad, if don't, then the fan circuit board is bad.
SOURCE: AC condensor fan motor replacement
one wire goes to the coil one to the capacitor and one line
SOURCE: replaced a one speed 230volt 1 phase electric
Look at the old motor and see what the rated rpm was. Next look at the new motor and see if it gives a speed for each wire. If it doesn't give the speed for each wire then look at the rated motor speed. That will be the Hi speed. Hook up the wire that matches the speed of the old motor and cap the other.
SOURCE: Rheem condensing unit fan motor
Could be the fan blade is the issue for vibration. Perhaps the blade was bent or somewhat damaged during failures or during the fan motor replacement process.
Might try replacing the blade. Be sure to install the correct blade. Pitch, number of blades as was on the original unit. If blade was replaced previously, the new blade may be pitched or sized incorrectly.
