Question about HP Pavilion DV5-1000US Laptop
Dv5 screen housing diassembly
Does anyone have pictures or directions or a link that would offer help? I'm looking to replace a a faulty LCD cable that runs from my video card through the hinge to the LCD screen itself inside the screen housing, i don't see any screws or ways of dissaembling the housing. any hints would be awesome!! thank you!!!!!!
  • 1,056 Answers
I have taken apart several laptops, incuding an hp. usually the pastic cover pops off. the you will see the screws underneath.
Posted on Jul 03, 2009
  • 37 Answers
Hey I think this is what you looking for
http://www.youtube.com/watch?v=6eorC7BI7JY
Also this is one of my favorite laptop repair sites. I suggest you check it out
http://www.laptoprepair101.com/
No HD pic on Samsung HP-R5250
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | Samsung HP-R5052 50 in. Plasma HDTV
I have hp pavillion dv 2000 laptop. from yesterday its not booting up .All i see is the multicolor vertical lines and slowly getting dark and i cant see anything else.
its the problem of the LCD screen in your laptop.
either the screen is got loose or the LCD screen is got faulty and needs replacement.
there are many other users facing this same problem of vertical lines on the screen .
please click on this link above directly
http://www.laptoprepair101.com/laptop/2006/08/17/bad-video-on-lcd-screen/all-comments/
in the link there are few examples mentioned with pictures to detect and rectify the problem.just click on the link directly and check out . the model and brand of laptop shown in the link is bit different from your brand and model.but that is just an example and the instructions will be applicable to all brand/models of laptop.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Jan 10, 2010 | Office Equipment & Supplies
Guide on how to replace laptop screen hp dv5
Is the LCD screen cracked?
If the screen is blank or has a very dim image then the fault could be a faulty inverter which supplies high voltage to the CCFL lamp or the CCFL lamp is faulty.
A replacement inverter and or CCFL lamp is cheaper to replace than the whole LCD screen. Check out LCD Parts for service, parts and DIY info - click on this link to their WEB site ; -
www.lcdparts.net
Oct 21, 2009 | Computers & Internet
HP Pavilion dv5 laptop screen keeps blacking out. I have to move it back and forth to get the screen to come back on... sometimes it takes a few minutes to get it in a position where the screen appears...
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 03, 2009 | HP Pavilion dv5-1250us Notebook
Monitor flickers goes out then comes back
Check out
www.lcdparts.net
Jul 10, 2009 | HP Pavilion dv5-1125nr Notebook
No display in my lg shine cu720
What happened in the first place to make your lcd screen go out? there is a chance that the problem was not the screen, but the phone it self. did you drop it in water, or jus cracked screen?
Jun 10, 2009 | AT&T LG CU720 Cell Phone - Silver
My htc screen shows only thin vertical lines, how do I fix this?
it might be a faulty flex cable connector inside the housing or the LCD itself is faulty u have to replace it
Feb 11, 2009 | HTC Touch P3450 Smartphone
F-417 working inconsistently after power fluctuation/outage.
You may want to check the VIDEO cable that goes from the monitor to the computer. Make sure its in tight. If the montor still continues doing this, it could be caused either by A) a faulty monitor, or the monitor is going bad B) the video card inside the computer is going bad. If you have another monitor in the house, try it and see if you have the same problems. If you do it's most likely the video card inside the comptuer going bad. If you don't, then replace the monitor. Was the monitor plugged into a surge protector? Let me know how it turns out... THANKS
Dec 20, 2008 | Neovo F-417 17" LCD Monitor
Touch Screen Creacked, but LCD is fine.
Hi Parvinder I suggest you replace the touchscreen though the procedure is not easy but I can provide you the instruction for how to replace it. If you can follow carefully the instruction of how to replace it, you will have a nice screen again. Please send your email to my address below: joe_dao2003@yahoo.com I will reply to you the full instruction written by me included of how to diassemble the unit. This model is also called audiovox xv6600, Siemens sx66, Qtek 9090.. but thet has the same housing with some modification but my Service Guide can be applied for all. You can buy the touchscreen only on Ebay for $19.95. Regards, pingping
May 22, 2007 | Orange SPV M2000 Pocket PC
HP Pavilion DV5-1000US Laptop Logo
183 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
