Question about Samsung CLP-300N - - color - laser - Legal, A4 - up to 16 ppm / up to 4 ppm -... Printer
Black colour doesn't print well, it is greyed and irregular
    Champion:
  • 220 Answers
The black deveploment roller is worned out on the drum,common problem.need to replace.
Posted on Jul 03, 2009
How do you fix the colour printing grey instead of black
Do you need to change out your black color cartridge? Check your ink levels to make sure that you have plenty of each color. Also, check the settings for your printer (perhaps under "properties") and make sure that you haven't clicked on "grey scale". I hope that this helps.
Jul 15, 2014 | Xerox Phaser 7400/N Printer
Have a label with colours of gray and black. Toshiba B-SX5T printer does not print the gray colour very well at all. Shoppy print of areas on the label that are gray. Printer issues?
You must either modify your graphics or try another driver ou driver options.
Take care that this printer only print black dots and the grey is obtained by not printing all the dots.
With some algorithms the grey color is not correctly interpreted.
Sep 09, 2013 | Toshiba B-SX5T Printer
Why cannon ip3000 can't print in only black and white although I choose grey scale priting?
Not sure of the QUESTION..? Do you want to print colour or black and
white..? Anyway,try this, bring up image , at top left click on Fix , at top
right click on Auto Adjust then go down to Adjust Colour click on and
hold Saturation Slider move to left to remove colour ,right to add colour
go to print and it should give you a black / white image. Remember to
return image back to original colour or image will return to file in b/w
hope this works for you..goodluck...T.C.
Mar 31, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
Hp officejet 4255 black colour print not very clear
Select print in grey scales only in printer properties while shooting the print command, printer is using color cartridge instead of mono cartridge..
Jan 11, 2012 | HP OfficeJet 4255 All-In-One InkJet...
I can't print in grayscale with my colour cartridges
The black ink cartridge is used to print in grey scale mode.
It is therefore not possible to print in grey scale using only colour ink cartridge.
damnor01
Apr 11, 2011 | Dell 810 All-In-One InkJet Printer
My Xerox 8400 is printing the wrong colors. Where it's red, it's printing a brown shade and where it should be grey, it's printing green. My logo is grey and red and it's printing all grey, but not the...
Try printing a light stripes test page (Troubleshooting, print quality problems, troubleshooting print quality page).
If you do not appear to have many missing jets but the colours are all just wrong it may be that the ink has gone stale. Run a couple of head cleans and you should see the colours start to improve. If it is getting better, all you can do is keep running head cleans until you have replenished all the ink in the printhead well.
This problem is common in situations where a lot of black and white printing is done, with very little colour.
Alternatively, it could be that your wiper/cleaning blade is not cleaning the head properly and is smearing the different coloured inks across the head, or possibly that your printhead is leaking colours but I think the first solution should solve your problem.
Hope this helps.
Dec 09, 2010 | Xerox Phaser 8400 Laser Printer
When using the 520 cartridge it prints grey. after cleaning it prints black for only so long then reverts to grey
you are either just about out of black ink in the 520 or the cart is not flowing properly for some reason. The "grey" print would be the mix of colour inks that these printers lay under the black to make the print "blacker".
If cleaning etc doesn't help, replace the black cartridge.
good luck with it
LC1000
www.inkbank.com.au
Dec 03, 2010 | Canon PIXMA iP4600 Color InkJet Photo...
Prints in faint grey only, no real black
dear sir.
it's not a pritner problem. u need to chek word font's and font's colour setting but it's depand witch version u used and if every print are printed on faint grey colour yr refill cartige has a problem.. also do one thing go to pritnter setting do as grayscale. if u have any quary tell me..
May 04, 2009 | Canon PIXMA iP1800 Printer
Black colour ?
Thats because it's using the other colours to mix what it thinks to be shades of grey. Due to the black ink being pigment based and the colours inks dye base, when printing onto glossy paper the machine will use the colour dye based inks to make up black.
If you were to print on plain paper, set to greyscale, then the machine will just use the black as the pigment ink sits onto of the plain paper and will not run should the paper get wet.  With glossy paper the ink has to be absorbed into the paper ad the Black pigment ink will not do this so the machine will use the coloured inks.
Sucks but true.
Aug 06, 2008 | Lexmark X3480 All-In-One Printer
Grey & Black Printing on everything
it appears that the printhead has a problem. try cleaning the printhead, via software. usually in printer prefs. also try running a few test pages. to see if you have any colours at all. if it,s only printing in grey scale. i.e grey-black. check the colour cartridges ink has,nt run out or blocked the nozzles.
Hope this helps Mike@Compurepair.
Feb 20, 2008 | HP DeskJet 9800 InkJet Printer
Samsung CLP-300N - - color - laser - Legal, A4 - up to 16 ppm  / up to 4 ppm  -... Printer Logo
66 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
