Question about Canon imageRUNNER C3220 Color Copier
I am shutdown ir2800 but late start - Canon imageRUNNER C3220 Color Copier
  • 1 more comment
  • azamesbi Jul 07, 2009
    Ok My Machine Problem Ir2800 Canon
    Slow Start and slow Indication and sloow Copy
  • Jay Otaigbe
    Jay Otaigbe May 11, 2010
    Sorry but please explain more about this problem. Are you saying it takes a long time to warm up? A long time to print? Or a long time to copy the first page? Please write a little more about this problem to help us help you because you have not said enough
  • Jay Otaigbe
    Could you be a little more detailed about your problem please?
    Problem Solver:
  • 13 Answers
Hi, usually, if an iR22/28/3300 is very long to boot, to copy or to print, i watch for a faulty Ram module or Hard Disk. Try another Ram module from another similar copier if you can.
Regards, Mug.
Posted on Jul 07, 2009
Slow shutdown
After click the Shutdown butten . Go to start , type regedit, in the run box and press Enter and in the left pane navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet and click on the Control folder. Look for WaitToKillServiceTimeout, right-click it and choose Modify. I suspect it's stored in milliseconds, in which case 3600000 represents 1 hour.
Test it first, set to, say, 5 minutes (30000
If this didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of late shutdown
Oct 05, 2013 | Sony VAIO VGN-N320E Notebook
Hp laptop won't shutdown
Could you be a bit more specific? Could you tell me the correct sequence you spoke of? I am trying to understand , you shut down using the windows 7 shut down and it re starts? Your response didn't clear up my confusion. I can remember ever encountering this. Just a thought have you done a Maleware scan lately? If not try MALWAREBYTES found at : http://www.filehippo.com/download_malwarebytes_anti_malware/Install and Run a FULL SCAN and a program CCLEANER found at : http://www.filehippo.com/download_ccleaner/ Install and Run, it's a good program to clean the junk files out and speed up you system. That a good place to start.
Nov 08, 2012 | HP Computers & Internet
How do I clear error code E000003-0000
ppress additional functions, 2 and 8 then additional functions again
Go through the following to clear the error: CLEAR >
ENGIN > ERRCLR; and then turn OFF and then ON
I think, I dont have an ir2800 manual. This is an error in the fusing section, so it may come back and require some parts replaced.
Oct 21, 2011 | Office Equipment & Supplies
My sony viao vgn-cs215j suddenly turn off by itself and it takes 20 minutes before i can re-start and use it again and after 15-20 minutes would shut off by itself again without any warning. what could be...
Sorry i nay be a month late on this thread... but better late than never. My Girlfriends sony vaio VGN-CS215J seems to be doing the exact same thing. After buying one of those computer fans that you rest the computer oneverything seems to be running normal. i would also recommend cleaning your fans inside the computer because dirt dust and grime can hold the fans back from cooling down the laptop efficiently and will cause the safety overheat shutdown to activate and shutdown your computer... that way it does catch on fire or fry any of your hardware inside of your computer.
If that does not work... your fans maybe malfunctioning or not functioning at all. this model of vaio has a grinding fan issue that can be very damaging to your cpu if not fixed.
hope this helps,
Mike Huffstutler
Apr 06, 2010 | Sony VAIO VGN-CS215J/W Notebook
Canon ir2800 is hanging after 2\3 copies what to do ?
How is it hanging.... What is wrong with it? Is it jamming or coding out? If it jams make sure the paper tray's are set to the same direction and size of paper in the paper tray. The knob for paper size input get's moved by the "Knob Mover".... Good Luck
Feb 28, 2010 | Office Equipment & Supplies
Acer t310 fan runs when shutdown
More than likely the cpu is still hot even after you shut off you computer, so as a saftey precaution the fan is trying to cool it down,(which is a good thing).
Jan 06, 2009 | Acer Aspire™ T180 PC Desktop
Automatic shutdown
You either have two issues . The heatsink Fan needs replaced ( it will shut down to save you from burning out the chip ) Or possibly the power supply has an issue . More than likely is the Fan for CPU .
Please make sure you mark my correct solution for your motherboard
Thank you
Aug 05, 2008 | ASUS M2N-MX Motherboard
Trouble with garmin 660 GPS
My Garmin 660 after going thru the initial start up of "loading map" it will just SHUTDOWN. I have tried to clear the data in the diagnostic menu as recomendated by Garmin support to no avail. At the start, the trouble is it will just stay in the loading map stage. Then later it begin to shutdown.
Jul 14, 2008 | Garmin Nuvi 660 GPS Receiver
Canon imageRUNNER C3220 Color Copier Logo
76 people viewed this question
old marine
old marine
