Question about Samsung SCX 4521F All-In-One Laser Printer
Paper Jam message on every print job.
Every time I send a document to print the printer reports a "paper jam" error. There is no paper jam and all I do each time is remove the toner cartridge, put it back in, close it up and it prints one page at a time, then another error "paper jam" is reported. I hae to go through this every time to print one page at a time.
  • admin209 Jul 08, 2009
    I fixed it myself. I had to open the rear cover. In the centre just before the hot paper roller, is a black plastic lever/flag which goes up and down every time a piece of paper feeds through. It is spring loaded at the base. The spring had become dislodged from its holder. I just had to push it back underneath its holder so the "flag" can keep resetting itself every time paper passes through. Thanks for your help though.
    Problem Solver:
  • 19 Answers
I have the same printer without the doc feeder. Check the paper trail thru the printer for the paper sensor lever hanging up. It gets pushed up by the paper and can stick, making the printer think it still has paper in it. Pulling the cart unsticks it till you print again.
Posted on Jul 03, 2009
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
My hp deskjet says there is a paper jam when there is none and will not print
If your printer for any reason reports a paper jam, withput going through the "clearing paper jam" procedure it may not respond to print command. So follow the procedure below:-
Clearing paper jam in a printer is simple almost seven step procedure depending on the printer. Paper jam is the term used to refer to the scenario where your paper fails to come out of the printer during the print process. When you send a document to the printer, normally the printer prints out the document on a paper; then you can pick up your printed copy. When the paper gets stuck in the printer, it is said that paper has jammed in the printer "paper jam".
Even if you are not a technical person, you can conveniently clear paper jams. All you need is to follow the set of procedures outlined below.
Good luck & God bless!
Mar 01, 2011 | HP Deskjet 3845 InkJet Printer
Printer says Paper Jam but it is not
  1. Remove the paper from the paper tray.
  2. Press the Power button and then wait for the jam to clear.
    • If the paper jam cleared, try the print job again.
    • If the paper jam is not resolved, continue.
  3. Remove the rear access door. Press the handle to the right, and then pull out the door.
  4. Remove any paper that is inside the printer by pulling the paper out from the back of the printer.
  5. Replace the rear access door.
  6. If the paper jam cannot be removed from the back of the printer, raise the product cover, carefully remove the jam from the front of the product, and then lower the cover.
  7. Re-load the paper in the In tray. Fanning the paper makes sure that the pages are not stuck together.
  8. Press the Power button ( ) to turn on the product.
  9. Open the document in the application in which it was created.
  10. Click File, Print, Properties, Printing Preferences click Paper/Quality tab.
  11. Verify that the type of paper specified in the Type is text box matches the type of paper being used. A paper jam might result if photo paper is specified in the Printer Properties dialog box, but plain paper is loaded in the printer.
  12. Click OK to try job again.
Sep 22, 2009 | HP Deskjet D2360 InkJet Printer
Printer erroneously reports a paper jam
Perform a hard reset of printer and see if that clears up the situation. Also uninstall and reinstall drivers.
Sep 04, 2017 | Office Equipment & Supplies
Paper jam error after last page prints
Hi Natoli3,
This could be a mis-match of paper sizes. Example, computer could be sending an A4 page to the printer. The paper size in the could be set to Letter. Ensure the 4 paper sizes match, in the computer - the document and printer driver; in the printer (change in control panel) and paper tray (adjust the physical side and length).
S88
Oct 23, 2008 | HP LaserJet 4100 Printer
Paper Jam
hi y'all -
you share a frustrating problem... error message but no apparent error (jam)! it's one that's common to many models of printers and the result of many different causes.
I've seen it when I've printed on cheaper paper, or different (lower) grades with odd surface finishes. the sensors get dirty, or the printer/computer 'thinks' there's paper stuck where none exists. I've opened/closed paper trays 2-3 times and rolled feed rollers around multiple times, then closed printer paper drawers only to have the 3rd time of doing the exact same steps be the time it cleared the error message.
there are often very tiny pieces of paper stuck in weird places in the paper path in printers, too. if you did have a jam before the message started, is every little scrap of the page accounted for? there are also hard to get to places to find paper scraps in larger printers, but I'm going to assume you're all talking about home printers.
here are a few general HP support links you may find helpful for future paper jam messages for this model of printer.
this link is for general info for this model:
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&dlc=en&product=304535&lc=en&jumpid=reg_R1002_USEN
this link is for general support for this model:
http://h10025.www1.hp.com/ewfrf/wc/solveCategory?lc=en&dlc=en&cc=us&product=304535
here's a link addressing paper jams in general:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bud09189&lc=en&dlc=en&cc=us&rule=26353&product=304535
and here's one on cleaning your printer:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00016484&lc=en&dlc=en&cc=us&product=304535
hope this helps a little bit for future refs. remember that using good paper helps print quality and lessens printing problems. also, when you take a stuck page out of a printer, doing so gently will help ensure little scraps of paper do not tear off paper edges and get stuck in weird spots. it some times helps to gently, manually, roll the feed rollers a full turn around in the printer, too. patience pays! -JW50
Sep 02, 2008 | HP DeskJet 3650 InkJet Printer
Print Jobs from our IBM Unix System Reports creates Ghost Jams
The answer to our problem ended up being a firmware upgrade to the Canon iR7095. I would look into that as your possible solution.
Oct 10, 2007 | Canon ImageRUNNER 3570 Copier/Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
413 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
