Question about Whirlpool Duet GHW9150P Front Load Washer
I keep getting an error code that flashes F02
  • 5,911 Answers
"F02" is a Long Drain error code. The following link explains how to troubleshoot:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
The majority of the time, all you have to do to correct this problem is to clean out the drain pump reservoir or drain hoses. Follow the advice in the link provided. If all preliminary checks do not solve your problem, the manufacturer recommends replacing the drain pump. If you have questions, please let me know. I hope this helps you.
Posted on Jul 03, 2009
F02 Drain problem The drain hose has been checked, it's ok . Keeps showing F02 code. What's wrong?
HI There
Try this and let me know how that goes.
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Thank you for writing to fix ya.
Best regards Richard
Dec 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
It quits on the drain cycle and a error code f02 appears
Error F02 code means Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed. Solutions: Press PAUSE/CANCEL twice to clear the display.
Oct 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Getting f02 and suds error mesage
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• If the above does not correct the problem replace the pump
Sep 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
After f02 code came up ran a test and get c00 andhttp://www.fixya
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Sep 27, 2009 | Kenmore Washing Machines
Getting an 02 F flash
F02 Long Drain
Potential Causes
Aug 12, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
F02 code flashes and stops rinse cycle
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be disp NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the displaylayedPress PAUSE/CANCEL twice to clear the displayCheck the drain hose and make sure it is not plugged or kinkedCheck the electrical connections at the pump and make sure the pump is runninCheck the drain pump filter for foreign objects.g. If the above does not correct the problem, replace the pump.
Jul 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE3 front loader keeps getting F02 error message, most often when I wash towels. I was able to workaround by pulling half the load, but that no longer does the trick.
Long Drain
F02
Potential Causes
Jul 13, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Error codes
F02 Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Potential Causes
Feb 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Persistent F02 / SUD error. Tried all the tricks!
how about the line from pump to bottom of tank?not excess suds?might be bad control bd..f code is generated when control bd senses incorrect current draw by drain motor ..could be glitch in readings or a misread
Nov 02, 2008 | Kenmore 4292x Front Load Washer
F02 Error on Front Load Kenmore HE3
F 02 Is your key pad user interface that has failed. I would call back and get some free service from a different technician.
Oct 23, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
145 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
