Question about Toshiba 32HF73 32" TV
Rca tv 32"
I have sound but don't have any picture??? I know there was a solder problem with it but can you tell me were it is located
  • 1,694 Answers
First, verify make, model # and service # ............T.
Posted on Nov 10, 2007
Rca L32hd31 lcd no picture blank screen.
Your mainboard is damaged, replace it and that will solve your issue.
Jun 06, 2009 | RCA L32HD31 32 in. LCD HDTV
RCA 32V550T Nothing happens when you press Power. NOTHING.
This set needs a flyback transformer p/n 262342, and a horizontal output IC, location number on the board is q14401 and crosses to NTE2353. When you're in there too touch up any bad solder joints you can find. Fixed several of these with the same problem.
May 25, 2009 | RCA 32V550T 32" TV
My RCA TV Model F27442 has no picture
is it snow on screen? if so tuner  problems. rca had recall on tuners on some models bad solder connections in tuner
Dec 03, 2008 | RCA 32V420T 32" TV
Perfect sound, no picture - RCA F32649
if you know how to solder ,re solder your tv, but before doing that replace or used other RCA cord
Aug 09, 2008 | RCA F32649 32" TV
How much does it cost to remove and replace a power supply
my friend here in guyana to replace a power supply it is VERY expensive i don,t know about your country
May 24, 2008 | RCA F32648 32" TV
Look for bad solder connections on the solder side of the board: You have to take board out of the plastic and slides out. Look around the high voltage transformer pin connections and large transistor associated with it and all connections associated with it too. Use magnifying glass. Could be hard to see. You could also shotgun the whole section by just soldering all associated connections. Look for burned connections also.
Dec 27, 2007 | RCA F32650 32" TV
XBR450 32" - getting 1080i picture from upscanning DVD Player
You need 5 RCA cable wire (Red,Green,Blue+Red,White) comb RCA/Cable cords to flow back on the TV connector or review Manul books
Dec 13, 2007 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
No picture on screen RCA F32650
Well let me take chance on this one for you. Who is repairing this tv for you? ???????? Briefly this should work. First solder a jumper under coil #L14401 to R 14402 [100 0hm 1/4 watt resister] these have the same ground. Second .....solder a jumper [other end of same coil L14401] to the solder spot located between J and L...also the same ground. This is kind of tough to explain.Hint....This coil L14401 has enough of a leg on either end to solder to the nearest common junction ground. Unless you enjoy listening to old time radio.....this unit can be repaired. Take this note to the repairman and tell him how to do it!!!!!!!
Nov 14, 2007 | RCA F32450 32" TV
Rca 32v434t
went in the menu and blocked the panel buttons on accident
Oct 13, 2007 | RCA 32V550T 32" TV
Picture problems
You didn't say whether the screen is black or not. If you have a black screen you may be loosing horizontal drive. There is a small inductor (coil) which is in series with the base circuit of the horizontal output transistor which may have a bad solder joint causing your problem. You probably need to have a tech check it for you. A lot of RCA's have in the past had bad solder joints. Stargazer
Mar 02, 2007 | RCA F32649 32" TV
Toshiba 32HF73 32" TV Logo
44 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
