Question about Janome MyLock 634D Mechanical Sewing Machine
My serger I just bought a Janome MyLock 644D serger. Doesn't it have a self-threading lower looper?
  • Janome Master
  • 1,388 Answers
Re: My serger
Self threading is perhaps not exactly correct, however there is a guide with an armature to release the guide to enable easy access........have a look in you manual
Also take a look at this image and move the lever to use it.....all will be easier to see with the needle plate off ....until you become familiar with the operation
Posted on Feb 17, 2008
0 characters
3 Points
The tread from the lower looper is not being picked up by the upper looper how o i fix this?
Best advice would be to consult your owner's manual. The most common serger problems are caused by incorrect threading or not threading the threads in the proper order. With most sergers, the upper looper should be threaded first. The lower looper is threaded second and the lower looper thread tail should drape OVER the upper looper. Then thread the needles.
Be sure when threading that each thread is pulled snugly into the tension disks.
Nov 15, 2015 | Janome MyLock 644D
Do you have a picture fo threading the janome 644d serger. and my stitch is not right.
There are good instructions in the book. Do you need that to help? I have a PDF if you need I can email it. chrisatcentralsewingdotcom 25081632-ejanej2jom3nxm54rtob2gnh-4-0.jpg
Sep 08, 2014 | Janome MyLock 644D
My Janome 204d Serger won't form a chain stitch. It is threaded correctly. I have changed the needles??
I would suggest that you check the needles again, make sure they are both fully up into the needle housing. Also they should be at different heights in order to form the stitch sequence.
It is important that you thread the loopers first in the sequence shown in your manual, then the needles. So you may need to recheck the threading again and make sure the threads are in all the eyes correctly, especially the lower looper. Also some overlockers, have a sliding eye on the lower looper for ease of threading, if yours does, make sure it has been slid back to normal operating position.
When you have checked the threading up, take all four threads under the raised pressure foot and make sure that the upper looper thread and lower looper threads are not crossing over each other. Lower the pressure foot and try to chain off again.
I hope this helps you to resolve the issue.
Oct 11, 2011 | Janome MyLock 634D Mechanical Sewing...
I cut the chain thread by mistake, how do i get it back? Am new to this
Rethread the machine. Do the loopers first, then the needles. If you ever break a looper thread, you have to undo the needle threads, rethread the looper thread and then rethread the needles.
Apr 22, 2011 | Janome MyLock 644D
How do i uses a janome Mylock 534 or mylock534D for sweing? I cant even seem to thread the thing correctly, when ever i thread the mashine it only stiches for about 3 cms. must have the needles unthreaded any time you re-thread the loopers. So thread the loopers and then thread the needles and see if you have better results.
May 06, 2010 | Janome MyLock 644D
I bendt my needles, and after changing them it wont sew. the threads just come out without getting sewn together.. just 4 straight threads..
Once the thread breaks, the serger usually has to be re-threaded - all four components of the serger.
Raise the antenna to it's highest position.
Open the tensions to zero.
Turn the handwheel so the the loopers are at their highest position. Some sergers have a mark on the handwheel that aligns with a mark on the side of the serger for this step.
Thread according the the sequence indicated on the threading guide - this is either on the inside of the door or on the serger.
Mar 14, 2010 | Janome MyLock 644D
Here is a manual -
The thread guide should be inside the door.
Lift the antenna and presser foot. Turn the tensions to zero, if possible.
Turn the handwheel so the upper looper is at the highest point - there may be a mark on the side of the serger to align with a mark on the handwheel.
Begin threading from the right to the left, beginning with the lower looper.
Mar 06, 2010 | Janome MyLock 634D Mechanical Sewing...
MyLock 634D won't serge
Check that your lower looper is actually threaded and not tangled with the upper looper (needle thread) when it moves. I wish they'd include pictures in the manual how to lay the thread.
Apr 05, 2009 | Janome MyLock 634D Mechanical Sewing...
Janome MyLock 644D
Yes, the model I used had a self threading lower looper. Just put the thread into the guide and flick the switch
Nov 09, 2007 | Janome MyLock 634D Mechanical Sewing...
Janome MyLock 634D Mechanical Sewing Machine Logo
179 people viewed this question
Top Janome Sewing Machines Experts
Bargain Box
Bargain Box
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
