Question about Jensen XA2100 Car Audio Amplifier
I have a jensen xa2100, resistor r33 value
I have a jensen xa2100, i need the value on the resistor in the r33 spot, it burnt and so did my irfz44a mosfet, found one of those, just not sure what the r33 resistor value is.
  • theradioguy Jul 03, 2009
    I know the mosfet is bad, and the resistor in the r33 position is burnt in half, not sure what the actual value is suposed to be, I will have to get my dmm from work to check the other resistor in the same position on the other mosfet
    the only thing i can see is the burnt metel end caps, but i did chack the other resistor in the same position on the other mosfet and its color code tells me its a 100ohm, so I hope that the one I need is also 100 ohm as you sugested
How to hook up to car
Jensen might be able to provide connection details.
Jul 06, 2014 | Jensen XA2100 Car Audio Amplifier
Blown resistors
Both resistors are: 1/4w 100 ohm with 5% tolerance (brown, black, brown & gold colors). Best to use the "Metal Film" type because they're more durable than the "Carbon Film" type.
Feb 24, 2014 | Jensen JHT525 System
Can I get internal parts for this cd player?
It is possible you can get a schematic and parts identification from Spectra
Jun 23, 2013 | Spectra Hello Kitty KT2024A Stereo CD...
Hilti TE-5 burnt resistor value
Hilti should be able to supply that information.
Jul 24, 2012 | Drills
Pioneer sa-1050 2 burnt resistors, cannot read
where exactly are these resistors located? any idea about the circuit board resistor numbers? sometimes burnt resistors do not go completely bad and is still possible to measure their values. why not take them out and try measuring their values. otherwise u have to b very specific about the rsistor numbers
Apr 05, 2010 | Audio Players & Recorders
Amp repair advice
check on the board to see if there is a resistor that looks similar, 90% of amps amps are matched in there design, meaning the left side is usally a carbon copy of the right, so if you look at one side and there is a resistor that looks like it's in the same spot on the other side, good chance thats the same one, read the colors off the one thats not burnt up. resistors come in different wattages,1/8,1/4 1/2 up to 10 watts, each wattage is a different size, most of the ones you see in the amp are 1/4 watt but some are 1/2 and 1/8. some on the output are 2 to 5 watt, but those are generally 10-18 mm in length, they are big ones you cant miss those. so once you get the color code, read the colors, ex red,gree,brown,last line is either silver or gold, that will tell you the resitor value. then google resistor color codes and then you can match the color sequence with the value codes, and that will tell you the value you need in ohms but then you have to get the size 1/4 watt resistors are generally about 6 mm in legnth, im measuring the actual part of the resistor not including the metal leads, just the body, so if its larger its probally a 1/2 watt if smaller its an 1/8 watt, 1/8 watt are about 4 mm. now go buy the resistor, but you might find it that tough, if its a common value radio shack might have it, but resistors are so cheap, pennies for a handful, good luck on your search.
Jun 30, 2009 | Sony Car Audio & Video
Alpine MRP 200 could you pls tell me valu of
I don't have a schematic for your deck however, if the resistors you need are not burnt beyond visibility, this PDF should be alot of help. http://www.electro-tech-online.com/electronic-theory/42899-resistor-colour-code-values-chart.html Hope this helps
Jun 06, 2009 | Alpine Car Audio & Video
Burnt resistor
You have to check what could cause these resistors to be burnt. It might be because of caps or IC. Unfortunately, I don't have this type of circuit board. If you cannot find it, try with the same value of resistors that are placed close to these fault resisters.
Mar 16, 2008 | Computers & Internet
Jensen XA2100 Car Audio Amplifier Logo
327 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
