Question about Craftsman 10" Table Saw
Replace blade to replace yhe blade, what size wrench is it
  • 10,865 Answers
Go to searsparts.com, have your model number ready and you can order what u need.
Posted on Jul 15, 2009
How do I change the saw blade in a Teledo TKZ 205 Chop saw
Using a set of vise grips clasp the blade so that the pliars get hung up on the blade housing/protector. Then get the correct size wrench and remove the nut and washer from the blade and replace it taking care to install it on the right side for proper cutting.
Sep 02, 2015 | Saws
How do i change the blades on a 42in zoom z turn
raise the front of the mower to gain access to the underside where the blades are, using the right size wrench undo the bolt or bolts that hold the blades on and remove them from the mower, replace the blades and tighten the bolts to the required torque, lower the mower to the ground and take it for a test run.
May 19, 2014 | Ariens Zoom 42 In 165 HP Briggs Stratton...
How to replace cutting blade
Before ever touching the cutting blade remove the plug cap from the spark plug ( this is in case the engine should fire whilst turning the blade ), tilt the mower backward onto its handles, the bolt size for the blade is normally a 9/16 and will be a normal right hand thread ( turn bolt anti clockwise ) the bolt will be tight i would suggest a socket or if you have, or can borrow an impact wrench this will make things much easier, once off replace with a new blade, make sure the new blade aligns with any pins on the blade carrier conected to the crank, insert and tighten the bolt.
Feb 07, 2013 | Poulan Garden
What is the size of wrench needed to remove the blade on a bolen 22" push mower?
Probably about 9/16" wrench or socket to remove the blade. I have not done a Bolen, but I think that is the size for the push mowers I have done. If not that it will not be far from it, only a step one way or the other, but I think that size is fairly standard for pushmowers.
Aug 03, 2011 | Craftsman 55 Torque 158cc 22" Push Lawn...
How to change blades
unplug it. remove the bolt in the center of the blade. the blade will slip off then. a wrench for this should have come with your saw. if not, use any properly sized wrench. if needed, pull back the blade guard, put the blade on a old piece of wood, push down on the saw and use the wrench. the wood and your pressure will stop the blade from turning as you loosen the bolt
Feb 12, 2011 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Trying to replace the blade on my Craftsman edger; the nut holding the blade won't budge - now I'm not sure which way to turn it to get the blade off!! Clockwise? Counter-clockwise? Thanks. Larry...
Take a little break and spray the shaft where the nut is on it with some PB Blaster or Liquid Wrench penetrating oil. Let it soak tonight and turn it off counter-clockwise tomorrow. If you can fit a good sized box wrench on in, turn the wrench down towards the ground and give it a few good whacks with a rubber mallet or hammer. Try not to strip the head of the locking nut.
Oct 29, 2010 | Craftsman Garden
Replacing belt on troybilt TBE515 edger . After replacing belt blade will not spin when engaged. If i remove the blade the shaft does rotate.
Use a 15/16 open end wrench an correct size allen wrench. Loosen nut (15/16) ccw while holding allen. Geez how dumb are yawl?!
Apr 24, 2010 | Troy Garden
I do not have a manual for my mastercraft maximum 13 inch planer and would like to know how to remove the blades for sharpening
If it is anything like my 12 1/2 inch mastercraft planer you will need to remove the dust guide first, and then the drum with the blades will be visible. To remove the blades you need to loosen the bolts with the appropritate sized crecent wrench. Seems to be the only part of my planer that does not require an allen wrench actually.
Oct 20, 2009 | Tools & Hardware - Others
My handle is loose but I cannot find a tool that will fit the set screw. What is it, what size. Blade screw, Phillips Screw, Hex, torx, what? Moen T2442 single handle shower diverter.
It would be an allen wrench. Any typical multi sized wrench should have the proper sized allen wrench.
The holes can often become filled with grime so be sure to seat the wrench properly to prevent stripping.
Aug 07, 2009 | Moen & One Handle Tub & Shower Faucet
Need to change saw blade, lost instructions
1st, !!UNPLUG the saw!! Wear gloves to prevent nicks from contact with the saw blades.
If this is a handheld 'skill-saw' type saw, use a piece of wood to chock the saw blade from turning as you use a proper size socket/wrench to loosen the bolt which holds the blade.
The bolt will loosen counter-clock wise. It will probably be very tight, and you will have to use some effort to loosen it.
Remove the bolt, lift the follow guard and remove the blade.
Replace the blade with a like size diameter blade by raising the follow guard, inserting the blade, replacing the bolt, using a piece of wood to keep the blade from rotating and TIGHTEN the bolt. You will almost feel as if you need three hands to accomplish this procedure but its been done millions of successful times.
Good luck. :)
Mar 11, 2009 | Hand Tools
Craftsman 10" Table Saw Logo
81 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
