Question about Intertherm P3RA-048K Air Conditioner
I have 2 seperate controls ,1 for heat the old honeywell round turn styls and then i bought a new digital thermostat ritetemp and i have 3 wires for the airconditioner white,red and green, i just cant figure out how too hook it up it has so many pins in it give me some help please!
    Sergeant:
  • 340 Answers
On the round its r g w hook that on the new stat if your using it for heat to then the rh and w are heat controlling baseboard or a boiler relay? the new stat has a jumper wire remove that it is hooked up to rh and rc un plug every thing good luck Tom
Posted on Jul 03, 2009
Bought new thermostat model ct87k but old Honeywell model I have was hook up by black and white wire not red and white , so how do I hook up.
The two wire Honeywell T87 and CT87 is nothing but a switch in a control circuit. Wire color is not important at all. What is important is the TERMINAL DESIGNATION those wires are hooked to. Soooo....take the wire off of the sub base of the old stat terminal marked 'R' and attach it to the new sub base terminal marked 'R' and so on. Wire COLOR means nothing at all in your case.
Oct 04, 2014 | Honeywell CT87K1004 Round Heat Only...
Wiring with only 2 wires; which terminals to connect?
See RC and RH, RC is for cool, RH is for heat, you wire the red wire to the RH or red terminal ,either one will work actually but we generally switch the hot leg of power, W is the heat circuit
Dec 12, 2013 | Honeywell Electronic Programmable...
Ruud UBHC AC System - Provides no Aux Heat
Tried this on my unit today, and observed the same results, but got Aux Heat (with A setting), if the H (blue wire) connected to B terminal, as per instructions for my 6036 Ritetemp. However, in this case, when the set temp is reached, I hear the click, but HVAC still blows aux heat indefinitely.
I also have RUUD UBEA 17J10..., and replaced my old honeywell with 6036, and can't get heat pump working. Both of my units are 14 years old, so I'm thinking to replace them soon.
Jan 06, 2010 | Ruud UBHC Air Conditioner
Need wiring for honeywell pro 3000 in trane xe1200
the pro 300 is a single stage thermostat and can not be wired to control 2 heat stages seperately
May 16, 2009 | Heating & Cooling
Wiring of gas central heating
you have a link pin on 3-4 or 1-5 or seperate 2 pin connector,thats were the stat goes,any way round with wires
Mar 05, 2009 | Honeywell Programmable Thermostat Heater
Rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
Dec 28, 2008 | Honeywell Electronic Programmable...
New honeywell thermostat on new gas furnace not working
sometimes there's a differential setting anywhere from 1-3 degrees, see if you can make sure it's down to 1
Nov 12, 2008 | Honeywell Programmable Thermostat Heater
Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Oct 23, 2008 | Honeywell Electronic Programmable...
Honeywell T86A3006 24V Class 2 Round thermostat 8020
The honeywell tradeline thermostat would work as a direct replacement (no mercury in the new ones), however if your using just heaters and no cooling system off of it, you could Heat only thermostat from honeywell that would replace your unit as well. Both at available at Ace Hardware with the heat only unity being roughly 7 dollars cheaper.
Jan 14, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Honeywell therostat wiring help
Don't assume the wires at the thermistate are correct.
I had similar and had to go all the way back to the heat/AC controller board. I found the colors weren't attached per spec so was fighting the origional installation at the new thermistat.
Also some digital won't control mutizones proerly
Dec 15, 2007 | Honeywell Programmable Thermostat Heater
Intertherm P3RA-048K Air Conditioner Logo
373 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
