Question about HP Pavilion TX2000Z Notebook
MY computer boots to a blank screen, what happened? the background light is on but the vista startup screen doesnt come.
  • 152 Answers
Press F8 repteadly while restarting ..then start in safe mode ..
Posted on Jul 03, 2009
I cant log in to my computer Windows Vista (due to a failed system restore). Now when I go to the login it has a blank user named "other user". That happens in safemode, repair system, and...
You need to access the BIOS - press F1 or F2 (depending on the version)during the start of the desktop - and in there you must modify the boot order: put the cd first then the had disk second. Save the change, reboot, insert the Vista disk and reboot once more - the disk will be loaded.
Jan 03, 2011 | Gateway GT5622 PC Desktop
Sir i had bought sony vaio laptop which showing text; boot mgr missing and press ctrl alt del to restart, pls give me a solution
http://cyberst0rm.blogspot.com/2007/04/how-to-fix-bootmgr-is-missing-in.html
I assume you are running vista because bootmgr.exe is used to run vista from startup. "bootmgr" is short for boot manager, and without this, your computer simply doesnt know how to start vista from your hard drive.
To fix it is quite simple. First of all go into your BIOS menu (usually press F2 or DEL when prompted when you turn on your pc). Make sure your cd/dvd drive is set to be your primary boot device. This way you can run your setup disk in the next step.
Insert your Vista install disk and restart your system. Press any key when prompted to begin running the dvd. Wait for it to give you a list of choices. This may take a while as it often stays a blank screen for some time. Choose "repair", and the setup will auto detect your operating system. It will also fix your bootmgr.exe at this point. If it does not, you can go on to the next screen and choose "startup repair".
Aug 20, 2010 | Sony Tablets & eReaders
Fan shuts off on computer startup, led lights are
The fans are USUALLY controlled by the processor chip reading its internal temp and running fans as needed. Under the varying load during boot, it is not uncommon to have fans starting and stopping..
Nov 30, 2009 | HP Pavilion dv6000z Notebook
My Dell Inspiration Laptop passes all the system diagnostic tests but Vista does not load - just have a cursor on a blank screen. Is there any way to reload/revive Vista without losing data files on the...
If you have the original Vista DVD that came with your computer, try running startup repair on your computer using the instructions here:
http://www.bleepingcomputer.com/tutorials/tutorial148.html
If startup repair doesn't work, make sure you have not modified system files such as authui.dll. I happened to have the same problem once on my computer :)
Try running this command in command prompt using the Vista DVD... sfc /scannow
Aug 27, 2009 | Computers & Internet
Vista Black Screen after Startup.
Try booting into SAFE MODE, usually by pressing F5 or F8 just after turning the power on. This should give you a display. Once you can see your desktop right chick on a blank area of the desktop, select PERSONALISE, then DISPLAY SETTINGS to reduce the screen resolution. Then reboot and try again in NORMAL Startup
Jul 27, 2009 | Microsoft Windows Vista Home Premium for...
Blank screen during POST and vista startup
The screen is going bad. Take it to a reputable repair person for a a electronics check out.
Mar 26, 2009 | HP Pavilion dv1000 Notebook
Enter password
To repair your computer using Startup Repair follow these steps:
  1. Boot into Vista installation DVD
  2. Choose your language settings and click Next
  3. Click Repair your computer
  4. Choose your operating system and click Next. This should bring up System Recovery Options.
  5. Click on Startup Repair
Startup Repair should now start diagnosing your system to identify the root cause of the failure. Once it has identified the root cause, it would automatically start repairing your computer. If you are curious to know what Startup Repair did, you can click on the details link and see which tests Startup Repair ran to diagnose the problem.
After Startup Repair has finished the repairs, click Finish to reboot your computer.
Your computer should now be able to boot normally into Vista!!
Note -- If your computer cannot boot into Vista even after repairs, then go back to System Recovery Options and run System Restore.
That's it! This is how you use Startup Repair for most unbootable situations.
Feb 22, 2009 | Acer Aspire 3680 Laptop
Startup problem
I would recommend you to boot your system and safe mode and do a system restore...To open your computer and safe mode hit the F8 button on your keyboad when the computer is booting up..click safe mode..and then once you get to safe mode its going to give you an option to restore your computer to another day..after the restore is finish, you should be able to use the computer without any problems...
Jan 31, 2008 | IBM ThinkPad G40 Notebook
HP Pavilion TX2000Z Notebook Logo
253 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
