Question about Zenith VCS442 VHS VCR
Cannot use on/off button
Kids playing around messed up the remote control on my zenith model 442. i can't find the manuel. there is some code i remember putting in, before getting on/off to work. otherwise it works fine except for volumn control, which will be ok once i get the coding set. help!!
  • 291 Answers
Re: cannot use on/off button
If you can turn the machine on and off, you have the code. your volume control (button) could be damaged, stuck in one position.
Get a can of that "compresed air" and place it inbetween the rubber (if it is rubber) volume control. see if that loosens it up.
Posted on May 13, 2008
0 characters
3 Points
What is the code to program a Zenith digital converter box?
If you have a recent GE remote, it may have a code for your Zenith STB. The code list included in the package with the remote may include it. In any event, you can use the code search feature of the remote to find a code that will work. if you search through all codes stored in the remote without success, you may have to try another universal remote. All universal remotes do not contain all possible codes.
Sep 12, 2015 | Zenith 3-Device Universal Remote Easy To...
Remote CTL model RM-V210 doesn't allow programming of the VCR.
Dear sir/madam,
click the above link and programmed your remote control..
good luck
Oct 01, 2008 | Sony SLV-679HF VHS VCR
I got a Zenith vcr model VRC4203C and I can't have a code for my URC-386 remote... can help ?
If your remote is programmable, you can use its code search feature to find a suitable code. If a thorough search through all codes stored in the remote does not succeed, you may have to try another programmable remote.
Feb 28, 2015 | Zenith VCRs
I ACCIDENTLY PUT MY VHS ON CABLE MODE AND NOW ALL I GET IS NO SIGNAL how DO I GET IT BACK TO TV MODE I have already unplugged it but nothing happens.
There is an input selector button on its remote control. Press it tepeteadely until the made change to TV. If you don't have a remote control, and if you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site Check this site too. Universal remote controls are available at most of the electronic spare part selling shops.
Nov 03, 2014 | Zenith VRA421 VHS VCR
Need remote code for old zenith vcr model IQVB423
I couldn't find any codes for Zenith in my code book, so I am wondering if it is made by another VCR maker and users that code?
Oct 06, 2009 | Zenith IQVB423 VHS VCR
Lost codes for v.old universal remote
All universal remotes work about the same. Try this.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 24, 2009 | Sony SLV-SE720 VCR
I'm looking for the manual for a Mitsubishi VCR HSU447 with the remote control RM75502 so I can program my TV to it. Thanks
1.- Turn off your TV
2.- On the remote control, set the VCR/TV slide switch to TV position.
3.- While holding in SP/EP button, press the code button listed below that corresponds to the brand of your TV
4.- Press TV POWER on the remote control. Once your TV has turned on, your remote is set up to operate your brand
Brand of TV Brand Code Button
Mitsubishi 1,2,3
Fisher 0
Goldstar 2,9
Hitachi 8
Magnavox 4
NEC 2,9
Pioneer 6
Philips 4
Sanyo 0
Sharp 3,5
Toshiba 7
Zenith INPUT
I finnaly found my VCR Manual, and I'm glad to share this info with you, because I was looking for the manual all
over the web and FOUND NOTHING!. Bye!
Mar 15, 2009 | Mitsubishi VCRs
Remote codes
Hope this helps.
Feb 27, 2009 | VCRs
VCS 442 Zenith
one way is to connect an antenna to INPUT of VHS, place a tape, press play, STOP and switch VCR\TV switch to TV. u should be able to change the channels from the VHS. If that don't work, u may have switch problems.
If this works, tell the
P.S. The 'blue screen' means that you don't have a signal to the antenna inpur\TV protion of VHS.
Mar 27, 2008 | Zenith VCS442 VHS VCR
Shuts down after 8 seconds of play.
Does the tape hang out when you eject the cassette?
8 seconds is about the time that the VCR brain allows the mechanism to run when there is a problem before shuting down. Just guessing from the model number, but I'd say the unit needs a belt job.
Dec 24, 2007 | VCRs
Zenith VCS442 VHS VCR Logo
90 people viewed this question
Top Zenith VCRs Experts
Steven Wander
Steven Wander
Are you a Zenith VCR Expert? Answer questions, earn points and help others
