Question about Ultra Products Ultra M923 Full Tower ATX Case (ULT40125) ATX Mid-Tower Case
Ultra m923 mid-tower case won't stop beeping
When I first received the computer and put it together, everything was working just fine and running great. When I tried adding a second monitor things just went bad. The display at the top of the case is showing half numbers and the HDD and fan display are not moving. The computer will however continue and finish booting up to the windows screen normally but it won't stop beeping, from the time I hit the power button to the time I shut down. Even after I removed the second monitor and set everything back to the way it was, the loud annoying beeping will not stop and the display is still messed up. Any solutions?
The problem is the board on the case's display. It has temp alarms for your components(video card, hdd, cpu), there are temp probes for you to set so you can monitor these temps. However the board that controls these functions, or at least mine and many others I have read about, is defective. It will change display constantly and sometimes have garbage display. It is setting its own limits for what is considered a hi temperature. The limit it has set for one of your components is < room temperature so it thinks you are having an overheating problem. You can manually set the limit for overheat and it will fix it for a while, but it will prob happen again.
Posted on Oct 14, 2009
Mine started beep continuasly after I plugged a second monitor to my video card also. The display went blank, and the beeping started. After I checked all my connections, reset the video and RAM cards, I pulled the LED display off (four scews) . On the back of the display, near the middle of the card is a reset switch. After I push that the beeping stopped and the display started working again.
Posted on Nov 22, 2010
Mine was working fine and one day the front panel started to beep and when I checked it was that the CPU fan was too clogged with dust (after 14 months) then I realized quickly that these newer computers work with much more airflow than the older ones that I had and since then I just clean them far more often (every 6 months or so). In that case the front panel beeps simply warned me that the CPU was starting to overheat so it did its job.
Now, about the time it had 3 1/2 years it started giving me 5 beeps every few minutes or so. I checked everything and everything was working fine but the motherboard BIOS and the overclocking utility were indicating that the CPU fan RPMs were at zero.
I checked the fan and it was running just fine so I bypassed the CPU fan connector to the panel and I plugged the CPU fan directly to my mobo (MSI X58 Platinum) and the BIOS started to report the fan RPMs again and so did the overclocking utility of the mobo which previously was giving me an alarm too because of the zero reading of the CPU fan RPMs (It sounded like those red alerts from Star Trek).
The problem is that he 5 beeps continued as before and all other sensors were in place as always (HDD temp sensor, VGA temp sensor and CPU temp sensor) I checked them and they were in the right place firmly.
I simply realized now from what I read on the web that the front panel must have started to malfunction. I checked the continuity of the cables with a tester but they seem to be fine. If I plug the CPU fan into the front panel connector as before it reports the RPMs in the front panel but not to the motherboard. In the mobo they appear as zero. So I will keep the bypass and leave the CPU fan plugged directly to the mobo (the mobo has its own buzzer speaker anyway).
What you can do if that pesky buzzer keeps annoying you is simply to pry it off the small board and bye bye with it. Anyway most other cases don't have this functions and the mobos work fine without them, you will miss the temp alarms yes but like I said many mobos have their own buzzer connector and you can buy one for next to nothing in computer stores and plug it in the mobo buzzer (speaker) connector so you have your mobo error beeps which is a good idea.
You can also use together with those mobo buzzers a software utility (like the one I mentioned) that loads at startup that can warn you if the CPUs or fans are having trouble of some kind.
If you bypass the front panel by disconnecting the two white connectors you will loose the system ON LEDs that look kinda pretty and of course tell you hat the PC is activated but they are not an absolute necessity cause you can get a single led from an old PC chassis or from a PC parts store or maybe from Radio Shack (you have to know what kinda LED to use so ask around) and plug it in the mobo power LED pins and then attach it to the chassis in one way to the other (Radio Shack have LED holders too that can be placed in the chassis with a hole).
If you don't want to loose those nice blue LEDs then do as I told you and pry (very carefully and making sure that the PC is disconnected of course) the panel buzzer off. If you are sure that the PC is working fine and this is just a problem of the front panel which causes the buzzer to malfunction then no problem in removing it, the front panel may "think" that there is an error and try to keep beeping but the buzzer wont be there to annoy you anymore. Problem solved.
Posted on Sep 17, 2013
  • 1 more comment
  • David Guzman Sep 17, 2013
    Well I did exactly what i said cause I tried to set the threshold limits to the temp sensors (all 3 of them) to the highest and the buzzer kept beeping. So I turned the PC off and broke the upper part of the buzzer little by little carefully with some pliers. I realized then that the top part of the buzzer is kinda of a separate thing, it has a line that divides the upper cover (the one with the little hole in the center) from the lower one so you may not even have to break it. It may be possible to just pull it carefully and then that upper plastic part comes off it and then you just remove the metal circlular part an leave the lower part of the buzzer soldered top the little circuit board and that's it, the buzzer wont be able to make any more sounds so it was even easier to do than I though originally cause I didn't have to pry the lower part of it from the board and that has far less risk of damaging the rest of the board and in my case that is good cause all the blue LEDs still light up perfectly when the PC turns on and I like it like that. Also the HD indicator in the LCD panel still works which tells me that the hard drive is accesing data. After that I have not have any more problems with it.
    And if you have more problems with the small panel than me and you have to remove it from the loop, just disconect the two white connectors on the back of it and plug the CPU fan directly to your mobo. If you need to provide a power on LED the one you have to buy is 3.3 volts. You may have to get one of those tini conectors that you plug into the mobo power LED pins. Its posible that you may get one of those from some of that surplus stuff that comes with many motherboards or from an old PC that no longer works. Some of those mobo power LED connectors are 2 pins & others 3 pins so just find the correct one you need and even if it is a 3 connector one you will have to use only two to attach the LED cables cause it has only two. It may be possible to place the new LED in one of those empty holes on the fron grills (this case has many) and hold it there with a little bit of that black epoxy that you can get on autoparts stores.
    Remember that not all 3.3 volt LEDs are the same, some are dimmer and some are brighter. Try to find one that you like cause you may find one that is too bright and you may find that annoying or you may get one that is too dimm and you may not be able to see if it is on in daylight. If you go to Radio Shack for example to buy it then ask the store clerck if it is low, medium or high power LED (in terms of the brightness), he/she may know, tell the clerk what do you want to use it for and the peson may understand and perhaps is able to recommend the right one.
  • 23 Answers
The last time I had a problem with my computer beeping at me like that and it was related to video was when the video card was not completely inserted and set into the AGP port. If it sounds like it is just random beeps without any real pattern then it might just mean that the 2nd plug caused a short and now there is a physical hardware problem. If it is beeping in a particular pattern then you should look up the beeping sequence with a google search...such as 3 short, 2 long 2 short means ....there are hamsters in your CPU fan.
Posted on Jul 03, 2009
Do I need to use the fan control that came with case? Because I heard it causes problems with the case.
Not at all... just bypass the controller and connect directly to the 4 pin power molex connector or Fan connector on the motherboard if they are available with your motherboard.
Nov 20, 2010 | Ultra Products Ultra M923 Full Tower ATX...
Azza Orion front fan problem
Put some oil in the fan motor or check if any wires may hitting in the fan while running
Jun 15, 2010 | Azza Orion 201 black/silver SECC Steel ATX...
I have a Ultra M923 Full Tower ATX Case ATX and the lcd screen doesn't work, is there anything i can do to fix it?
@ PaulMo..
You need to research the question and product at hand before posting a solution, Flyner1990 was referring to the LCD panel on the Ultra M923 Full tower case and not a monitor or video card.
The Ultra M923 has known issues with the front LCD panel, either they work or they dont. They are not accurate either.. Solution is either replace the case with something else or disconnect the LCD panel's sensor's and purchase another fan controller. I too own this case and love the design but having issues with the front panel as well and my fix was installing another fan controller/monitor..
Feb 22, 2010 | Ultra Products Ultra M923 Full Tower ATX...
My computer tower wont stop beeping
Re-seat the memory.. more than likely they have unseated themselves during the dust cleaning. Beeping is usually caused by memory.. Beeps are usually a series like Morris code long..short beeps.. if re-seating the memory doesn't work, try swapping and removing different sticks and differnet locations on the motherboard, most motherboards have 2-4 memory banks or known as dimm slots.
Jan 16, 2010 | Ultra Products Ultra M923 Full Tower ATX...
Need to know how to open for cleaning
There should be a handle on the side (opposite to mother board where everything plugs into the back). Simply squeeze the handle and pull the side back. If the case locks, make sure the case is unlocked prior to carrying out the procedure
If this solution has helped you, please take the time to rate me.
Oct 04, 2009 | Ultra Dragon ATX Mid-Tower Case
No display no beep sound
you need to check your memory RAM of your PC. if it is ok or not. try to swap to another pc or tighten it.. cheer ^^
Jul 20, 2009 | XION II Mercury (XON102) ATX Mid-Tower...
M2N MX SE Plus Motherboard
Read the labels for the connectors on the motherboard.
Polarity does not matter for the POWER and RESET buttons.
If the lamps for AC-POWER or HARD-DRIVE-ACTIVITY do not light-up when you expect them, then reverse the connector.
Try the PC SPEAKER connection one way, and then shutdown
the computer, reserve the connection, and start the computer.
If the "beep" at start-up is better, leave it as-is.
If the "beep" does not happen, or is quieter/distorted, reverse the connector.
May 21, 2009 | Ultra Products Ultra M923 Full Tower ATX...
I broke my temp probe on my raidmax
if by the probe you understand front fan controller,yes,there are controlers to replace yours..just pay attention to fit in the bay..
Jan 21, 2008 | RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower...
Raidmax Scorpio ATX Mid-Tower Case
The on/off connector is the power labelled one. The one thing you may have to do is (if you have'nt already)connect the power connector from the PSU to the processor power supply, close by to it as it may not just run off the motherboard ZIF socket for it's power up.
Feb 07, 2007 | RaidMax Scorpio 868W ATX Mid-Tower Case
Ultra Products Ultra M923 Full Tower ATX Case (ULT40125) ATX Mid-Tower Case Logo
786 people viewed this question
Top Ultra Products Computers & Internet Experts
David Payne
David Payne
Are you an Ultra Products Computer and Internet Expert? Answer questions, earn points and help others
