Question about Makita MAC2400 Electric Powered Air Compressors
Brand new Makita MAC2400 is leaking oil.
Just took it out of the box today(I ordered from Amazon), put oil in, air filter and followed the initial startup instructions(let run not filling for 20 minutes). Once it was broken in I shut it off and closed the valve and started it back up. I came back out to check on it's progress(which seems really slow too) and I noticed oil leaking from the unit. I didn't know if that was normal so I continue to work and I just shut it off and it's still leaking and it's almost out of oil. It's all over my garage. Any idea what this could be, it's not coming from the oil cap or drain.
  • 146 Answers
Send it back Right now do not keep iT NO IT SHOULD NOT BE LEAKING LIKE THAT Paul
Posted on Jul 05, 2009
Hi my suzuki gz 125 wont idle correctly and when i rev the engine it just dies down and cuts out i cant even achieve a stable idle speed
I had this problem today with my bike and after much ado I discovered there was oil in the air filter box... check your oil level it could be too full. Mines was and the excess oil was blown into the air filter box and as a result contaminated the air filter. Spent today cleaning the filter box, carb and draining and changing oil, could not get a new air filter today so ran it without onebike runs like new!! New air filter will be here Monday!
Aug 22, 2012 | 2000 Suzuki GZ 125 Marauder
Craftsman mower runs rough
Sounds like carburetor problem, remove the air filter and see how it runs without it if it still running rough need to have carb rebuilt or replaced
Jul 05, 2012 | Craftsman Kohler Courage 26 hp 54" Garden...
Mower thoughing oil while it is running then chokes out
If the mower has been tipped up oil will now have entered the air filter box and soaked the paper air filter, remove the filter and run the engine to see if the oil burns away and the engine runs normally, do not over fill the engine with oil, fill only to the max mark on the dip stick.
Apr 16, 2012 | Garden
My greetings to all Iam from Saudi Arabia and bought 2005 ford free star sport with 4.2 L and i do not know how to get the manual and how many for oil for changing oil with filtter . thank you
you should change the oil every 4000 to 5000 km in that hot climat your van should take a little more then 4 liters of oil so buy 6 liters oil filter part # should be on the filter you could take it off the old one if your doing this yourself drain oil put new filter in and add 4 liters of oil wait 5 minutes check oil level on dip stick add half liter at a time and check oil level again wait few minutes in between for oil to drop down in oil pan for proper readings on dip stick.repeat ontil oil level shows in the hatch marks on dip stick DONT OVER FILL. also fill oil filter with oil before instaling the new one to insure that oil will flow trought engine at startup without having to fill oil filter first leaving engine to run without oil until this happends internaly on its own you may have a liter left after your done ,you can use this for top ups inbetween oil changes .you should also check and replace your air filter at this time .
Apr 11, 2011 | 2005 Ford Freestar
How many quarts of transmission fluid goes in a 2000 ford explorer /
Hello there
abar_a.gif?v=72006
2000 FORD TRUCKS EXPLORER 5.0L 8-cyl Engine Code P
FILTERS
AMSOIL Ea Oil Filter.........EAO11
Wix Oil Filter.........51372
AMSOIL Ea Air Filter.........EAA122
Wix Air Filter.........46253
Wix Fuel Filter.......33595
Wix Trans Filter.....58955 [1]
[1] 4R70W
CAPACITIES
Engine, with filter..........5.0 quarts[1]
Cooling System, Initial Fill..........15.0 quarts
Automatic Transmission, Others Initial Fill..........3.9 quarts[2]
Automatic Transmission, 4R70W Initial Fill..........5.0 quarts[2]
Automatic Transmission, Total Fill
4R70W..........14.0 quarts
2wd ..........10.0 quarts
4wd ..........10.0 quarts
Manual Transmission, ..........5.5 pints
Differential, Rear..........5.7 pints[3]
Differential, Dana 35 Front..........3.6 pints[4]
Transfer Case,Full-Time 4WD..........2.7 pints
1. When refilling, remove dipstick to provide adequate venting and allow oil to flow into crankcase.
2. With ENG at operating temperature, shift through all gears. Check fluid level in PARK and add fluid as needed.
3. Fill to no more than 1/4 to 9/16" below fill plug hole.
4. Fill no higher than 9.5 mm or 3/8" below fill plug.
Aug 07, 2010 | 2006 Ford Explorer
Oil in air cleaner
Run it minus an air filter until all the oil is off your piston head, you can also try keeping the plug out and ejecting the oil via that access by pulling the cord. It seems like you've already solved the problem, now you're just cleaning up.
Apr 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
2003 honda shadow spirit vt750 carb problem
buddy dont worry about it what you have done is put to much oil inside the engine and as the piston goes down it cause abit off pressure which in the small space it has when you over filled it the pressure inside has just forced the oil out the breather into the air box just give it a little clean and drop oil aswell bud
Sep 04, 2009 | 2003 Honda VT 750 CD Shadow A.C.E. Deluxe
Way too much oil, how do I fix?
If the problem was just overfill, the smoke should clear up after running it for awhile. You may want to replace air filter or clean if possible.
Aug 05, 2009 | 2004 Yamaha TW 200
Engin fogs the neiborhood with air filter on.
Sounds like it's pulling oil by the rings/valves -- the air filter is creating more suction. I would try a small amount of an oil additive for high mileage engines. Follow the mixing/proportion directions on the bottle. Sounds like this engine is "wearing out".
May 07, 2009 | Mtd Garden
Makita MAC2400 Electric Powered Air Compressors Logo
584 people viewed this question
Top Makita Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Makita Air Tool and Compressor Expert? Answer questions, earn points and help others
