Model number FFHS2313LM3 have noticed this before once and it froze everything in the fridge side which kinda makes me think it would be a damper or tempature control of some sort
Appliance Repair Forums
See page 8-8
http://appliance911seabreeze.com/Frigidaire_Error_Code_Booklet.pdf
Testimonial: "Thanks, this is perfect"
SOURCE: I have a Kenmore model 795 77563600 refrig side
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: Fridge problems - frigidaire
Sort of sounds like the adaptive defrost board is bad and you are not going into a defrost cycle. Do you have ice build up on the lower interior freezer section? Are the vent slots full of frost/ice? Ideally, pull the freezer shelfs out and take the little aluminum panel off the interior back to look at the coils. Are they basically a block of ice and frost? The problem happens when the unit doesn't go into defrost cycle and the coils freeze up. That blocks the air flow in the freezer so you get frozen food at the bottom but soft stuff at the top. And the frige just can't get enough cool/cold air from the freezer section to cool anymore. Power surges or blackouts, etc. can just destroy the defrost circuit board. Without good air flow the unit is not going to cool properly.
SOURCE: Frigidaire side by side error code 4
I have Fridaire refrigerator model PLHS67EGSB5 and have electronic control flashing code 4 at the right side (Refrigerator side) . What that means and how can solve it.
Thanks, Anibal
SOURCE: Flashing #4 on temperature display
flashing #4 is a communication error between the control board and the damper assy, usually it is the fault ogf the damper assy but if it is under mfg warranty, replace both, if you need to pay for the parts yourself get the damper first.
