Question about Maytag Atlantis MAV6451 Top Load Washer
Maytag washer How do i get to the water hoses on the back of my machine to change them?
  • 4 more comments
  • jarr1229 Jul 03, 2009
    My water hoses are in a little boxed in space. I must have to take the lid off to get to the hoses.
    I can't get pliers in the space to loosen the hose.
    model mav6200aww
    mav6200aww
    How does the front panel come off?
  • jarr1229 Jul 04, 2009
    Thank you for your help.
    We have the spring clips how do you get them out?
    We tried a flat screwdriver.
    Thank you Thank you we got it.
    President:
  • 1,136 Answers
Hi, Just pull the washer out away from the wall a little. You will need pliers to turn the fittings off. Be carefull when you replace them. The inlet valve is plastic and the threads will strip out very easy. Also notice witch one is hot and witch is cold.
I hope this helps you.
Vic
Posted on Jul 03, 2009
  • 4 more comments
  • Victor
    Victor Jul 03, 2009
    If you woill get me a model#, I can look it up and let you know.
  • Victor
    Victor Jul 03, 2009
    There are 2 different series machines. I believe the one you might have is after series 18. Remove the rear panel behind the controls and see if you can get to the hoses that way. If not, you will need to remove the front panel. Then remove the 2 screws holding the top to the cabinet and lift the top up to get to the hoses.
    This is not one of there better ideas for a repairman to access the water valve. If you go to www.bellparts.com you can type in your model# and see the pictures to get an idea.
    I jope this helps you.
    Vic
  • Victor
    Victor Jul 03, 2009
    If there are no screws in the bottom front corners, then you will need to insert a flat blade in the gap between the top and front panel and release the spring clips. There are 2 of them.
  • Victor
    Victor Jul 03, 2009
    Sorry but the pics aren't that great and I don't work on enough of these yet to know exactly.
  • Victor
    Victor Jul 04, 2009
    Just push them in and lift the top at the same time. The top should seperate from the cabinet.
  • Victor
    Victor Jul 04, 2009
    You are welcome. I am glad I was able to help. Have a great weekend.
    Vic
How to replace a washer drain pump on a MAVT634Aww Maytag washer.Thanks
It's a fairly simple job. Unplug machine. Lean back on back legs so you can access bottom / underneath machine. Remove belt. Place machine back on all 4 feet. Remove access Panel on back of machine in order to access Pump which is in bottom floor of machine. Remove 2 hoses from pump. There will be water that escapes so have several thick towels to soak up water. Pump is held on by 3 self tapping screws. Remove those, and pump will lift right out. Place new Pump in, reinstall screws and hoses. Reinstall back Panel then reinstall belt. You may want to leave back Panel off until you inspect for hose leaks. Don't forget to plug machine back in.
Sep 06, 2017 | Maytag Washing Machines
Maytag washer (LAT7400AAV)shuts off during rinse cycle
The machine control board is programmed to allow a maximum continous fill time of six minutes
or an accumulated fill time of 8 minutes for each full wash cycle.
If the required fill time exceeds the time limit, the washer will shut down.
This is to prevent flooding in the event there is a loose hose clamp or damaged air dome hose.
Check the incoming water lines for a minimum pressure of 20 psi.
If lower, the customer can use smaller clothes loads and reduce the pressure to 10 psi.
An alternative solution would be to change the plastic inlet screens to metal screened washers
and remove the nozzle extender found in the water valve inlet hose near the dispener inlet."
Dec 10, 2014 | Maytag Washing Machines
Leaking maytag neptune washer
The pump and its various hoses are easily accessable through the back panel. The boot can collect coins which can block the pump. Squeeze the boot and empty it of all coins. Coins can ruin the impellers on the pump. A new pump costs $100 on line. The drain hose can be plugged by dimes and pennies. Good luck.
May 28, 2014 | Maytag Neptune MAH5500B Front Load Washer
Maytag washing machine no water coming in
check water coming out of hoses. check on hot and cold fill. could be fill valve
Feb 09, 2013 | Maytag Legacy MAV208DAWW Top Load Washer
My Maytag Washing Machine has lost water pressure. We changed hoses and still same. What else can be wrong? Model number is PAV2300AWW.
You need to clean the screens in the back of the washer. Take off the hoses. Then pull out the screens that are inside the water valve of the washer. clean them then put them back in. This should solve your problem
Jul 12, 2011 | Washing Machines
Water seeping from hose connections in back. hoses are brand new.
make sure that the hose washers have been inserted properly and that the hose connection is not cross threaded it is easy to do
good luck i hope this is some help to you
Feb 03, 2010 | Maytag MAT13MN Top Load Washer
Model number mav85578ww Hot water won't work.
the inlet water valve on the back has gone bad,replace it and it should be all right-mike
Jan 15, 2010 | Maytag MAV8557 Top Load Washer
Maytag washer will not fill with water. It does agitate and spin
My May Tag model LA 882 washing machine is not draining water. the water remains even after spining and the cycles are longer durations. any advise ?
Mar 31, 2009 | Maytag Washing Machines
Washer Maytag
To get access to internals you have to remove back panel of machine and then other 3 sides that then exposes the parts you need to get to eg. drainage hose,s
Apr 20, 2008 | Maytag Dependable Care LAT9706
Maytag Atlantis MAV6451 Top Load Washer Logo
229 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
