Malwares recommends that I ask you for a replacement disk. I ordered the Powertools CD on 7/13/14. The number on the disk is 61175393; Malwarebypes 2014. When I opened the package the glue stuck to the CD. Malwares recommended using Windex and rubbing alcohol. Neither would remove the glue. They now recommend that you send a replacement disk. ID: 5YR68-B57JH. Key: YHRP-VUW7-EP6P-70X1
SOURCE: harman kardon soundsticks II
use a clear silicone based sealant (similar to the type used for caulking and in fish tanks) I'm guessing you used CA or superglue, and thats what melted your plastic, you're using too much also most likely.
SOURCE: wii console
If you have game cube games you may want to try them as well. If it plays the game cube games but not the wii games it sounds like the sensor inside is bad and you will need to contact nintendo so they can fix the sensor.
SOURCE: Hello, The stereo has a CD stuck in it and just says ERR.
Mike
Yes you can remove the CD , how did it get stuck, during loading or when you tried to eject it? Is it a multi disk Player or a single cd player and is the loader in the trunk of the vehicle?
Thanks
Bill
SOURCE: Xbox 360 sound with no picture
I posted here below about an hour ago, I contacted Microsoft and this issue is only under warranty for 1 year,I was well pissed at them,They wanted £60 to fix it,I surfed the net researching the issue and found out it seems quite a common problem,I think the piece of **** 360 over heats cos its made badly,Anyway i read about wrapping your box in a towel???????? I tried it,wrapped it completely in a towel and turned it on,The fan got louder and the machine turned itself off after about 3 minutes,I left the machine for about 30 mins to cool and then i tested it. This is no ******** it actually works, I dont know how long it will last though.
SOURCE: Disk
http://www.ku990.co.uk/lg-ku990-u990-viewty-downloads.php#originalsoftware
they have a link to download the original software from the CD if you are missing it
