Question about Kenmore Refrigerators
Used but very new Kenmore 21 cu. ft. I just bought doesn't get cold enough. Fridge won't go below 50 degrees, freezer won't go below 10 degrees at coldest setting.
  • robert_willa Jul 03, 2009
    Thanks. I'm guessing it's most likely low on Freon, or maybe one of the other problems you mentioned that I can't test for. I'm going to have a Sears repairman come out for the repair.
    President:
  • 942 Answers
Hi, i think the freon, and do the steps that i can list below
  • Check the temperature settings
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condinsor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Good luck !!!
Regards
PCmania
Posted on Jul 03, 2009
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
I have a Kenmore Elite 51374. The refrigerator is not getting cold enough but freezer is too cold. Technician said that it was an electrical problem to call a electrician that I needed a new outlet. I...
That is the dumbest answer I've ever heard from a technician.
The cold control on most boxes controls the freezer temperature. You want the freezer temp to be around zero degrees.
Somewhere (usually in the refrigerator section) there's another control that actually sets a damper, letting some cold air from the freezer into the refrigerator. Higher numbers equal lower temperature. Find that second control knob and turn it up by 1 or 2 numbers, let an hour or so pass and check your refrigerator temp. You want about 40 degrees in the fridge.
Aug 02, 2017 | Kenmore 23.3 cu. ft. Side-by-Side...
On my GE GTH21SCXSS, top freezer bottom refer, the freezer and refrigerator settings are on the coldest settings and the freezer won't go below 15 degrees and the refer won't go below 43 degre
Do you see any ice buildup on the back panel of the freezer? You may need to remove the back panel to see if the coils are iced over. Post back your results.
Feb 10, 2013 | GE GTH21SCXSS Stainless Steel (21 cu ft)...
Kenmore side by side not cooling, freezer still frozen, but fridge@50 degrees
is it one or two compressors as if it has one it will be low one r134a gas, or defrost stuck on good look
Apr 11, 2012 | Kenmore 25.1 cu. ft. Side-By-Side...
The refrigerator is not cooling enough. Even though I turn the dial up to the maximum 7, the temperature will not go below 50 degrees. I need to maintain a temperature below 47 degrees.
There could be two reasons for this
The thermostat is not working properly - replace the thermostat
There is a small refrigerant leak and the fridge cannot get cold enough - you will need a technician to find the leak and regas the fridge
Mar 30, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore upright freezer. Ice cream soft. Food is cold. HELP!
Ice cream has to be colder than 0 degrees C /32 degrees F. You need a cheap thermometer If your Ice maker Ice is not sweating in the bin, -10 degrees F ice stops sweating. you need not to sweat the freezer untill your cheap freezer thermometer can be compared to -10 degrees F
Nov 29, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Gladiator ref is not cooling properly
Check to see if there is cold air coming from the freezer to the refridgerator side through the vent holes The compressor maybe getting weak or the freon charge maybe low. Does the unit run a long time before it shuts off? 50 degrees is not cold enough for a freezer. You should be around 32 or less.
John
Sep 28, 2009 | Gladiator Freezer GAFZ21XXRK
Freezer/Fridge not cold enough
check see if compressor on check control if on
Apr 05, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore elite refrigerator
It sounds like the fan is not circulating the air from the freezer to the fridge. Since it's new then you should contact the store where you purchased it for exchange or repair immediately.
Jul 08, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
