Question about Kenmore Refrigerators
Kenmore 795.77312600 interior lights always on.
Kenmore 795.77312600 interior lights always on. I know the door switches are good because the open door indicator will not beep when doors are closed.
frcs68
  • 1605 Answers
SOURCE: Kenmore Side by Side
use WD-40 on the hinger of the door. very small amount will do the trick.
Posted on Oct 15, 2008
  • 84 Answers
SOURCE: Interior lights won't turn on when door opens
Do you have electric locks in the vehicle? One test to do is turn on the car's headlights and open the door. You should hear a chime when you open the driver door. One other thing is to unlock the doors with the remote if you have a remote open the driver door, get in the car but don't put the key in the ignition. The doors might relock after 15-20 seconds. This proves that the door signal open is not being processed. Just tell me what model VW and what year and if you have electric locks and I'll help you.
Posted on Oct 31, 2008
SOURCE: Kenmore Elite bottom freezer refrigerator model 795.77573600
My Kenmore Elite (Model 795.7755 3600), less than two years old, had the same problem. One morning I opened the doors to a hot fridge and burning plastic. The light housing was sizzling hot - much of the unit literally melting away. Another hour or two and it could have been much worse.
Called the 1-800 number listed in the fridge. After about 45 minutes of patient talking, I learned that Sears (or Kenmore) have issued what they refer to as a "flash warranty) on the light fixture kit (Kit # 6871JB1423N) which in effect, for this part only, extends the factory warranty from one year to three years. I may even be able to have a factory tech install the parts. Hope it works out.
Bottom line: if you have this fridge, be very careful and monitor closely. An pursue the part warranty!
Posted on Jan 13, 2009
SOURCE: Interior Lights and Door Ajar light stay w/beeping noise.
Try spraying WD-40 into the door latching mechanism (door side). I learned this fix after two battery replacements, but have only had to spray twice in the more than seven years of ownership
Posted on Jan 29, 2009
SOURCE: GBC Shredmaster 5260X - door is closed by light indicates otherwise
This shredder has a magnet built into the door. If you open the door you'll see a metal strip on top right side of shredder. Either the magnet is not getting close enough to activate the reed switch or the hinges have came loose allowing a door sag condition. Also, if the shredder isnt that old, just contact GBC for some warranty work at 800-790-7787
Posted on Feb 10, 2009
2007 POLO GTI 1.8T... my interior lights don't switch off? light switch turned off, engine switched off, key pulled out of ignition, door locked but the interior illumination stays on
there must be a switch on the actual light fitting to set it to 1 always on , 2 always off , 3 on when door opens , check the switch position
Nov 04, 2014 | 2007 Volkswagen GTI
Kenmore 600 dryer
Your door switch for this dryer is stuck closed or defective. The door switch controls the light to come on when the door is open while it also controls the drive motor as a safety device to stop the motor when the switch is opened. Replace the Switch.
Oct 28, 2013 | Dryers
1999 Jeep Grand Cherokee Laredo interior light stays on
are you sure it isnt the roller switch on the dash? if not that maybe you got a bad door switch
Jun 18, 2017 | Cars & Trucks
Interior lights wont go out
Check for a faulty switch inside the door jam. If the switch is broken or pushed into the holder, it will not open the circuit thus the light will stay on. You may have to remove the bulb until you have time to replce the switch. Good luck
Feb 12, 2011 | Jeep Grand Cherokee Cars & Trucks
Why doesn't the dome light go on when door is opened
Get your owners manual out and find the instructions for the interior light. You will find it has three settings: always off, always on, and on when the door is opened. Make sure the bulb is good by moving switch to always on, then move it to on when door opened. if it does not come on at all you need a new bulb. if it comes one with one door but not another then you need to replace the button switch in the door jamb. Should still be under warranty though so call a dealer before you spend any money.
Nov 29, 2010 | 2007 Chevrolet Equinox LS New Cars
Microwave door shut, but interior light is on - micro won't work
Yes. One of your door switches is not working. It could be an alignment issue or a faulty switch. There are actually 3 switches in the door latch area.
Eric
Sep 06, 2009 | Kenmore Microwave Ovens
Door ajar and interior lights dont go on when door is open
THE SWITCH MIGHT BE STUCK! OPEN YOUR DOOR, LOOK FOR A BLACK ROUND SHAPE BUTTON AND GRASP THE ROUND EDGES WITH YOUR FINGER AND PULL OUT AND SEE IF YOUR DOOR AJAR LIGHT COMES ON, ALSO CHECK THE FUSES AND LAST CHECK YOUR INTERIOR LIGHT BULB. GOOD LUCK!
Jun 10, 2009 | 1997 Lincoln Town Car
Cant get my interior lights to come on when i open the door.
My 02 did the same thing, i don't know if you tried this, but turn the interior lights on with the dimmer switch, then back off. Then lock the car with the remote and hopefully when you unlock it the lights will start coming on.
Mar 14, 2009 | 2000 Chevrolet Impala
Interior lights do not come on
Is it an old van? Can you see on the door frame a switch does it come out when the door is opened (push in and out a few times). 3 position switch on always / off always and door switch?
Apr 10, 2017 | 1999 Ford Windstar
Refrigerators Logo
128 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
