Question about Nike WC0045012 Chisel Training Digital Watch for Men
How do i get my Nike Chisel watch into power mode
I need to change the time on my nike wk0006 watch, but nike doesn,t sell it anymore...WHAT DO I DO!!!!????
TRY!
Make sure the watch is facing the correct way. Put the watch on your wrist as you normally would, or pick it up by the strap with your left hand. You should see that the Nike swoosh is right side up. You should be able to read the time.
Find the left side of the watch. This will be your left when the watch is facing you correctly the same way that you would look at it to read the time. You will see at least two buttons. One will be labeled "mode" and the other will be labeled "set."
Press the "mode" button. Press the "mode" button. Continue to press the "mode" button until you have scrolled through the options and are on the correct setting. The correct setting should be "time."
Hold down the "set" button. You should see the currently set time on your watch and the hour should be flashing. You should see a plus sign (+) and a minus sign (-). If your current time says three (for example) and you want to read five, press the button that corresponds with the plus sign. If you want to go backwards, press the button that corresponds to the minus sign. When you are finished hit next.
Change the minutes. Now the minutes should be flashing. Repeat step four: press the button that corresponds with the plus sign to increase the minutes. Press the button that corresponds to the minus sign to decrease the minutes. Hit "next" when you are finished.
Hit "done." Congratulations, you have now successfully set the time on your Nike watch. Now your watch should read the correct time. If you want to get really crazy, you can repeat the steps above to change the date on your Nike watch.
Sep 28, 2014 | Nike Triax WK0006-001 Watch
Tip
Manual of instructions for wacth Nike Chise Wc0045-001
I'm trying o find a manual of instructions for wacth Nike Chise Wc0045-001.<br /> If somebody have it please send me by email <a href="mailto:godoyva@hotmail.com">godoyva@hotmail.com</a><br /> thanks<br /> Valeria
on May 03, 2011 | Nike Mettle Chisel Watch Black WC0045 001...
If my light and the alarm noise is out, does that mean I have a low battery?
Not necessarily , you can try opening the back and exchanging the battery. It is pretty easy to do and the batteries only cost like 3 dollars.
If its not that then it will need to be serviced in order to work again , if you had bought it within the last year then you can get it done free from Nike .
http://www.nikewatchrepair.com/
thats the link and instructions you do not need to fill out form if you do not have receipt just send a note with watch when you bought it and whats wrong with it along with your name email phone number and return address.
hope that helps
Oct 22, 2010 | Nike Mettle Chisel Watch Obsidian WC0045...
How do u do this
Below is the link for manual to the C3 watch in question. From what I can tell, you need to do the following to set the time:
1. Push MODE button until you reach TIME MODE.
2. Hold the START/STOP button for 2 seconds. I believe the HOUR will start to blink at this point.
3. From here on, one of the buttons will scroll through the HOUR, MINUTES, 24HOUR FORMAT, and the other will be used to adjust them, I am just not sure which it is, but with the PDF MANUAL link below and trial and error, you will get it done in no time flat!
This link will take you to the C3 manual in PDF FORMAT:
http://www.nike.com/timing/extranet/product/triax_c3/c3_manual_eng.pdf
This link is for nike support on the C3, by phone, email, even live chat!
Enjoy your Nike watch!
Dec 31, 2008 | Nike Triax C-3 Wrist Watch
Nike watch
In TIME mode - not ALARM - top right hand button marked "START/LAP" toggles hourly beep on/off. As not in ALARM menu, easy to put on unintentionally.
Nov 07, 2008 | Casio DW290 1V Classic Alarm Chronograph...
Nike watch problem
Okay, mine's a Chisel but I'm pretty sure the module is similar, if not the same, across the Mettle range.
Anyway, press and hold the light button - marked adjust - until the display says "hold to adjust"; after a couple of seconds the time display will return and the hours will be flashing.
To adjust up, press "start/+" and down press "stop/-". To cycle through the options, press "mode".
Once you're done, press the "adjust" button again to return to regular timekeeping mode.
Enjoy your Sledge - if you don't I'll have it!!
Regards,
Martin.
Jul 16, 2008 | Nike Mettle Sledge Watch WC0040 096
Nike WC0045012 Chisel Training Digital Watch for Men Logo
134 people viewed this question
Top Nike Watches Experts
Ansel Alberto
Ansel Alberto
TIME TRACK SERVICES
TIME TRACK SERVICES
Are you a Nike Watch Expert? Answer questions, earn points and help others
