Question about RCA RP5016 Digital Voice Recorder
RCA RP5016 will not format SD Card. Is there a
RCA RP5016 will not format SD Card. Is there a limit? I've tried both a 512MB and 1GB, neither will format. The "Wait" message has been on for 39 hours now. Surely it should take that long to format an SD card.
    Problem Solver:
  • 4 Answers
The max SD card capacity is 256Mb.
Posted on Nov 12, 2009
My micro sd 512mb memory card asking password, i have forget it. how to open or format my memorycard
If you're on a mac, use disk utility to format it. If you're on a PC, right click the drive and click "Format..."
Mar 01, 2011 | SanDisk 1GB microSD Memory Card
Nikkon coolpix L1 After downloading memory card .. then putting back into camera. Reading says "cannot read memory card." Checked card out at store verified that it is good. Why does it not work in my...
A couple things you might try.. remove the card carefully and check the position of the "lock" tab. Make sure it is fully in the unlocked position - not locked or a point between the two positions. Reinsert and try again.
It sounds lie you're using a card reader to download the pictures - try formatting the card while in the card reader via computer. The card should be completely empty when the format is complete. You can even try copying files to and from the card to make sure its ok and format again. When complete, try again in camera.
If the problem persists, check to make sure the card is on Nikon approved memory card list for use with the Coolpix L1 (provided below):
The following is a list of approved memory cards for the Coolpix L1 digital still camera. These cards have been tested and approved for use with the Coolpix L1.
The L1 uses SD (Secure Digital) memory. Sandisk:
  • 64MB, 128 MB, 256MB, 512MB, 1 GB, 256MB*, 512MB*, 1GB*
Toshiba:
  • 64MB, 128MB, 256MB, 512MB, 1 GB, 128 MB*, 256MB*, 512MB
Panasonic:
  • 64MB, 128MB, 256MB, 1 GB, 256MB*, 512MB*, 1GB*
* - Cards rated for 10MB/s (high speed) Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
The list came direct from Nikon Support. Other cards may work, but only those on the list are approved. Successful use of other cards can not be guaranteed.
I hope this helps!
Sep 30, 2010 | Nikon D60 Digital Camera with 18-55mm lens
Format error
The reason why is because that particular camera does not support memory cards that big.  Samsung only guarantees compatability up to 512MB, but the max I have ever heard working is 1GB.  If you do buy one, make sure it is a sandisk card as these have been tested and guaranteed to work in that camera.  Lexar may also work, but for sure 4GB is to big and is unsupported.  Hope it helps.  Please dont forget to rate!
Mar 03, 2009 | Samsung Digimax A40 Digital Camera
How to use sd card with magellan meridian gold
http://www.mtgc.org/robertlipe/MeridianFAQ/#47.Troubleshooting%20–%20My%20tracks%20have%20the%20wrong%20time%20stamp?|outline
Try this site to trouble shoot your problem! Good Luck! I ran across this today trying to trouble shoot mine.
Dave
Sep 09, 2008 | Magellan Meridian Gold GPS Receiver
Maximun SD Storage card size
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Kodak/Kodak+EasyShare+C330_Memory_Cards
Jul 12, 2008 | Kodak EasyShare C330 Digital Camera
Size of sd card
Hey there harad82, many digital cameras have difficulty formatting and thus difficulty recognising larger size memory cards. This limitation is due to the date of design of the camera, and the only recent availability of the larger memory cards. Also the processor power onboard many cameras is quite limited and cannot handle too much information, such as when one of these cards begins to fill. This can result in lost data. I would suggest you try one before purchasing, perhaps a friend can help with a loner or you can check your cameras specs for limitations on card size. The smaller size cards (512mb or less) rarely cause these difficulties. If you need help with specs please respond with your camera make and model#. Good Luck!
Feb 25, 2008 | Vivitar ViviCam 5299 Digital Camera
Memorex MMP3642A - SigmaTel format
A few suggestions:
1] I’ve tried using a 1GB sd card in the MMP3642A with no success. Interestingly, I can transfer files to the 1GB card when it is in the MMP3642A, but when I turn on the player to listen to the files, I get the sigmatel formatter error message. I tried running the sigmatel formatter, but it doesn’t understand the 1GB size. Apparently whoever programmed this braindead formatter program only programmed it for up to 512MB sd cards. Interestingly, I tried flashing this player with the MMP8500 firmware, and then the player does play files off of the 1GB sd card, but the LCD is mostly cutoff and only 25% of the LCD shows up. So it seems the only obstacle to using a 1GB sd card is this stupid formatter program. I tried formatting the sdcard to fat16 instead of Fat32, but that did not help
2] If you want to use a card with more than 64MB, you need to use the CD that was with the player. DO NOT USE AUTORUN! Explore the disc, go into the "products" folder, run the stusbmscformat.exe application. It will show a the drive letter for the player, click the arrow and select the next drive letter down, then press start. This worked for me, I hope it will be useful. Why memorex doesn’t address this issue is beyond me.
3] How do I correct the error: Reformat external media with sigmatel formatter? If you have installed the software disc that you received with your MP3 player, you will need to follow these instructions; -- From your computer, click 'START' -- then 'PROGRAMS' -- then 'MEMOREX' -- then 'FORMAT' -- choose the 2nd drive If this doesn't correct your error, you will need to return the memory card to the retailer for an exchange. connect your memorex mp3 player , then turn it on and click start .....i did the same and its working now.
Jan 08, 2008 | iLO MP3 Player
Playing off of the sd card
I guess that no sopport that size you most have use one sd of 512MB
Dec 27, 2007 | RCA Lyra RD1072 MP3 Player
"This card can not be used"
I experienced the same problem with a 1Gb card. The Vivicam 4000 only supports SD cards no larger than 512Mb. My solution to the problem was to simply repartition the SD card into two equal 512Mb partitions using Cute Partition Manager...http://www.cutepm.com. You should be able to do much the same thing except you will have to create 4-partitions, each no larger than 512Mb. When doing so, use the FAT 16 format option. As a word of caution, after repartitioning, do not use the fomat option on your camera, or it will restore it to a single partition 2Gb format. Also, when using whichever partitioning software you choose, be sure that you have selected your SD card, and not your C-Drive. Hope this is as successful for you as it was for me.
Sep 25, 2007 | Vivitar ViviCam 4000 Digital Camera
I have the same problem as 'Can't acces [sic] mass storage'
Problem is unit will not work with an SD disk over 512MB. For some reason if the SD Card is 1GB or larger you will receive the message the card needs formatting. Verified this after many hours of trying to get 1 and 2GB cards to work. Used 512MB cards or less and the camera works perfectly. Originally got this info from a tech support facility that does support for Bushnell.
Aug 06, 2007 | Bushnell ImageView 11-8321 Binocular
RCA RP5016 Digital Voice Recorder Logo
110 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
