Question about Whirlpool GC5SHEXNS Side by Side Refrigerator
Water dripping slowly out of water dispenser
HI, I have 1998 whirlpool refrigerator (ED25PQXFW01). The ice maker is working fine but the cold water dispenser is have problem. Over the weekend, water started to drip slowly out of the water dispenser (we have not used it for a while).
when I pushed the dispenser lever, the switch (near the lever) seems to works but no water come out. I confirm this with a ohm meter.
Any advise?
Ti
  • gotv973 Jul 03, 2009
    Kevin, what is a RO?
  • 854 Answers
Sounds like your water inlet valve is bad.
here's the picture
Posted on Jul 03, 2009
    Genius:
  • 1,847 Answers
On the right hand side in the back take off the compressor cover with a screw driver and then two more hold on the water valve. If you have a RO system hooked up to refrigerator you may need to change the filters on the ro or just change the filter on the refrigerator.These two will also cause the water to drip through the valve allowing it to drip on the front .
Thanks.
Kevin.
We have a whirlpool gold conquest side by side refrigerator. Water dispenser works, ice does not. Stopped suddenly making any ice. How do we fix it? It's only 2 years old.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it's frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don't refill with water.
ICE MAKER NOT GETTING WATER
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Jan 21, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side by side GS5SHAXN. Ice maker slowly died.
Hi agcruiser;
Have your change your water filter lately?
If not try that, as it may be starting to block up a little.
Another problem could be the water inlet valve(Ice Side) situated at bottom of fridge, that could be starting to wear (Can interchange with water side inlet valve). Yes there are 2- 1 for ice and 1 for water
The Whirlpools Ice Michine set up is very easy, and runs by a mechanical system, they can be tested (Use a qualified tech).
Cheers hope this helps
Mar 29, 2010 | Whirlpool GS5SHAXN Side by Side...
My whirlpool model # ed2chqxkb05 is not making ice, we can still use the water in the door. its not making ice. Help
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Dec 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Auto Ice maker in Whirlpool fridge, not producing ice. I suspect the water feed line might be frozen since it was working fine two days ago. I haven't heard the water fill and the tray is empty.
Oct 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hi. I have a Whirlpool sise by side gold
Aug 30, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker goes through the process but no ice is produced water
If you're not getting water to the ice makerTry swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
A strainer before the inlet valve can also get stopped up restricting flow. ice maker
Jul 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water drips slowly out of dispenser, ice distribution is fine.
Hi, yes the water line could be starting to ice up; maybe defrosting the fridge will cure the problem. Mine has a coiled tube behind the lower drawer in the fridge, this is where the water line is chilled. Hope this helps if you've not sorted the problem already. Kind regards jb
Jul 02, 2009 | Whirlpool GS5SHAXN Side by Side...
Cold water dispenser on new whirlpool side by side dispenses lukewarm water...ice maker works a charm
there is a tank in the refrigerator section that hlds about 1.5 gal of water as you dispense it refills and pushes out the cold water. if your unit is new it will need a day to cool down the tank of water before you will get cold cold water at the dispenser
Hope this help explain how it works
Aug 01, 2008 | Whirlpool GS6NBEXR Side by Side...
Maytag side by side multi problems
1. Ice maker is not cold enough to start the ice making process.
3. having to take off the back panel is an indication of a problem in the defrost system. Call to have a service tech check this out.
May 15, 2008 | Maytag MSD2756GES Side by Side...
Whirlpool GC5SHEXNS Side by Side Refrigerator Logo
141 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
