Question about Dryers
Not drying machine runs and door gets hot, but does not dry
  • 75 Answers
Check the outside vent flapper make sure its opening and blowing they get clogged with lint and stick shut also some dryers have 2 heating elements and one will quit
Posted on Jul 03, 2009
The dishwasher runs through it's cycle but does not clean the dishes properly and leaves a cloudy film and smears on the inside of the machine and the dishes
    Common Problem
  1. Confirm the wash water is hot
    1. Try heated wash(sani wash) if available
    2. Run hot water in sink to warm up before starting
    3. At least 120 degree Fahrenheit water temperature
  2. Open door check wash arm position start washer for a minute
    1. Confirm wash arm has rotated
    2. Check for plugged spray tips at either end of wash arm.
    3. Use small tweezers to remove
    4. Check for rack and dishes interfering with arm rotation
  3. Place cup in upper rack with opening up cycle washer.
    1. Confirm that cup quickly fills with water
    2. Not washing check water level in tub mim 1 1/2 inch
  4. Discontinue use of rinse/dry liquid additive.
    1. Confirm rinse/dry additive not leaking from dispenser into tub
    2. Washer detergent contains sparkle additive and too much sparkle/rinses/dry additive will coat dishes
    3. Try alternative wash detergent that contains minimal rinse/dry additive and use without liquid rinse/dry additive.
  5. It will take several wash cycles after the elimination of rinse/dry to purge the oily film from dishes and machine..
  6. If success "joy" is achieved with no additives then cautiously add back wash detergent with additives. Additives are important to facilitate drying and protecting the glassware china from leaching. The leaching process permanently etches the surface of glassware leaving a cloudy appearance.
Jan 03, 2016 | Dishwashers
The dryer stopped working for my hwd1000 --
Check your belt. It may be shot. And that will cause your machine to do that. The heat will still work but your clothes will not dry.
Jun 14, 2017 | Haier HWD1000
How to clean my washing machine Electrolux Front Loader
Hello -
First rub some bleach around the door gasket. Let this dry. Next rub some vinegar around the door gasket. Let this dry. (Do NOT mix the bleach and vinegar) Then run a hot empty load of bleach in all three dispensers. Put 1/2 cup of bleach in the detergent dispenser and fill the softener and bleach dispenser to the max fill line with bleach. Once that is done repeat the process with vinegar. Please make sure you run a load of towels or some sort of items that will not matter if you get a little bleach on them once this process is done.
Sep 21, 2012 | Electrolux EW1000i Front Load Washer
My Bosch logixx dishwasher is sticking on 1 minute at end of cycle; the dishes will be clean but still wet rather than dry.
100% add the jet dry until it is completetly filled then close the dispenser door and lower then raise the door.repeat this at least three times then check and fill if you can still add more. then after doing that b4 you start the machine run the hot water to get the right temp. when the water is hot enough then start the machine.
Mar 03, 2010 | Bosch 24 in. SGS09L12 Logixx Free-standing...
Film on glasses and dishes.using cascade complete and jet dry.Dishwasher is a kenmore elite.
make sure when you fill the jet dry that you make sure it is completely filled. you must add jet dry,close door,lower and raise the door 3 times and then check normally you could add more jet dry because the air is now pushed out by this process. and finally b4 you turn on your machine make sure tolet your faucet run until it hot and then start machine. that should handle the problem. let me know if this helps by sending me a 4 thumbs up post . thanks
Feb 28, 2010 | Dishwashers
Bosch Exxcel WVT1260 On drying the heater seems
Check your venting. If the water vapor can't get all the way outside, your dry times will be longer than usual and the steam will come out the front when you open the door. You may need to clean your ducting, which is a good idea anyway to reduce fire risk.
Nov 13, 2009 | Washing Machines
My Magic Chef dryer doesn't dry properly
remove the vent from the back of the machine, run it full of clothes from the washing machine and if it dries nicely, then you have a clogged vent that needs replacing.
Jun 16, 2009 | Magic Chef CYE2000 Electric Commercial...
Clothes wont dry but gets really hot
make sure your exhaust line is clear and not kinked
Oct 24, 2008 | Washing Machines
Hello, sounds like your cold water feed hose has got a kink in it. The machine needs cold water to condense the steam. Just pull out the machine and slowly slide back into place.
Oct 21, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
Dryers Logo
Top Dryers Experts
Marvin
Marvin
