Question about Linksys WMP54GX 802.11g/b Wireless Adapter
How to find WEP keyso I can access WLAN on my Nokia phone
  • 37 Answers
If you forget your wep key you will have to reset the router by holding down the reset button for 8 seconds then release. Then you will have to set up your router all over again. On most routers the user name is Admin and password is Password. Check under her router for the ip address to get the set up menue. Apply that address in your broswer as is. You will have to create your own wep key depending on your router settings.
Posted on Jul 03, 2009
I cant access wlan connection using dlink router,im using nokia c3-00 .it always says wlan connection failed even if theres a strong signal
if the router is password protected, try reseting it to open and attempt to connect again. If it connects without security then there is a security log error between the two devices.( which is common for n-type routers and/or mobile operating systems.) you will need to select a security type that is listed within your phones settings.
May 13, 2011 | Cell Phones
I am using nokia e63 phone. When i try to connect to a wlan network it asks for preshared key or wep/wpa key . What should i do?
This is the same key that you use to connect your laptop to wlan.
if it is an office network, you will need to ask the network administrator or someone using the wlan for the key.
Mar 11, 2011 | Computers & Internet
I want to connect to internet using this unit please help me
  • Figure 1
    The strongest local wireless network connection
    is displayed on the N95's Active standby screen. In this case the phone has found a network called 'mat'
  • Figure 2
    To search for more WLAN connections, click Options, highlight Search for WLAN and click Select
  • Figure 3
    To connect to a WLAN network, highlight its name and click Connect
  • Figure 4
    If the wireless network is security-protected, you'll need to enter its hexadecimal WEP key to log on
  • Figure 5
    You can also connect to a WLAN using the WLAN wizard. This can be found in the Tools are of the Main menu
  • Figure 6
    When opened, the WLAN wizard displays a list of the available local wireless networks. Highlight one and click Options to log on
Feb 28, 2011 | Nokia N95 Cellular Phone
I cannot connect my nokia c7 to the internet through wifi
Hi, pls verify below steps,
1.Whether WLAN switched on and has a good WLAN coveage. 2.Security settings on WLAN options
- Check the security modes (Open/WEP/WEP2 - this depends on your WLAN connection) - Check Security settings (Public shared Key settings)
3.You have to be a authorized user in WLAN network if it requires authentication login. 4.Open the browser on you mobile and select General->Connection->Always Ask, then it will prompt for the connection type, Select WLAN.
Thanks, Ramaly
Feb 28, 2011 | Nokia C7 (8 GB) Smartphone
My psp won't connect to the internet. it says, a commection error has occured. a connection to the access point could not be established. check the security settings for the network and try again.
First of all check if your wireless router requires (WEP KEY) to establish a connection then you will have to put same (WEP KEY) in PSP WLAN security setting and if your wireless router is set without (WEP KEY) then in PSP WLAN security setting it should be set to None. kindly refer to the following image.3782ff8.png
Oct 20, 2010 | Sony PlayStation Portable (PSP) Console
How to connect my nokia n95 to wifi
Sir,Your required Wifi Connection to access internet OR you can access internet using GPRS service Nokia N95 you.For-you require Wifi router then your mobile will detect that wifi connection and you will be able to access internet on your mobile phone.
Dec 10, 2009 | Nokia N95 Cellular Phone
Wep key for nokia 9500 communicator
wep key is the password you give when you own the connection, so that not everyone can connect to the net and do nefarious acts on the net and get you caught. so, for wep key, you must ask the owner/administrator of the connection/phone that has the WLAN.
Aug 30, 2009 | Nokia Cell Phones
Need to get wep key for wlan
The WEP key is an encryption/authentication key. It is used in a wireless network to authenticate a device as being authorized to access the network and is also used to encrypt traffic between the wireless device and the access point. WEP is a weak encryption method and should be replaced with WPA2
Jun 10, 2009 | Computers & Internet
Wep key data of nokia 9300i
Hi..
Let me help you out..
You have to enter WEP key which you used for computer synchronization.
Let me know the Router Model you are using..
follow this steps:
Option:1 - If setup with Bluetooth or Router with Mobile.
Just enter 12345
if it promts again in the computer there also enter 12345. use same key in all places when it prompts.
Option:2
If the setup as Router computer and Cellphone.
1.Open Router Configuration page by accessing default IP address mentioned on the router.
2.Go to Security or WEP tab. disable WEP.
or set WEP key
3.now enter the same Key for your nokia 9300i.
Feb 17, 2009 | Nokia 9300i Cellular Phone
Siemens gigaset se587 wlan dsl wpa
You can try this link, this has a step by step instruction and screen shots as well. I hope this one helps.
http://portforward.com/english/routers/wireless/Siemens/Gigaset-SE587/wireless.htm
May 04, 2008 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Linksys WMP54GX 802.11g/b Wireless Adapter Logo
52 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
