If you are referring to the oil cooler for an automatic transmission, then it will mostly be in the radiator bottom/side tank and uses coolant to cool the oil. They have a habit of cracking/leaking and putting red oil in the radiator or allowing coolant into the transmission. The fix for this is costly flushing of the engine system and transmission and a new radiator. I would consider an air cooled oil cooler as they are more efficient and not prone to coolant problems.. They are generally cheaper than a radiator as the inlet/out let pipes can be blocked off
