Hi,kenmore top loader washing machine type 110 mod 14102300 ser cr2210773. all still working but will no longer spin.?...any help I thank you.
    President:
  • 1,136 Answers
Hi, When the cycle is in spin, do you hear the motor at all? If the motor is not running, it could be the lid switch. Try pushing down on the lid and see if it starts the washer.
Does the washer agitate? I am asking because, If the washer doesn't agitate or spin, it could be the coupler or transmission. Just wanting to narrow down the problem for you.
Please let me knwo if any of this helps you.
Vic
Posted on Jul 03, 2009
  • 5,911 Answers
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Now...a washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Take note of your symptoms:
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
2. Washer fills, does NOT agitate or spin, but WILL drain - motor coupling.
If you still have questions, please let me know. I hope this information is helpful to you.
42936- My kenmore elite he front-load washer w/steel tub-has scrapping/unbalanced like sound coming from washer when in spin cycle, then after completed there is shredded plastic/fiberglass like mater
Sound like one of the wights has come off or is loose and damaging the drum and other parts take a under the machine and you may see the problem
Jul 29, 2014 | Kenmore Washing Machines
How to remove Control Locked
www.appliancerepair.net/kenmore-washing-machine-repair.html
Jul 27, 2014 | Kenmore Elite 45986 Front Load Washer
My elite he3 will not drian/spin with out pushing the drain/spin butten.
Possible that the auto mode is not working due to fault in the processor or the memory. Try and check with another program cycle and if the same fault repeats it seems to be a suspect. Make sure to clean the Inlet and drain filter and check the water flow pressure.
Jan 23, 2013 | Kenmore Washing Machines
Kenmore top loader machine will agitate, and dispense water, but will NOT drain and spin cycle is not functioning.
If the mod # starts with110 then it is whirlpool built check lid switch///need to know Mod # before I can help you further. check back with me..///If I helped you please vote...Good luck
Feb 09, 2011 | Kenmore Washing Machines
Kenmore washer MOD 110.24422300 SER CP4427442 the washer wont spin, it makes a harsh and loud noise when it comes onto the spin cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 20, 2010 | Kenmore 12502 Top Load Washer
Want an owner manual for an old Kenmore 70 series washing machine havy duty super capacity plus mod. # 110 22722101 ser. # CL4432583
Go to managemylife.com and type in the model number you provided under the "Manuals" link. Your owner's manual is listed in a .pdf (Adobe) format that you can download or print for FREE. I hope this helps you.
Mar 07, 2010 | Kenmore Washing Machines
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Kenmore washer wontt spin or empty. i laid machine on its side
Adjust the motor mount so the pulleys are aligned.
Brute force may be necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 10, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
134 people viewed this question
Top Washing Machines Experts
