Intertherm blower motor is shot and i need a one thats compatable
Intertherm blower motor is shot and i need a new one but i cant find the one i need all the info on it is that its a half horse motor and2 speed /1070 rpms where can i find a compatible motor at a reasonable price will a motor with similar size shaft and rpms work?
  • Dennis Boxerman May 11, 2010
    match the specs. Frame size (FR) usually 48 or 56 Voltage Amps Service Factor (SF) Some have it and some don't. RPM's Shaft size Shaft rotation (CW or CCW) Best advice is take it with you and go to Grainger. They can most likelymatch it. If you got it in your hand, less chance of OOPS.
  • 75 Answers
Yes bring the motor to a a/c service dealer and they can match it up for you
Posted on Jul 03, 2009
SERIAL # IK0487-01713
I googled: Intertherm Air Conditioners There are a number or articals that may help you find what you need. One referance to a youtube "review" Hope this helps. I was going mention "how do you know it's a bad blower motor? But depending on age and use anything is possible. Usually the motor has a model number on it. That would be the safest way to find an exact replacement.
May 12, 2015 | Intertherm Heating & Cooling
My husband got up this morning and the coils were frozen and the blower was not and still will not run, we checked both breakers (indoor and out) and replaced the capacitor outside a month ago and replaced...
Hello, since you replaced the capacitor it only leaves either a bad control board or bad blower motor. If there is 120 volts to the motor then the motor is shot, however is there is no voltage to the motor then the control board must be replaced.
Jul 26, 2011 | Intertherm Heating & Cooling
My outside a/c unit runs but no air is blowing thru my vents. Is the blower motor or could it be a r
Hello, if no air is blowing thru the vents then it could be a bad blower motor, a bad run capacitor, or a bad control board. If the motor is getting voltage from the board and it will start by spinning the blower wheel by hand you capacitor is bad. If it does not the motor is shot, however if you do not get voltage from the board but there is voltage to the furnace then the board is bad.
Jul 01, 2011 | Intertherm Heating & Cooling
I have a 1971 Coleman Intertherm Furnace that the motor went out in and i cant seem to find a motor got any suggestions I live in Grand Junction Colorado
I usually bring my motors to a rebuild shop, however 40 years is a long time for a Coleman. Ever considered a new system?
Mar 20, 2011 | Intertherm Heating & Cooling
35 year old intertherm ModelE2712..Blower motor sluggish to start up but runs fine once it gets to speed.. Could it be the capacitor Model #620-2712
Since it goes ahead and starts I would be more inclined to look closely at cleaning the motor and lubing if it has oil ports.Remove and clean out blower if you can as they can gather several pounds of dirt and debris over the years. If you have compressed air available then blow out ventilation ports on motor and blades on blower
Also check side to side movement of motor shaft as it may have bearing about worn out.If it has much more than 1/8 inch movement than you probably are getting close to needing a new motor Hope this helps you. Thanks.
Jan 18, 2011 | Intertherm Heating & Cooling
Intertherm unit : heat is on and Iam energized at the motor but It does not turn on !! Blower motor works on cooling!! ???
try to switch the speed of the blower to a diffrent speed to se if that works(usually its the red wire for heat) . make sure to turn power off before disconnecting.
Jan 14, 2011 | Intertherm Heating & Cooling
How to replace Intertherm M1 Combustion Blower Assembly on an Intertherm M1MB 070A BW Gas Furnace Series #m1D020401209? I think this is the problem. The furnace squeals when turned on and it seems to be...
The combustion blower is easy to replace. You may be able to prolong the life of the motor by applying lubrication to the shaft bearings. If the motor is too far gone then replacing it is the only option. Just remove the screws that mount the blower case to the heater, disconnect the wires and reverse the steps to install a new motor.
May 04, 2017 | Heating & Cooling
WIRING
why did the wiring burn?Id have the heat exchanger inspected before rewiring.better to be safe.
Sep 17, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
