Question about Maytag Neptune MDE5500AY Electric Dryer
One of the three paddles inside the drum has broken off. I have the new part and need to know how to access the drum to replace the paddle? I know the bolt heads are on the outside of the drum.
    President:
  • 1,952 Answers
You will need to take the back panel off use a 1/4 in socket driver.Then you should see the drum.
www.partstoday.com
http://www.partselect.com/
http://www.repairclinic.com/Home.aspx
If you want to do it yourself, click on this link: Appliance Parts From PartSelect | Repair Parts For Major Appliances.
Insert the model number and get part diagram to install it and part price to buy it.
If they do not have the part, call them or try here: RepairClinic.com
two screws hold each in place, and is is common for them to graduallyloosen. it is also easy to tighten them back. open the door, there are4 screws on each side inside door frame, remove them. then pull thefront panel from the sides towad you, the pannel will come foward thenlift up and set panel aside. there is 1 screw on each side holding thetop down, remove them then top hinges up. you will be able to see thedrum and as you turn it you can tighten the screws to all 3 baffles,then re-assemble.
Posted on Jul 03, 2009
  • 1 more comment
  • mohammed marika thambi
    mohammed marika thambi Jul 03, 2009
    put all the screws back in the back. You are going to get it from the
    front. Remove the screws that hold the door in place. Lift up on door
    and slide the hinges out. Remove the two screws and spacers on the
    opposite side. Now pull the front panel forward and off. Now you will
    see two hold down brackets that secure the top. Loosen the screws and
    slide the brackets to the inside. Now the top will lift up and you can
    get at the screws for the baffles. Just rotate the drum till it's on top
    To fit new paddle,line up the lugs on the paddle in the slots in the
    drum, and push firmly with both hands towards the rear of the drum, you
    should feel it click into place, make sure you fit it the correct way
    round.
    The harder ones can involve removal of the drum,
    which means stripping down the machine almost totally just to remove a
    plastic paddle! The reason is that the retaining screw can be on the
    underside, the part that faces onto the outer tub or tank. It is
    incredibly annoying to say the least when you find this to be the case.
    One trick is to release the sump hose (watch out you will get
    water out it) and to see if you can access the retaining screw through
    that. If you can then it becomes a reasonably straightforward job to
    swap the old broken drum paddle for a new one.
    If you do have to strip down the machine to access the drum
    paddles and the machine is a few years old we would almost always
    replace the tank seal or tub gasket as well as the bearing seal at the
    same time. There’s absolutely no point in stripping the machine down to
    that degree and not doing it.
How do i fix a paddle on the drum? I have zanussi machine. Paddle broken off. If i buy a new paddle how do i fix it on? Have tried to glue old paddle with no success!!
With some of these machines now they have sealed drums.On some models you can access through the bottom sump hose and others you may be able to get access through the hose by the soap box.There are a couple of drums where you can drill a hole in the top to get at the tags on the paddles and some drums where you cannot do without changing the complete tub.
Hope this helped.
May 17, 2010 | Zanussi FJD1466W Front Load Washer
Where can i buy a washing machine drum paddle (for inside the machine) one has snapped off today.
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the laterwashing machines often come loose and come off altogether. They can bereplaced. call them lifters. You usuallyinsert a small screwdriver down one of the holes (it's the 3rd one on ) andgently press down while sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
Mar 23, 2010 | Indesit W 123 Front Load Washer
Replace broken drum paddle on indesit wixl123 washing machine and were to purchase part
On hotpoint, creda, Ariston ,indersit and someother makes see video
To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine.
Huge selections of lifters are available on thewebsite DrumPaddle lifters
Oct 19, 2009 | Indesit W 123 Front Load Washer
Drum paddles keep falling out (Hotpoint BWD129 washer/dryer)
I had this problem, and I was advised by the guy who has apparently 'replaced hundreds of these bloody things on this housing estate' to never buy this machine because 'its cheap and ****'
However, if you bend the long central tab ,the one that looks like it does bugger all, upwards into the drum (carefully though, only bend it a little) this will increase the tab tension, and your lifters should last for over six months instead of the previous couple of washes mine was doing.
As for the comment on washing trainers, I put a single towel in my machine and the lifters broke...
Jul 17, 2009 | Washing Machines
Plastic padle on inside of drum broken
Yes the paddles can be replaced. www.bellparts.com type in your model # and locate the paddles.
I hope this helps you.
Vic
Jul 12, 2009 | Washing Machines
How to remove and replace the paddle on a Hoover HSE140 Washing M
pull the paddle towards yourself and lift up it should come out to replace reverse instruction
Jun 23, 2009 | Washing Machines
How do I replace Drum paddle on Hotpoint WF860 washing machine
To fit new paddle,line up the lugs on the paddle in the slots in the drum, and push firmly with both hands towards the rear of the drum, you should feel it click into place, make sure you fit it the correct way round.
Please rate my solution.
Thanks.
Mar 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
Plastic lug securing paddle in drum have broken off
It is easy to fit.
To remove paddle ,grasp firmly and pull it towards you, then slide new paddle into slots and push firmly towards rear of. drum
You should feel it clip into place..
Make sure you get right paddle as there are at least 3 versions of drum paddles
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint WMA64 Front Load Washer
Drum Paddle broken Hotpoint Aquarius
The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out.
Mar 08, 2008 | Hotpoint Ultima WF860 Front Load Washer
The paddle came off inside my Neptune Dryer
The screws for the paddle can be accessed by removing the small back panel. If they are stripped out you will need a new paddle.
Jun 07, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
