Question about Nokia 3100
Not working ringer
I need 3120 ringer solution
    President:
  • 1,952 Answers
Menu
2 settings
3 tones
incoming call alert (set to ringing)
ringing tone ( pick your ring tone)
ringing volume (set to level 5 loudest)
vibrating alert (on)
message alert tone (pick tone)
instant message alert tone (standard)
keypad tones (on)
warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok
alert for (all calls)
Posted on Jul 03, 2009
5 Suggested Answers
SOURCE: ringer not work
try to check the buzzer,if ok,go to check the buzzer lone...
Posted on Jul 18, 2007
SOURCE: Ringer doesnt work Nokia 3120
Have just fixed this problem on my 3120 everything else was working on it except this. If you take apart the phone starting with removing battery, then the face plate and touchpad, then using a T6 screwdriver remove the 6 screws holding motherboard to the chassis and remove motherboard. Then remove silver metal base plate to expose the Antenna Assembly, very gently remove this part as this is where the ringer is. When you are looking at this you will see two little spring loaded balls on the left hand side, you should be able to put your finger on one of these to get a clicking sound. Both of these should be in the up position if not do this, with a very thin blade gently go into the seam nearest the spring loaded balls and cutting thru the glue go along edge of seam until they pop up. Then put it all back together again and hopefully this has sovled your problem. My phone was out of warranty and i had 3 quotes of $70-$90 to fix so i had nothing to loseby doing this.
Posted on Jan 16, 2009
  • 1894 Answers
SOURCE: ringer problem
it may be due to some small loose connection. remove the connections once and re fix them again.
Posted on May 31, 2009
ashlocked
  • 1140 Answers
SOURCE: my Nokia 3120 Ringer Problem
If you can't the ringer of your phone,check the settings on your profile if its activated and volume is up,otherwise,it seems your buzzer/speaker is the problem,sometimes when the phone gets drop on the ground, buzzer contacts may be dislocated or probably need a buzzer replacement.
To work with this problem and can DIY,
* you need a T6 precision screw driver or any tool that can release the screw.
1. Remove the battery cover
2. Remove the battery pack.
3. On the front panel/housing,release the 2 clips on the bottom using even your thumbnail and lift up the front housing.
4. release the 6 screw using the said tool.
5. lift up the entire module which is the LCD with frame and together with the mainboard.
6. On the back housing,you will see a 2 gold plated pins on the upper potion,that is seems to be the connector were the buzzer is connected and hide underneath.
7. clean it first,check if there's a corrosion and align it as well.
8. located the interface were the 2 metal pins is align connected unto the board.clean it as well.
9. Now assemble the phone and try if it is working then.
If not working,need a parts replacement and this could be possible if you bring to the a mobile service shop near you for replacing the said part.
Hoping this method helps you in a way. Thank you for visiting FixYa.
Posted on Jul 16, 2011
My 3120b is restricted i need a restriction code
Hi, You can get the restriction code for a Nokia 3120 from www.classicunlocking.com/nokia-3120/rs16wp9/ at low cost.
UNLOCKING STEPS FOR NOKIA 3120
1 - Switch on your Nokia 3120 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 3120.
3 - Compose #pw+CODE+1#.
4 - The Nokia 3120 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 3120 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 3120
Nov 02, 2012 | Nokia Cell Phones
My Nokia 3120 Ringer Problem Ringer not working
Jul 16, 2011 | Nokia 3120 Cellular Phone
Nokia 3120 red contac service
Here is the official main page to Nokia's "Nokia 3120" Support page:
http://www.nokiausa.com/get-support-and-software/product-support/nokia-3120
On it, you can choose manuals to read, software updates to download, or contact further on your individual needs (Under Nokia Care Services on the left).
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 06, 2011 | Nokia 3120 Cellular Phone
3120 ringer ic jp
tell your problem clearly please!
Jan 14, 2011 | Nokia 3120 Cellular Phone
Ringer of nokia 3120
what is the problem? please add more details so that we may help you
Oct 04, 2010 | Nokia 3120 Cellular Phone
Ringer problem
May 31, 2009 | Nokia Cell Phones
hi follow these instructions
1 menu
2 settings
3 tones
keypad tones (on)
once you have done them settings try your phone and see if it works if not then follow these instructions
1. menu
2 settings
3. profiles
4 general then personalise
the set like this
Incoming call alert (ringing)
ringing tone (choose ringtone)
ringing volume (level 5 )
message alert tone (choose tone)
Keypad tones (on)
warning tones (on)
once you have changed the last setting press back then select activate your phone should be now be working if not let me know ok
Mar 21, 2008 | Nokia 3100
Nokia 3120 NO SOUND
there can be problem with ur fitting of phone, may be screws are loosen, or ringer is faulty or ringer ic also can have problem. open rintones play anyof ringtone, then press gently on left side in centre of phone, i mean press its case infront of green button ,then check if sound is coming if comes then screws are loosen, if don't come, then u need to take it to technician.
Feb 22, 2008 | Nokia 3120 Cellular Phone
Not ringing 3310
chk profile settings else speakers is out of order.need to replace it frm nokia care,
Nov 12, 2007 | Nokia 3120 Cellular Phone
Ringer not work
Jul 17, 2007 | Nokia 3120 Cellular Phone
Nokia 3100 Logo
595 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
