Question about Garmin nuvi 350 GPS Receiver
I am not able to select all options.
Some buttons don't respond. When I press one option another one gets highlighted.
  • Garmin Master
  • 2,130 Answers
Try recalibrating your touchscreen. The procedure can be found here:
http://www.sharc.net/discus/messages/6/77.html?1236709210
- Jim
Posted on Dec 23, 2009
What do I do to my next book Ares 8 ? Every app I open says not responding?
NOTE: Doing this will clear the data on your tablet, so it is suggested you not choose this option unless you have to, or aren't worried about losing anything on the tablet.
To "Hard Reset" the tablet...
1. Make sure that the tablet is actually powered off.
2. Press the "Power" and the "Volume Up" buttons, together, until you see the start-up logo on the screen.
3. Once you can see the logo, release the buttons and allow the device to enter the "System Recovery Mode".
4. Next use "Volume Down" button to get to the "wipe data/factory reset" option When in recovery mode the "Volume Up" and "Volume Down" buttons are how to can navigate and highlight what option you need.
5. Once you have selected the "wipe data/factory reset", press the "Power" button to select that option.
6. On the following screen, repeatedly press the "Volume Down" button until the "Yes - delete all user data" option is what is selected.
7. Then press the "Power" button to hard reset the tablet. how do you rest nextbook tablet
Jan 07, 2018 | Tablets & eReaders
Tip
With article and troubleshooting guide solution for Android Hard reset way
  • Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights FACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press then release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release the Power key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and the Camera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
5. Here is an alternate reset for a Motorola Atrix still running on the 2.2 Android OS...
While the phones power is off, press and hold the volume down button and press and release the power button (note: if it doesn't work after all the steps listed try holding down the power button along with the volume down button in this first step).
A "Fastboot" screen should pop up, press the Volume down key to cycle through the choices until you get to "Android Recovery", then press the Volume up key.
Wait for the "triangle!/Android". Once it pops up you'll need to tap on the bottom right corner of the screen (note: it may take a few attempts). A menu should pop up.
Tap on "wipe data/factory reset", and then tap OK. Another confirmation screen will appear. Tap Yes and then OK.
After the data is cleared the "reboot system now" option should appear and is highlighted by Default. Tap OK.
Note: this type of reset is common on the 2.2 (Froyo) before the tech geeks wised up and removed the need to use the touch screen.
6. This reset is for the same phone, the Motorola Atrix, but one that's running on the 2.3 OS.
Power off the phone, press and hold the Volume down button and Power button simultaneously while powering on the unit.
The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press the Volume up key to boot in this mode.
Wait for the "triangle!/Android" screen to pop up. Once it does press both the Volume up and Volume down keys simultaneously. A Recovery Menu should pop up.
Tap on the Volume down key until "wipe data/factory reset" is highlighted, and then tap the Power button. Another Confirmation screen will come up. Tap on the Volume down key until it highlights "Yes" and then tap the Power button to make the selection.
After it's done make sure "reboot system now" is highlighted and then tap the Power button.
In this method you don't have to use the touch screen any more. So let's say your touch screen isn't responding therefore you can't navigate the phone or go into your settings and do a regular factory data reset. Well now on the 2.3 there is hope. Just power off the phone and perform these steps and the reset should go through.
7. Here is a hard reset for a Sharp Android Smartphone.
While the device is off, hold the Sym button (it's located on the keyboard) and the Power button simultaneously.
Once the Android boot screen appears highlight the Wipe data/factory reset option by using the volume buttons. Then use the Return key (on the keyboard) to actually make the selection.
Scroll down to Yes - delete all user data and then press the Power key to confirm.
Once it is done select reboot system now and press the Power key to confirm and reboot your handset.
8. Here is a common method used to hard reset an LG Android smartphone. So if you need to hard reset an LG Optimus this is the hard reset key combination to try first.
After the LG phone has been powered off, press and hold the Volume Down button. While holding the Volume Down button, press and hold the Home button. While holding both the Volume Down button and Home button, press and hold the Power button.
Continue holding these three keys down simultaneously until the LG logo appears.
Once the LG Logo appears release all of the keys. This will complete the reset on many LG phones; you will be given the option to "Select your language" and can proceed with setting up your device as if you were setting up the phone for the first time.
If however, you are taken to a fastboot screen or a screen with additional options then use the Volume Down key to scroll to and highlight the wipe data/factory reset option and then press the Menu key to make the selection.
The phone might give you a confirmation screen in which you can use the Volume Down key to scroll to and highlight Yes -- delete all user data and then press the Menu key to make the selection.
If you get an option to reboot system now then select that option with the Menu key. The phone will reboot, which can take a couple of minutes, and the hard reset will be complete.
Now you know how to hard reset an Android Smartphone and the next time your touch screen stops responding, your phone freezes, your phones power cycling, you forget your password, or pretty much any reason you wouldn't be able to perform a reset through the settings, you'll be set.
If I have forgotten any key combos that you know of, leave the method in the comments below so that I can add it to the list. Don't forget to check out some of our many other popular posts and don't forget to power your phone off every couple of days and watch what applications you choose to download onto your device that way you can keep your phone healthy and efficient. Hope you enjoyed the article, have a fantastic day, and enjoy your phone.
Thanks for checking out this Solution. Phonetolls.blogspot.com contents provide include dozens of cell phone artical additional, pictures, with hardware and software troubleshooting guides for you. Support us like and connect with this blogger for latest newsletter please follow me. By Admin shahid abbas
Phonetolls
on Jun 24, 2015 | Cell Phones
How to get software of my proline tablet pc ak888-13
In order to hard reset your tablet, the steps given below must be followed:
Ensure that the tablet is powered off.
Press the Power and the Volume Up button together till the device displays the start-up logo.
Once the logo is displayed, release the buttons and wait till the device enters the Android system recovery mode.
On the displayed screen, use Volume Down button to go to the wipe data/factory reset option (Volume Up and Volume Down buttons are used to highlight the displayed options on the Android system recovery screen).
Once the option is highlighted, press the Power button to select the option. (Pressing the Power button in Android system recovery mode selects the highlighted option.)
On the next screen, press the Volume Down button multiple times till the Yes -- delete all user data option is highlighted.
Press the Power button to hard reset the Samsung tablet device while clearing the dalvik cache along with the process.
Feb 02, 2015 | Tablets & eReaders
How do i reset the password on my galaxy tablet
In order to hard reset your Samsung tablet, the steps given below must be followed:
  • Ensure that the Samsung tablet is powered off.
  • Press the Power and the Volume Up button together till the device displays the start-up logo.
  • Once the logo is displayed, release the buttons and wait till the device enters the Android system recovery mode.
  • On the displayed screen, use Volume Down button to go to the wipe data/factory resetoption (Volume Up and Volume Down buttons are used to highlight the displayed options on the Android system recovery screen).
  • Once the option is highlighted, press the Power button to select the option. (Pressing thePower button in Android system recovery mode selects the highlighted option.)
  • On the next screen, press the Volume Down button multiple times till the Yes -- delete all user data option is highlighted.
  • Press the Power button to hard reset the Samsung tablet device while clearing the dalvik cache along with the process.
Oct 08, 2014 | Samsung Galaxy BBSPHP1 Tablet PC
Reset tablet
Hello,In order to hard reset your tablet, the steps given below must be followed:
  • Ensure that the tablet is powered off.
  • On the displayed screen, use Volume Down button to go to the wipe data/factory reset option (Volume Up and Volume Down buttons are used to highlight the displayed options on the Android system recovery screen).
  • Once the option is highlighted, press the Power button to select the option. (Pressing the Power button in Android system recovery mode selects the highlighted option.)
Hope this helps..
Jan 12, 2014 | Computers & Internet
Zeepad has frozen!! how can i reSTART it without waiting for the power to die out ???
  • Once the option is highlighted, press the Power button to select the option. (Pressing the Powerbutton in Android system recovery mode selects the highlighted option.)
Oct 02, 2013 | ZEEPAD 7 inch Android 2.2 Tablet
I don't know how to adjust the bright and dark for the screen.
To adjust the brightness and contrast, do the following:
1. Press the either the Minus button and highlight the option you wish to change.
2. Press the Menu button to select the highlighted option.
3. Press the - or + buttons to adjust the brightness/contrast settings.
4. Press the Menu button again to accept the changes.
Click the link below for the documentation on this monitor:
http://support.dell.com/support/edocs/monitors/e156fp/En/about.htm
May 23, 2011 | Dell E156FP 15 inch LCD Monitor
How do i switch voicemail off g600
To find where to enter the Voicemail number your phone, please follow the instructions below;
1. Select the menu (press the Navi button).
2. Highlight 'Settings' and 'Select' (left softkey).
3. Highlight 'Message settings' and 'Select' (left softkey).
4. Highlight 'Voice mail number' and 'OK' (left softkey).
5. Highlight 'Voice server number' and 'OK' (left softkey).
6. Press 'Options' (left softkey) highlight 'Edit' and 'Select' (left softkey).
7. Highlight 'Edit Number' and enter '901'.
8. Press 'Options' (left softkey) highlight 'Save' and 'Select' (left softkey).
Jan 21, 2010 | Samsung SGH-G600 Cellular Phone
PS2 Star Wars Force Unleashed Game won't run
Another thing you might want to check is the system settings on the PS2. Start the PlayStation 2 console with no disk inserted in the drive. Upon loading to the main screen which states "Browser" and "System Configuration", press the X button on the controller. You will see five categories, highlight the PS Driver category, and then press the Triangle button once. Verify that both options within say "Standard". If they do not, then please use the steps below to change them.
- Use the D pad up and down to select the option that needs to be changed.
- Once the option is highlighted, press the X button once
- Use the up and down keys on the D pad to change the option to the Standard setting.
- Press the Circle button once to confirm the change
Next, use the D pad to select System Configuration, then press the X button. Using the up and down arrows on the D pad, cycle through the options on the screen and confirm that they read as follows.
Digital Output - Off
Component Out - RGB
Language - English
Screen - Full (This toggles the letterbox functions of the console, and may not be fully supported within the functionality of some games).
If any of the options are different from what is stated above, then, with the option highlighted, press the Triangle button. Use the D pad left and right to select the option that matches what is listed above. Once the correct setting is selected, press the Circle button. Once all the options are set as listed above, press the Circle button to return to the Main menu.
You may also want to try enabling the Auto-Diagnosis feature of the PS2, which will allow it to auto-detect the best settings to use when playing DVD's.
To Activate the Auto Diagnosis
- From the Browser and System Configuration menu.
- Press the triangle button to select Version.
- Highlight the Console from the list and press the triangle button - this accesses the next menu option.
- The Diagnosis will be highlighted.
- Press the X button to access the options available.
- Highlight "ON" and press the X button to affect the change
Dec 14, 2008 | LucasArts Entertainment Company Star Wars...
Garmin nuvi 350 GPS Receiver Logo
24 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
