Question about Sharp Notevision PG-B10S Multimedia Projector
My projector is shooting a yellowish brown color in the middle left of the screen. Kind of looks like it is burnt or something? What could this be and how can I fix it. I just changed the bulb for the first time about 6 months ago and it has been doing this for the last four months i would say. Thanks. Seth-
  • pamsam11 May 17, 2008
    My Projector has a yellow streak in the middle left of the screen. It looks like a highlighter was used in a small area. Bulb is fine, filter is clean. What could it be? It is growing? Color wheel?
  • 115 Answers
Hello
Pls check for the Fly-Eye lens in the optical unit.Also service the
LCD panels.
Viren
Rave Services
Chandigarh, India
Posted on Jan 21, 2008
I Have 50inch Sony Bravia progetor tv and I have a yellowish colour in the middle of the screen
One of the color projectors CRT's is burnt out or is malfunctioning, the cost to repair this is very expensive, in the $500 range. With the new Flat panel LCDs now at rock bottom prices (saw a 42" at Best Buy for $499) I would really suggest you scape the old technology instead of repairing it, it will likely develop another problem within a year or so.
Feb 12, 2012 | Sony Televison & Video
I replaced the lamp on a Panasonic PT-LC80U thinking this will solve the yellow appereance, but it did work, it seems that there are not blues in the image. What Can I Do to solve the problem?
here are some probable causes..
This appears to be an older model (over 5 years old) and LCD projectors turn yellow with age. It's just what they do
However, if you are projecting a computer signal or a component signal, a short in the blue signal of the cable can cast yellow hues over your image. The hue will cover the entire image as if you are viewing the image "through rose (or in this case, lemon) colored glasses" so to speak. That's an easy fix.
Harder fixes: the blue LCD panel is weaking and/or gone bad.
If you have a round yellowish spot in the middle of your screen, the diffuser has been overheated and is "burnt".
Apr 08, 2010 | Panasonic PT-LC80U Multimedia Projector
InFocus LP70 color problem
try resetting the settings to factory default through the menu. if there's still a problem, take the cover off. if you look from the back of the machine, inside on the bottom left, you'll see the main board attached by a large white plug. use something thin and non-metalic to push the bottom of the board towards the plug to tighten it. now do the same to the other side of the plug. this should solve it. if it doesn't, you need to replace the main board.
May 11, 2009 | InFocus LP70+ Multimedia Projector
The screen turns yellowish
That is true, problem is as old as lcd projection. Suggest buying a dlp product. they don't color decay
Nov 26, 2008 | Mitsubishi HC5000 LCD Projector
Nec projector vt 660
could be bad bulb is it setting in right is coler wheel freeley moving
Oct 06, 2008 | NEC VT47 Multimedia Projector
Color bleeding - blue colors always on the screen
just came across this same prob on my projector. Any ideas?
Dec 11, 2007 | Canon LV X2 Multimedia Projector
Yellow area in the projected image
Hello Media Man,
Looks like your projector has done it. Thats acommon trouble to ageing polirising lens, usually the blue. less blue, the green and red make up the yellowish image on the screen. The blue is bombarded with tremendous heat from the lamp and it fade and wash out. If its free, its worth replacing. Get quote for the poliriser; 2 pieces each color.
Good Luck.
Sep 28, 2007 | Mitsubishi ColorView XL30U Multimedia...
Yellowish color
turn off the color and see if you have a good grey picture if not your grey scale is off and requires adjustment
Aug 26, 2007 | Hitachi 43F300 43" Rear Projection...
Dark (brown-yellow) area on the screen
Dalnel97,
Did you ever find a solution to your yellowish brown blob? I have the same problem with mine here at work.
Jun 12, 2007 | Panasonic PT L720U Multimedia Projector
Sharp Notevision PG-B10S Multimedia Projector Logo
230 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
