No high voltage. Turned on green light on the front for a few seconds. changed hot low voltage supply, powers up but still no high voltage and no b plus. any ideas?
  • mrdane3263 Jul 03, 2009
    when i said i changed the hot what i change was the H.O.T
    Sergeant:
    Champion:
  • 212 Answers
It may due to the voltage fluctuation
Posted on Jul 03, 2009
  • 749 Answers
What did you change the voltage from? make/model of tv? you should not adjust the voltage of the tv to the wrong voltage it can harm the the tv's electronics.
    President:
  • 942 Answers
Hi...
Yes, do a hard reset and see if it helps (I give it only a 25% chance it will). Merely unplug the power cord for 4 hours or more. Then power it back up again.
It may turn on again and shut down soon thereafter.
The protection circuit has been activated. This is due to a shorted condition somewhere in the set. In your case since you indicated that the white screen came up shortly which to me indicates the problem is likely not with the high voltage generator, but something either in the deflection circuits or the main power supply.
The set is not "old" in terms of big screen products. It should be good for a life of 12 to 15 years. Therefore, it is worthy of the repair expense. The repairs typically run around $250 to $300 for this kind of repair. The house call you mentioned of $150 is too high unless the tech is coming from a long distance and/or the service company provides something in addition to making a diagnosis report. More typical is $40 to $80 for house calls.
Maybe try two or three different shops to see if they are able to give you a better deal. Also, you can give them my "long distance diagnosis" of either one of the deflection amplifiers or the main power supply and it may help them know what to expect in advance of coming out.
Let me know if I can help further. I would like to hear back from you - as reality check to see what the final outcome was and if my prediction of the repairs was correct or not. Appreciate your help.
Good luck
Regards
PCmania
    President:
  • 1,952 Answers
First check loose conect and electric problem check ur plug point try another plug .........then
If the picture is dropping out all together but the sound is remaining on it points to a failure of the high voltage.
If the picture, when it does come on, has a misregistered pattern, that is the colors are shifted and not aligned that is a convergence failure.
Sometimes the convergence will fail, short down, drain the power supply sufficiently it will cause the HOT and High Voltage to drop out.
So, your problem could be convergence AND/OR high voltage failures.
If it is intermittent and comes and goes it compounds the troubleshooting, making it more expensive than a total failure.
The cost of repairing the convergence circuit is always expensive. Over $400 for example.
I have a pioneer pro-505pg plasma. When powered on The box and TV both go green then both red within a few seconds. plasma then flashes red twice then pauses.what part of the power supply has failed?
You have to check voltages at power supply because any one of the usual four voltages being low or high will shut down as described, so you have to check all voltages. 5V is usually the culprit.
FREE-PPV.com
May 14, 2015 | Pioneer Televison & Video
I have a new heater with diferant terminals from the old one so not sure how to atach the wires
There is no need to rewire the internal of the heater!
Just bring in the electrical supply to the heater, it can be either 120 or 240 volts.
If the heater you have is like the picture associated with your post, then all then have to do is change the supplied plug from 240 to 120. It comes pre set for 240. That plug is inside the cabinet.
If any other brand, then you need to change the wires at the transformer of the heater. All heaters need to be supplied with primary voltage: 120 or 240. Then the control system is supplied with secondary voltage out of the transformer. The secondary voltage is no more than 28 volts. and these wires are normally colored as blue or yellow.
Secondary power is already wired within the heater. NO need to change where they are. You will only need to deal with the Primary wiring.
There are many varieties of transformers that transform high primary voltage to a low secondary voltage of 28 volts. and these transformers have many wires: primary & secondary.
I will try to make this easy to understand.
If you have a Gas Heater Transformer with these colors:
  • Red
  • Black
  • White
  • Green
Or...
  • Red
  • White with Red Stripe
  • Black
  • White with Black Stripe
  • Green
These are Dual Voltage Transformers, you can bring in either 120 Volts or 240 Volts
If you bring in only 120 Volts...
1st example:
The Red wire will not be used! Hot wire to the Black, and the Neutral/Common, to the white wire. Green to ground.
2nd example:
Connect the Red wire with the White with Red Stripe together and connect these to the incoming Neutral/Common wire, normally White.
Connect the Black Wire with the White with Black Stripe to your incoming Hot Wire, which is normally Black.
Green to ground
If you bring in 240 Volts...
1st example.
1 Hot wire to the Red, the Other Hot wire to the Black, and White wire is not used. Green to ground
2nd Example:
Wire nut the two Striped wires together. then one incoming Hot wire to the Black, the other incoming Hot wire to Red.
Green to ground
Or This is only a Low voltage - 120 Volts Only
  • Black
  • White
  • Green
Or either any of these combinations...
  • 2 Blacks w/Green
  • 2 Reds w/Green
  • 1 Black, 1 Red w/green
This type will only be a high voltage, 240 volts only
Picture below is what a transformer looks like and it is where your incoming supply wires go. The smaller leads with the spade connections will go to a specific location & is the 'Secondary" .
Good Luck
Mar 14, 2015 | Pool & Spa
My rca HD52W59 shut itself off; i can power it on and i get a few seconds of audio, but no picture, then it shuts off. The green power light does not blink any sequences
This may be an indication that your H.O.T 'High Output Transistor' that is the main transistor that supplies the High Voltage to the 3 CRT's when the TV starts up. Just a thought.
May 24, 2012 | RCA HD52W59 HDTV Projection Television
NEC Multisync LCD1770V Model# L174F- Monitor powers on for a few seconds then goes black. You can still see a faint image in the background and the power light is still green. I checked for leaky caps on...
Check the iCs on the lcd control board which shut down the ccfl lamps? If hot put a paper sticker slightly smaller on the IC. This prevents condensation from osmosis into the IC.
Dec 19, 2010 | Televison & Video
Monitor no raster power has been ok
The screen is blank with no raster at all. There are indications that the channel numbers are changing in the display. This indicates that some of the low voltages are present but these may be derived from the standby supply.
Assuming there is no deflection and no High Voltage, you either have a low voltage power supply problem, bad start up circuit, or bad horizontal output transistor (HOT) or other bad parts in the horizontal deflection.
Check for bad fuses.
(If you have High Voltage as indicated by static electricity on the front of the screen and you hear the high pitched whine of the horizontal deflection when it is turned on, then the following does not apply).
Use an ohmmeter to test the HOT for shorts. If it is bad, look for open fusable resistors or other fuses you did not catch.
Assuming it is good, measure the voltage on the collector-emitter of the HOT (this is safe if there is no deflection). You should see the B+ - probably between 100 and 150 V.
If there is no voltage, you have a low voltage power supply problem and/or you have not found all the bad/open parts.
If there is voltage and no deflection (no high pitched whine and no HIGH VOLTAGE), you probably have a start up problem - all TVs need some kind of circuit to kick start the horizontal deflection until the auxiliary power outputs of the flyback are available. Some Zeniths use a simple multivibrator for this - a couple of transistors. Others power the horizontal osc. IC from a special line-derived voltage. The multivibrator type are sometimes designed to fail if someone keeps turning the set on and off (like kids playing) since the power rating is inadequate.
Test the transistors if it is that type with an ohmmeter. If one is shorted, you have a problem. The usual way a TV service person would test for start up problems is to inject a signal to the base of the HOT of about 15.75 kHz. If the TV then starts and runs once this signal is removed, the diagnosis is confirmed. This is risky - you can blow things up if not careful (including yourself).
If you hear the high pitched whine of the deflection and/or feel some static on the scree, confirm that the horizontal deflection and high voltage are working by adjusting the SCREEN control (probably on the flyback). If you can get a raster then your problem is probably in the video or chroma circuits, not the deflection or high voltage.
hope this helps......
Aug 06, 2010 | SAMTRON 77V 17" CRT Monitor
How do you fix a ps42p7 plasma tv that has sound and no picture. i have checked the cables and changed tv's and it is not any other source for the problem.
Assuming there is no deflection and no High Voltage , you either have a low voltage power supply problem, bad startup circuit, or bad horizontal output transistor (HOT) or other bad parts in the horizontal deflection.
If there is voltage and no deflection (no high pitched whine and no High Voltage), you probably have a startup problem - all TVs need some kind of circuit to kick start the horizontal deflection until the auxiliary power outputs of the flyback are available. Some Zeniths use a simple multivibrator for this - a couple of transistors. Others power the horizontal osillator. IC from a special line-derived voltage. The multivibrator type are sometimes designed to fail if someone keeps turning the set on and off (like kids playing) since the power rating is inadequate.
Test the transistors if it is that type with an ohmmeter. If one is shorted, you have a problem. The usual way a TV service person would test for startup problems is to inject a signal to the base of the HOT of about 15.75 kHz. If the TV then starts and runs once this signal is removed, the diagnosis is confirmed. This is risky - you can blow things up if not careful (including yourself). See the section: Bypassing the Startup Circuit for details.
Hope this help
May 30, 2010 | Televison & Video
Mitsubishi 55'' projection tv model # WS-55909 won't turn on
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT
Nov 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
My tv screen went green for a few seconds then went blank, the power light is on but no picture, my tv is not a plasma or lcd.
It appears that you may have either lost the High Voltage to your CRT(picture tube) or your CRT went belly up. There is also the possibility that you also lost the low voltage power supply feeding the Chroma circuits, but either way it will require a repair shop to look at it. You might consider getting a new TV.
Oct 11, 2008 | Televison & Video
Tv won't turn on..
need to replace the power supply
Sep 03, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Power on won't stay on
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB
Sep 07, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
