Question about Vtech 5.8GHz Cordless Phone with Digital Answering System
Same scenario, all phones say "connecting"
The phones started ringing, i picked up and heard "hello" before all phones cut out and now say "connecting". other wired phones still work
  • 22 Answers
Yeah OK. A 5.+ Ghz transmormer via your head is then releyed to via MWatts to & back to you. How smart are you?
Posted on Jul 03, 2009
How do I get my phone to work it right vs but there is no sound or ring tone
try the buttons on the side of the phone. you may need to open your phone or go to the call mode
Sep 23, 2016 | Lands Phones
How to pick up a internal call from colleague extension?
Depending on the system the phone is connected to, you can dial 40 on the intercom or 4+1xx (the intercomed extension) to pick up the call.
40 will pick up anything ringing in your group, so if you want to be sure it's only going to answer your colleague's call, use the 41xx code.
If the code doesn't work, check out your user's guide for directed call pickup.
Carl
Dec 31, 2012 | Panasonic KX-T7730 Corded Phone
Answering system records message after hang up
One thing to try and take note of is when the message does pick up on the "two ring" message present part do you hear on your side two full rings before the pick up?
It may be that the primary ring starts on the home side as does happen sometimes with VOIP service. If you are only hearing 1 or 1 1/2 rings before the message picks up then you might try hanging up after the second full ring thus knowing no messages are present and it should overcome your problem.
Dec 12, 2009 | Uniden Cordless Phone
IT WILL RING BUT GOES TO ANSWERING MACHINE DOES NOT RECEIVE FAX
>first run fax test, press set up go to tools menu then select run fax test,all entries should be pass
>then check your connections, do you have one line or number for your fax and phone?or a separate line or another number for fax and another number for phone?
>let me assume you only have one number for fax and phone..
>check connections, this should be downstream connection, the fax machine using the black phone cord provided by hp should be connected directly to the phone jack using line 1 at the back of the fax and the answering machine or the telephone should be connected to ext 2 or line 2 at the back of the fax...there should be no other devices phone or answering machine connected directly to the phone jack.
>next set rings to answer on the fax machine higher than the answering machine...if your rings to answer on answering machine is 4 rings, set the fax to 6 rings...if it is a voice call the answering machine will pick it up at 4 rings then if it detects that it it a fax tone then it will transfer the call to fax.
>also check if auto answer is on in your fax
>you can check auto answer and rings to answer by pressing set up or menu button on your machine look for it in basic fax settings or advance settings
>also check if your voice prompt for your answering machine is not too short there should be like at least 5 seconds after cutting your message to allow the machine to transfer the call to the fax if it is a fax tone.
Sep 14, 2009 | HP 1040 Plain Paper Inkjet Fax
Incoming faxes not received, all else works.
It is your phone answering machine that must pick up in three rings or less.
Therefore 4 is too much. I would not limit number for fax machine itself.
On receipt of fax sometimes seems like it will not work when answering machine picks up in the middle. However, leave it and it will work. Sometimes sender will hear your answering machine and cancel as well. So try to ensure they don't give up at other end as well.
Good Luck!
Feb 26, 2009 | HP OfficeJet 6110 All-In-One InkJet...
No dialtone
If you use Dsl as a internet provider make sure you have the filters on each phone. If you use cablevision and have a wireless connection make sure you chage the phone to a 5.2ghz because you might have the wireless router with the same ghz causing a coflict. This will also create loss. of internet connections then you use the phone
Jan 19, 2009 | Panasonic GigaRange KX-TG2432 Cordless...
Getting to answer phone before fax or message bank cuts in
to stop the pixma from picking up even after the phone line has been picked up you need to ensure the telephone line is connected to the LINE port and not to the PHONE port on the back... the PHONE socket is if you wish to connect a phone line to the same socket Thru the pixma. (passthrough)
not sure how to stop the pixma picking up on the first ring though..... are you sure that you are SAVING the setting change.....?
Sep 28, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Answering machine wont pick up it just cuts off incoming call leaving line busy
just set the amount of rings higher on the back of the phone and make sure all you old messages are deleted and also make sure its not set to do not disturb
Mar 28, 2008 | Uniden Cordless Phone
Answering machine doesn't pick-up reliably
I found in the manual that if the machine doesn't answer after the correct number of rings, then it may be the ringing system used by the phone company. But I have also heard of people with VOIP (such as Vonage) having problems with this as well.
http://telephones.att.com/docMgt/public/art/21714/1738_english_manualpart2.pdf
Dec 05, 2007 | AT&T 1738 Digital Answering Machine
Vtech 5.8GHz Cordless Phone with Digital Answering System Logo
287 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
