Question about Kenwood KDC-MP332 CD Player
Hooked up the kdc-mp332 without having speakers connected to the unit an it still reads protect what do i do?
  • 75 Answers
Shut it off connect speakers and re set it
never ever hook up an audio system with out speakers this will blow the amp transistors.
Posted on Jul 03, 2009
Radio display says protect. does not emit sound.
Sounds like you have either a short in your speaker wire somewhere, wires touching in the back of the unit or a short inside the stereo itself... Try pulling the radio out and unhooking all of your speakers...Turn unit back on after all speakers are disconected...If unit still shows protect, then radio is bad...If it doesnt, power off and hook up speakers one by one and power it back on till it shows protect again....When it does, the last speaker wire you hooked up has either a crossed wire or the speaker is bad...
Oct 07, 2010 | Kenwood KDC-MP205 CD Player
I need to hook up a kenwood kdc-mp332 to a vw passat 99, what adapters/plugs do i need?
go to walmart or an adio shop to the stereo section and look at the plugins they should have it
Oct 07, 2009 | Kenwood KDC-MP332 CD Player
It is flashing the word protect on the screen
You have a shorted speaker wire or a blown speaker. The unit is protecting itself from damage. Did you install it? if so, pull the deck and check your connections. If they all seem fine, disconnect one speaker at a time, and turn on the radio. Make sure the radio speaker wires are taped so they don't short and cause more damage. Test each speaker wire until you find which one is causing the problem. Now re-connect all the other speakers and test. Next, disconnect the speaker wire right at the speaker that's giving you a problem, tape it off, then re connect it to the receiver. now test again. If all is ok, you have a bad speaker, if not run a test wire from the radio to the possible bad speaker and test again. If the speaker plays, you know what the problem is, replace the bad wire. Most often it's a door speaker wire or a wire got pinched during installation and took a while to short. Hope this helps
May 24, 2009 | Kenwood KDC-MP332 CD Player
Cd read e-05
Well E-05 error code on Kenwoods is "the cd is upside down" So either the disc is upside down or there is a problem and the Kenwood unit thinks it is upside down.
Mar 05, 2009 | Kenwood KDC-MP332 CD Player
Front Speakers Not Working
Hi, as a retired installer maybe i can suggest a better configuration. I would run your front speakers in series with your rear mids in low level. Your sound will be alot cleaner. Hppe that helps.
Aug 26, 2017 | Kenwood KDC-MP332 CD Player
I have a kenwood kdc-mp332 and it just show protect i need music now please help
My manuel says : Protect: The speaker wire has a short-circuit or touches the chassis of the vehicle, and then the protection function is activated. Wire or insulate the speaker cable properly and press the reset button. I had the same problem with my stereo, but I took it to Geek Squad cause I still have warranty on it.
Dec 06, 2008 | Kenwood KDC-MP332 CD Player
My kenwood kdc mp332 car cd player is saying that it is on protect and will not play anything. how do i get it on and off protect?
if the power is not turned on (or it is on, but will be off immediately,) the speaker wire may have a short-circuit or touched the chasis of the vehicle and the protection function may have been activated. therefore the speaker wire should be checked. the press the reset button. also it will do that if it gets hotter than 60 degrees celsius or 140 f
Apr 20, 2008 | Car Audio & Video
Security
"Protect" isn't for security on a Kenwood; it's caused by a problem with the speaker output. There may be a defect in the CD player, or you may have a blown speaker or a shorted speaker wire in the vehicle. Try disconnecting all the speakers and see if the unit still shows "protect" when you turn it on. If it still shows the "protect" message with no speakers connected, the unit needs to be serviced; if not, re-connect the speakers one at a time until you find out which one is causing the problem.
Aug 10, 2007 | Kenwood KDC-MP232 CD Player
Protected
Wires are exposed. According to the manual, the wiring is grounding out or exposed at some point between the head unit and the speakers.
Sep 13, 2006 | Kenwood KDC-MP332 CD Player
Kenwood KDC-MP332 CD Player Logo
122 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
