Question about Nikon Coolpix 5000 Digital Camera
No card present - Nikon Coolpix 5000 Digital Camera
    President:
  • 2,976 Answers
It needs a memory card. Usually an "SD" card.
Posted on Jul 03, 2009
How do I change present credit card to another credit card
Refresh page and try to go to setting and change payment mode to credit card.
Dec 17, 2012 | tracfone.com
Forgot the combination to the lock. Is there a way to retrieve the combination or return it to its factory default combination 1, 2, 3, 4, 5
The instructions below are copied from the programming instructions (page 11):
ERASE ALL PROGRAMMING
(The "out of box" factory default will be restored)
1. At the back of the lock, remove the screw at the bottom of
the lock housing and remove the cover.
2. Take out the battery pack and remove battery power by disconnecting
the battery pack.
3. Plug in the (provided) male shunt connector into the yellow
wire female connector.
4. With shunt connector connected, re-connect the battery
pack. The lock will immediately sound 3 short beeps (if
these 3 beeps are not heard, then restart at step 2).
5. The lock will then sound more slow beeps, 1 beep for every
second it takes to clear the memory.
6. After a few more seconds, the LED will slowly alternate between
flashing red and green--disconnect the yellow wire
shunt connector.
7. The LED will continue to slowly flash green and red for 25
seconds. To enroll Function Cards, proceed immediately
as follows:
• With the lock LED slowly alternating between flashing
red and green, present the Function Card #1
to the lock. The lock will sound 5 slow beeps.
• The lock LED will flash green rapidly. The lock is
ready to enroll the Function Cards.
• Re-present Function Card #1 to the lock. The
lock LED will flash green then red, with two beeps
(indicating the card was enrolled successfully).
• Present Function Card #2 to the lock. Again, the
lock LED will flash green then red, with two beeps.
• Continue to present, in order, Function Cards 3-
9. Each time a new Function Card is presented, the
After the 9th Function card is presented, the lock LED will flash
green twice, sound two beeps, and will then remain silent,
ready for use. Note: If the lock continues to beep after presenting
the 9th Function Card, check to verify that the yellow
wire shunt is disconnected.
Note: If you only wish to use the first 3 Function Cards, simply
allow the lock to "time out" after 30 seconds.
Here is the link to the complete instructions, in PDF form. You will need Adobe Acrobat or equivalent to view them:
http://napcosecurity.com/download/PL3000_WI1280A.04_PROG.pdf
Good luck-and please provide feedback if this helps!
Nov 04, 2011 | Trilogy ALARM LOCK PL3000 Series T3 Prox...
Hi - recently I've been getting a no signal message on my monitor - system is still runnung but no video. I have checked cables - all are OK - The computer is a Gateway DX4300
Three major components usually is causing this kind of problem. One is the memory card. Two the video card . and lastly worst is the motherboard. Check and clean your memory card first then put it back to its place of slot. Start your computer. If you hear one beep but still no pictures, the problem lies in your video card. If there's still no beep sound and picture, and you think your memory card is good, try to clean your video card, then start your computer. If there is still no picture, and you think your video card is good, then you have a problem with your motherboard. Indication that your cpu is working were, beeping sounds, lead lights blinking or changing sequence is present. If it is present, your monitor has a defect an needs to be replaced.But if none of this is present, we have a motherboard problem.
Sep 04, 2011 | Gateway DX4300-03 Desktop PC
Half side has vertical lines
Turn the computer OFF and just turn the monitor ON if the vertical lines are still present then the issue is your monitor, but if there are no lines on the monitor alone turn the computer ON then go into the BIOS either keep on tapping del key once you turn the computer ON or keep on tapping f1 to get into thew BIOS screen.
If the vertical lines are present in the BIOS the issue is the Monitor but if not and the lines are present in windows the issue is your video card.
Replace the video card, if you don't have a video card and you use the built in video card on the system then the motherboard needs to be replaced.
Sep 01, 2011 | LG Flatron Ez T710BH 17" CRT Monitor
I need a update on my graphic card driver. I don't have a vertex shader
Using dating drivers or directX to the latest versions to your present graphic card will not resulting you getting the "Shader Mode" option, because your present card is not support this option.
You have to get a newer graphic card with "Shader Mode 3" options.
Hope it helps.
May 06, 2011 | Computers & Internet
How do i unprotect my memory card from a canon 450d?
Thanks for using Fixya.
Every SD card should have a write protect switch located on the right edge, about 5mm from the top of the card. In order to unlock the card, slide the switch upwards.
Note that with Mini SD and Micro SD (Transflash) these switches are not present. The card is always unlocked. A switch may however be present on an SD card adapter.
Because of the position of the switch they can often be switched accidentally on inserting or removing the card.
Rating the solution is highly appreciated.
Apr 14, 2010 | Canon EOS 450D Digital Camera
Fuji FinePix F470 works perfectly unless a memory card is present
Some cameras are very sensitive when it comes to memory cards for some odd reason. I would try a different make of sd card.
Oct 13, 2009 | Fuji FinePix F470 Digital Camera
2 gig micro sd presently formatted in kodak c743
yes you can swap the card. there will be no issue.
Jul 02, 2009 | PNY 2GB microSD Memory Card
Frontech tv tuner card connection
I have my Frontech TV -Tuner Card and I like to connect the present PC with the Frontech TV -Tuner card for using editting with cable tv. Please send me drivers for using it.
Oct 28, 2007 | Computers & Internet
-SD Card was renamed
From what I remember when this happens you empty the SD slot and do a soft reset. When the SD card is put back in it will be SD card. Similar steps when you put your SD slot device in.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
Nikon Coolpix 5000 Digital Camera Logo
80 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
