Question about Kenmore Kitchen Ranges
Kenmore electric range model 790 oven stopped functioning, both broiler and bake. however, oven light still comes on.
Oven suddenly stopped functioning. Both bake and broiler elements do not heat. Oven light still functions range top functions. Help?
    Prodigy:
    An expert who has answered 500 questions.
  • Kenmore Expert
  • 663 Answers
I believe there is a thermal fuse (also called a TCO or Thermal Cut-Out) located either on the back of the oven, or between the top of the oven and the cooktop that has opened up. Did this happen after running a self-clean cycle?
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Posted on May 27, 2015
SOURCE:
  • 112 Answers
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Hello all with this oven not working problem!!! I had this happen and I found exactly what causes this to fail. The circuits operate in the following manner... The oven is controlled by a double pole single throw heavy relay (wired as a single pole single throw or simple off/on relay) that supplies power to 2 other relays.. The oven relay is a double pole double throw relay (6 contacts 12 volt coil, ) it is normally open circuit, that is when the main relay turns on the power goes to the oven relay but no further. The other sie of the oven relay is wired to a second relay connected to the broil element that is normally open circuit with the other side of the DPDT relay going to Leg 2 120 volts. So in normal off mode the broiler is connected to the one side of the relay, common is connected to Leg 2 and the other side of the relay is connected to the other side of the oven relay.
SO when you call for the Bake Oven element, the power goes through the main relay to the oven relay, the oven relay clicks and now connects the oven relay to the set of contacts on the broiler relay that is connected to Leg 2- now the oven turns on. When you ask for broil the oven relay turns off and the broiler relay tirns on connecting the broiler to leg 2 (bypassing the oven relay.
I know its long winded but basically to operate the oven the power goes through 3 relays where the broiler only uses 2 of the relays (not the oven relay) Kinda dumb way to do it I suppose BUT the idea is to never have a situation where the oven and broiler can be on at the same time.
Heres what happened with my oven.. the broiler relay failed (broke internally) and the common contact shorted across both of the other terminals momentarily turning on BOTH elements, the sudden inrush of current literally exploded the output contact on the main relay and vaporizing the lead, trace and solder joint.
It was a mess... badly burned.. I found a new relay (omron) to replace the main relay.. but the other 2 were Omrons that I could not find replacements for (12 volt coils is the issue) So I did find some potter brumfield relays that were rated 10 amps per pole so I wired these externally from the timer board (ran wires to them) (doubled up so each relay was using both sides in parallel so it can handle 20 amps) The elements only use about 8 amps each anyways this worked great and since the new relays are on spade terminals with quick disconnects, are easy to swap out of they fry again (doubtful) Its a forgone conclusion these timers are ready to fry at any time and I can almost guarantee the WILL blow.. the relays arent very heavy duty at all... I would not buy another of these.. pretty weak control.. expecially these small relays.
Good luck in your repair.. a new timer was 300 my repair was 50 and WILL NOT fail like theirs did.
Cheers
Dave
Posted on Dec 28, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool electric range model # RF261PXSQ oven not heating
I'm afraid you may have a blown Electronic Oven Control (EOC) board. The EOC controls all the functions of the oven. The surface elements are controlled by individual infinite switches behind each control knob.. That's why the surface elements all work, but the oven does not. A replacement EOC can be purchased on line at searspartsdirect.com. Just type in your COMPLETE model number and you will find it under the "Control Panel Parts" heading as item number 12. There are several listed, based upon the color you need (White, Biscuit, and Black). This is a very simple repair that any do-it-yourselfer can accomplish if you wish to perform this on your own. All you have to do is UNPLUG the appliance and remove the back panel of the console to access.
Before assuming the EOC is defective, however, inspect the board to see if it has a fuse on it. I do not have a wiring diagram to confirm. Some of these boards do have fuses and that's all that it may take to repair it. However, if the board shows signs of burned components, replace it. NOTE: Check for any loose connectors to the board as well.
I hope you find this information helpful. Let me know if you have questions and/or require additional assistance.
Posted on Sep 25, 2008
freetek
  • 5569 Answers
SOURCE: Bottom oven burner will not light
If your Kenmore is like most Whirlpool-built gas ranges, surface ignitors similar to those used in gas dryers are used. These devices have a conductive path fused to a ceramic substrate and are common failures. There are separate units for bake and broil burners.
Check the Sears website under the 'Parts' subsection and enter your range model number. This should bring up a choice of things to do and if you ask for the illustrated parts breakdown, you can see where the ignitor is located, get its part number, and generally order from that same site.
It's mildly disturbing that the range continues to allow gas to flow unignited.
Posted on Feb 07, 2009
SOURCE: i have no heat coming from the oven portion of my
Top burners are working, broiler is working, bottom oven burners dont ignite and dont heat the oven? What can we do?
Posted on Dec 30, 2009
blueextc3221
  • 15935 Answers
SOURCE: My Kenmore gas stove model 790, the oven will not
It appears your thermostat/probe has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Kenmore gas range model #790-77471790 oven stopped working...broiler and stove top still work
If the oven has stopped working but the broiler continues to work, it would imply that the bottom heater is broken. When you are using the oven, both the heater for the broiler and the bottom heater are at use. The broiler only uses the top heater.
Elisa Jed ' http://www.atlasappliances.com
Aug 19, 2014 | Kitchen Ranges
Kenmore 790 oven won't maintain temperature
anyone know where to buy the battery for hand phone model mini i9500 ? manufacturer is
z.doxio
Nov 12, 2013 | Kenmore Kitchen Ranges
I have a Kenmore 790.94479801 electric range. While using the Bake function, I noticed that the broiler element was on and the oven had gotten very hot. I hit the Stop button and noticed a small puff of...
When the broil function is off, check for continuity between the broiler relay output terminals. If there is no continuity, check for an external short. If there is continuity when the broiler is supposed to be off, you need to replace or repair the board.You can get your old board repaired at appliancetimers.com.
Mar 18, 2011 | Kenmore Kitchen Ranges
KENMORE ELECTRIC RANGE 95032. EVERYTHING WORKS BUT OVEN DOES NOT HEAT.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 25, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
My Kenmore electric range oven, model 790.suddenly stopped working while I was baking at 400 degrees. The coil burners still function correctly but the touch 'panel' which controls the oven...
The oven is controlled by a separate circuit in relation to the coils. That is why your cook top operates as it is independent. If the Oven controls are failing to work, it could be that the circuit board has shorted out or a fuse has disconnect operations. This requires a professional technician with the proper test equipment to trace down the problem.
Jan 30, 2018 | Kitchen Ranges
I have no heat coming from the oven portion of my kenmore 790 electric range after hearing a "pop" sound. fyi, the element looks intact.
Dec 30, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 11, 2009 | Kitchen Ranges
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Jan 13, 2009 | Kitchen Ranges
Kitchen Ranges Logo
265 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
