Home | RCA | D52W20 52 in. Rear Projection HDTV-Ready Tel... | Rca 52" hd
RCA D52W20 52 in. Rear Projection HDTV-Ready Television
Problem for RCA D52W20 52 in. Rear Projection HDTV-Ready Television
Rca 52" hd
By lorendaw2 on Jul 03, 2009
turns on fine and stays on for about 10 minutes then turns itself off. It will not turn back on until after it cools, I guess?
Sponsored Links
Best Solution
posted on Jul 03, 2009
Helpful)
palaboy
Rank: Wiz  RCA Expert Televisions & Videos  Expert
Rating: 82%, 1141 votes
have the voltage of the regulator output measured, start from the diode right after the chopper of the main regulator with the 200v capacitor near to it. whatever voltage you get will determine the status of your horizontal deflection circuits. if no voltage at all check for a shorted horizontal output transistor. if you will have a reading of at least 120V have the entire pins of the flyback re-soldered, and check for cold solder joints. if you will be getting a reading of 80V you have a partially shorted flyback transformer.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for RCA D52W20 52 in. Rear
Questions and Unsolved Problems for RCA D52W20 52 in. Rear
Do you recommend RCA D52W20 52 in. Rear Projection HDTV-Ready Television?
Answer
Answer
i need a high def cable but the ones tn the stores are smaller where can i get one or what kind of... (More)
Answer
all 3 color lines are stagerd and i cant get them lined up properly and then the t.v. just cuts off
Answer
I have a rca D52W20 52 inch hdtv. When i try to turn the set on it tries to come on but turns off,... (More)
Answer
color on faces red and blue also shadows on faces arms ect.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For RCA D52W20 52 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 1444
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
