Question about Vizio GV47LF Television
I came home and turn on TV and notice it was darker than ever the picture is deep dark and not as bright as it wss
  • brubaker63 Jul 03, 2009
    thanks but what is a new display
  • 2,071 Answers
First thing to do is a hard reset. Merely unplugging the HDTV power cord for 4 hours, then power up again.The purposed of unplugging is to dissipitate the stored current in the memory IC so it will gone.
If the reset does not help, try disconnecting anything on input 2. For example, if you have a dvd player connected to that input, the tv may be sensing its presence and switch over to it. (Especially, if the device is left ON).
Good luck:
Regards:
VOTIT
Posted on Jul 03, 2009
  • 744 Answers
Hi...
the reason for ur darkness in ur tv is that ur diplay has gone bad and needs a immediate replacement.... the best solution is to purchase a new display for ur television..
thank u
rate me
I have a Dark picture, so it is hard to see Darker scenes...Can I or How can I Adjust...?
Yes you can. Go into your menu system, picture adjustments, and adjust the brightness level.
Mar 01, 2015 | Philips HTS3410D/37 700W DVD Home Theater...
Why is sony bravia dark screen
If your TV seems to be darker than you think it should be, it is possible that the problem is with the light sensor. The light sensor will automatically adjust the picture brightness based on the ambient light that is in the room, (i.e. if the room is bright the picture will also be bright, if it is dark the picture will also be dark).
To turn this feature off go to Settings > General Setup > Light Sensor.
Feb 27, 2015 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Dark line down the middle of my flat screen tv
Most LCD and PLASMA sets use two boards (some combine them into one board) that drive the Display Panel (the entire front screen unit) so I would suspect one of yours is bad.
The other unpleasant possible cause is where the left board is connected to the Display Panel (entire front screen unit) you have a problem inside that Display Panel and that is fatal as there is no way to get INSIDE the panel---it can cause both lines and a dark picture on one side of the screen.
May 25, 2012 | Sylvania Televison & Video
Hi Guys, I have a JVC 32T55EKS TV & the picture is overly dark. When the picture goes through the set-top box the picture gets even darker. The brightness is turned up fully & I have accessed the...
U turn on the contrast level to the max,if still not watchable,tv cathoray tube is dying,radiaton is disappearing.Time to buy another tv.
Feb 14, 2011 | JVC AV-27230 27" TV
Screen getting dark
If you have never changed the lamp this is more than likely the issue, as the tv ages the lamp looses brightness. Most lamps are rated for 3000-5000 hrs of use. Replace the lamp assembly part # UX21514 and you will notice a much brighter picture. You do not mention if the tv plays the right colors on the entire screen. These have had light engine issues.
Good luck with it
JOTVGUY
Apr 07, 2009 | Hitachi 50VX915 Rear Projection Television
JVC TV THE PICTURE IS DARK EVERYTHING ELSE WORKS GREAT
there so many things which can cause that to happen an these are thwe following,
i a tube has to be tested
ii a line transformer
iii vedio amplifier
this tests can be done in w/shop where other tvs are of the same.
Mar 27, 2009 | Televison & Video
My JVC 56G787 is dark and bright is turned all the way up
You need a professional.
Stop using the TV until it is repaired.
Continue to use it and your problems will multiply and grow more expensive.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | JVC HD-56G787 Television
Dvd picture is darker than tv picture
Most sets have electronic service adjustments. Contact manufacture for nearest service center.
Mar 06, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Darks too dark
try to open your tv and you can find the flyback ,in flyback you can see the screen and focus to adjust.use and try to rotate the screen,it control the brightness of your unit
Oct 15, 2007 | Toshiba 32AF43 32" TV
Picture is getting darker and darker
if the tv has never been service before you could have dust on the 3 tubes,this will decrease the brightness to the screen. try taking the front or back off & see if you can see the top of the picture tubes. remember to unplug the tv & to clean spray the cleaner on the colth , then clean the tup of the tube. never spary on the tube itself. hope this works for you.
Oct 22, 2006 | Panasonic PT-51HX40 51" Rear Projection...
Vizio GV47LF Television Logo
59 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
