Question about Yamaha RX-V1800
Have no sound when I connect the rear speakers
    President:
  • Yamaha Master
  • 1,114 Answers
Open the "Menu" on screen, go to "manual setup" then "speaker setup" check your settings on "surround rear" and "surround back" If your not using zone 2 and zone 3, in the menu for zone 2 amp, select "Ext" and "Ext" for zone 3. If you still have an issue, post a comment and I can help you some more. I am a Yamaha Dealer. Hope this helps
Posted on Jul 03, 2009
Why is there no sound from rear speakers?
One of the buttons you pressed probably disabled surround sound
Nov 03, 2015 | Denon AVR-791 7.1 CH A/V Home Theater...
Creative SB X-Fi titanium rear speaker out problem
Hello.
This sound card it is well compatible and all you have to do its depending on your OS update and reset the sound properties to get the full reestored sounds of all channels.
Hope this hint helps
Carl
Apr 02, 2017 | Creative Technology Creative Labs Sb0880...
I don't know which port in the back of the Pavilion to connect the black wire from the speakers (that connect to the right speaker with red and white ends). Any ideas? They are labeled as side, rear...
To get "surround" sound, when you face the computer, you will have:
* 2 front speakers, one immediately on each side of the computer
* 2 side speakers, one on each side of your head
* 2 rear speakers, one behind each side of your head
Thus, when the sound is of a jet-plane coming towards your face,
you'll first hear the sound in the front speakers,
then in the side speakers,
and finally in the rear speakers,
to produce a sound-effect of the jet passing over your head, and going "behind" you.
Usually, for "front" speakers, one speaker connects to the other speaker, and the second speaker connects to the "FRONT-audio-output" connector on your sound-card.
For side speakers, one speaker will connect to the LEFT-side-audio-output port,
and one speaker will connect to the RIGHT-side-audio-output port.
For rear speakers, one speaker will connect to the LEFT-rear-audio-output port,
and one speaker will connect to the RIGHT-rear-audio-output port.
Jun 01, 2011 | Audio Players & Recorders
My left rear speaker has no sound. All others work. I have tested the speaker on a different reciever and it works fine. My reciever is a integra DTR 5.5
Swap your left and right rear speaker over. If you still get no sound from the right speaker connected to the left speaker connection on the receiver, then you have a fault on the receiver output. Check your manual first to see if any setting switch off the rear speaker before taking the unit for repair or replace
Nov 26, 2009 | Integra Audio Players & Recorders
No surround sound
It sounds like the speaker wires are mixed up or maybe a setting on the reciever is wrong. Verify your speakers are properly connected. you test speakers using a 9 volt battery or smaller.
Jun 19, 2009 | Bose Lifestyle 12 System
STR--DG910: no rear speaker sound, no center speaker sound
if you confirmed all connection repeat your speaker setup.
Jul 06, 2008 | Sony STR-DG800 Receiver
Cant connect rear speakers
Hey there Subaquakid, the nature of surround systems is to identify separate extra channels of information and send them to the right address, being the selected speaker. In order for the rear speakers to work they need to be sent a signal. The media which you are using may not have the rear channel encoded. therefore the rear speakers have nothing to announce. Please ensure your source cd has the suround feature encoded. Hope this helps. Good Luck!
Jan 28, 2008 | Dell WL6000 Computer Speakers
Both rear speakers on my z540 system play only the left side rear
Hmmm, this sounds like either a driver issue, or a card/compatibility issue. you might try reverting to old drivers(last resort), making shure you have 4.1 enabled in sound control pannel(do this first), triple checking connections/connectors on both the speakers and the card(remember, you only have 5 speakers, not 8) and if you have the headphone-type phone plug for your speakers, you might try making shure that they are compatible with the jacks on your card, although, I would have to know more about your setup to be completely shure.
Dec 26, 2007 | Logitech Z-540 Speaker
Rear speaker connection issue
OK, the fix for the missing rear speaker sound on the DELL WL6000 5.1 Surround Speaker System is relatively simple, just 7 simple steps (Verified by Dell at http://support2.jp.dell.com/docs/acc/P121646/multlang/srg/DAO/srg_dao.pdf..
First, power down everything. Second, disconnect the rear speaker and subwoofer from the power source and wait about 5 minutes. Third, be sure the power switch is off on subwoofer and the center speaker. Fourth, plug in the power for the subwoofer but DO NOT turn on the power yet. Fifth, plug in the rear speaker power cord. Sixth, turn on the swtich on the subwoofer (this is the start of the resync mode). Seventh, turn on the center speaker power and the system will change the rear speaker system LED from flashing blue to solid blue in 5-8 seconds. The surround system is functioning again. You may test this under sound in the Control Panel but I would prefer to use a modern music CD that has Dolby Digital Support for 5.1 sound or better. YOU WILL HEAR INSTANTLY THE SOUND DIFFERENCE WHEN THE REAR SPEAKERS ARE CONNECTED.
Nov 10, 2007 | Dell WL6000 Computer Speakers
Yamaha RX-V1800 Logo
181 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
