SOURCE: Reset my engine oil low in 2007 chevy impala
it will say in your owners manual but i believe you turn your ignition key to the run position not the start. and pump the gas pedal 3 times with in 5 seconds
SOURCE: How reset service interval light (already changed oil, oil filter, etc)
the service interval "light " has nothing to do with emissions or a problem with the car . There is a rectangle slot on the dash cluster you just use your key and press it and it just resets the counter
SOURCE: volvo 2002 S80 T6 - codes P0011 and P0011
Weell it sounds like you have the days old problem Pepole dont know how to look after there cars.
The muck you still have in the engine isent doing it any good and so you have to get rid of it all, as its in the engine block and is got to go ,,so drain a little of water out and put in 1/2 a cup of washing up liquid in the radiator and start the engine and let it get hot and take the reves up to 1000 rpm now and then to keep the water going around the system, after about 1/4 hr turn off,,stand for 10 minutes ,,and then remove the cap slowly and then take off the Bottom hose and let all water out also take off Top hose at the engine end and put the house water hose in the top and turn it on till all water comes out clean. Then put hose up into the bottom hose and do the same again ,and the same in top again.Now with a clean engine you can do the same to the new Radiator and wash out all gunk .then check the thermostat and make sure its 100% (any doubt through it out) and take note how it comes out so you can fit a new one the same way,
Now refit both hoses and fill with coolant or antifreeze and TURN on the heater to hot before starting as you also have to get out the air from heater when it was drained and you will trap the air which might cause you code problems..
But now try service light reset
1,,Turn Ignition to Number 1position.
2,,Press and hold "day counter"reset button and turn
ignition to II(second) position,hold down for about 12 seconds.
3,,Afterservice light flashes,release button,there should be 2 beeps confirming reset was successful.
Let me know how you get on .. Ron
SOURCE: code indicated #3 misfire, changed spark plugs and
Change the spark plug wire also. This is often looked over but it has most to do with a miss fire then a spark plug 9 times out of 10
SOURCE: I have a P0011 "Camshaft Position/Bank 1 code.
OK check the CMP sensor connector for cleanliness, sometimes oil can get in and disrupt the signal transmission to the ECU. Check the wire loom continuity all the way back from the CMP to the ECU. If the error code persists remove the cam sensor, clean its tip of any debris and refit.
Testimonial: "Thanks joe2mercs...you had the problem diagnosed correctly. Cleaned and light has not come back on. U saved me a lot of $."
