Sometimes the timer on my kenmore heavy duty series 80 is hard to push in to stop the washer. any help is appreciated
    President:
  • 1,136 Answers
Hi, The only way to fix this issue is to replace the timer. It is starting to go bad inside.
Vic
Posted on Jul 03, 2009
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
Washing machine does not advance cycles automatically
More than likely a bad timer. You can buy the parts on-line, one source is repairclinic.com. Go to that page and enter your model number and look for timers. I found several there for your machine depending on the options the machine has.
Jul 04, 2014 | Kenmore Washing Machines
Kenmore washers, heavy duty 80 series, no spin
Hello, Your problem is going to be with your lid switch, this is located normally either in the control panel or about half way down on the right side under the lid. This is a safety feature to stop you opening the lid while the machine is in a high spin. Once you have located the switch trace the wires back to the wire harness in the control panel. Disconnect the lid switch from the wire harness and with an ohms meter check for condinuity on pin 1 & 3 (the 2 outside pins not the middle this is a ground) You should find you have no condinuity and should replace this switch. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 14, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Aug 21, 2009 | Kenmore Washing Machines
What is the capacity of my Kenmore washer?
3.2cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore washing machine will not drain
Replace the timer.
This is a neutral drain machine. If there is no natural pause in the timer at the end of the rinse cycle the timer is bad.
Mar 13, 2009 | Kenmore Washing Machines
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Kenmore/works on one cycle only
that machine have somes burn contacts on the timer replace with a new one and that is...good luck
Aug 07, 2006 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
