Question about Canon PIXMA iP1600 Printer
Paper jams but doesn't go anywhere!
My canon pixma iP 1600 keeps jamming. I am using just normal plain white paper and it keeps getting jammed in the right hand corner. The message tells me to unjam it and press the flashing orange light button. I have tried 5-6 times it is not working. The paper comes out easy as it barely goes anywhere. I have tried everything I don't know what to do now.
  • 4,041 Answers
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 27, 2010
Paper Jam error
unplug the printer and then restart your computer and plug the again. if not work, please try cleaning some part of the printer inside by blowing air.
Jan 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Service error 6000 for canon pixma iP 1600
Error 6000
An error occurred in the LF encoder signal.
Can be the result of a deep paper jam with pins, paper or other miscellaneous objects stuck in there.
Check the unit and clean thoroughly.
Jan 15, 2013 | Canon PIXMA iP1600 Printer
Canon iP 1600 printer won't print. Says that
Hi
If it keep saying paper jam Then it maybe just that you may not see any paper in it but it only takes a very small bit of paper that stopping it or I would take a closer look inside, you may have had a paper jam before and it has left a small nit inside. All Best: Pineworks
Feb 01, 2010 | Canon PIXMA iP1600 Printer
Canon pixma ip 1600...can't clear paper jam there is no paper jam but it keeps telling me there is
possible that there is a very small piece of paper near the edge or back that the sensor is picking up ... check again and see if there is something there
Jan 10, 2010 | Canon PIXMA iP1600 Printer
Printer says clear paper jam then press reset
Could there possibly be:
A) Paper jammed internally: Power Off. Open the cover and remove the paper or scrap carefully. Do not touch the internal printer parts. Close the cover. Power on.
B) Foreign objects in printer: Power Off. Open the paper support and confirm that there is no foreign material in the auto sheet feeder. (If so, remove it by hand or with tweezers). Open the front cover and confirm that there is no foreign material in the unit. Avoid touching the inner workings of the machine.
C) Reset the printer:
1. Turn the printer off with the Power button
2. Disconnect the data cable from the printer
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. Attach data cable.
4. Turn the printer back on.
If all of these suggestions fail, your iP1600 may require repair service. Please note: With the suggested retail price of $29.99 USD, repair does not seem cost effective - you could just go out and purchase a new printer.
Dec 28, 2009 | Canon PIXMA iP1600 Printer
Canon iP 1300 keeps coming up with Paper Jam
this problem may be due to many reason.
first due to moisture in paper. try some good one and rey paper.
second due to dirty paper feed roller problem. clean the roller with moist cotton using cleaning liquid such as spirit, petrol or nail polish remover.
and last may be due to mis allignment of paper feeder assembly contact any printer specialist.
Aug 21, 2009 | Canon PIXMA iP1300 Printer
My canon ip 2600 keeps popping up paper is jammed
hmmm...
I think the paper pick mechanism has failed..
try to add some paper to it..so the paper pick can easily pick it...
if the problem still exist ..try to full out all the paper in the tray and put it again..
May 12, 2009 | Canon Pixma iP2600 Photo InkJet Printer
LCD Error message: Paper output slot. Thye paper is jammed. clear the paper and press OK.
A jam sensor may be stuck or have something stuck on it, causing the machine to think it is jammed. These sensors are normally located where the paper feeds into the printer, and where the paper exits the printer. Try forcing a sheet of paper through the machine in the direction paper normally. feeds. This may free up the jam sensors.
Jul 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA iP1600 Printer Logo
110 people viewed this question
old marine
old marine
